VFR "picking his way thru" heavy cells with XM Radio weather
On 6/4/2007 1:30:51 PM, Larry Dighera wrote:
Did you happen to note the aircraft's N number? Someone should relate this incident to the appropriate FSDO office before the tapes are wiped, Not only do I have the tail-id but I also have the exact exchange, thanks to LiveATC.net's 40-day archive. However, Larry, I am not going to be the one to report anyone, since IMO this is quite a gray area. I personally have a very different take on reporting pilots to the FAA. For education purposes, though, I thought it might be beneficial to retrieve and edit the archive files into a short clip (and also removing the majority of the tail ID so the resulting clip cannot be used against the pilot) with the relevant content. When I have the clip, I will post it to a file sharing site and the link to this thread. -- Peter |
Similar Threads | ||||
Radio "Squelch-type" Noise | Kensandyeggo | Owning | 7 | April 12th 06 07:20 PM |
jeppesen "aviation weather" book | Mike | Instrument Flight Rules | 0 | March 26th 06 08:09 PM |
