How does fuel (safely) get from the tank to the engine?
It would seem logical to just draw gas from the lowest point of the
tank into a fuel line leading to the engine. But contrary to a car, an airplane can experience negative gs, and especially in aerobatics, for prolonged periods of time. So a pump connected to the lowest point of the tank would only draw fumes at some point. How is this problem solved? Thanks (again) for enlightening me, Oliver |
On Nov 25, 9:23*am, Oliver Arend wrote:
an airplane can experience negative gs... During which times the engines of most airplanes just sputter. Aerobatic airplanes usually have at least one tank with the fuel pickup on a flexible hose that follows the fuel. That's usually called a "flop tube." Thanks, Bob K. |
"Bob Kuykendall" wrote in message ... On Nov 25, 9:23 am, Oliver Arend wrote: an airplane can experience negative gs... During which times the engines of most airplanes just sputter. Aerobatic airplanes usually have at least one tank with the fuel pickup on a flexible hose that follows the fuel. That's usually called a "flop tube." Thanks, Bob K. Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel. It's very successful in modeling. You just stick a weighted fitting on the end of the hose called a "clunk". |
On Nov 25, 2:53*pm, "Maxwell" #$$9#@%%%.^^^ wrote:
Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. |
On Tue, 25 Nov 2008 15:11:12 -0800 (PST), Bob Kuykendall
wrote: On Nov 25, 2:53*pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. They are getting a little pricey lately, around $55 at Aircraft Spruce |
"Bob Kuykendall" wrote in message ... On Nov 25, 2:53 pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. Duh? I misread your post. Although you described it as a hose, when you called it a flop "tube", I pictured a mechanical tube or arm. |
On Tue, 25 Nov 2008 20:24:38 -0600, "Maxwell" #$$9#@%%%.^^^ wrote:
"Bob Kuykendall" wrote in message ... On Nov 25, 2:53 pm, "Maxwell" #$$9#@%%%.^^^ wrote: Do any of the experimental aircraft designs use just a simple hose with a weight that follows the fuel... Yes. It's called a "flop tube." Thanks, Bob K. Duh? I misread your post. Although you described it as a hose, when you called it a flop "tube", I pictured a mechanical tube or arm. In aircraft use, generally it IS a tube, not a hose. |
Similar Threads | ||||
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:33 AM |
Fuel tank balance | Mxsmanic | Piloting | 101 | October 3rd 06 07:56 AM |
Engine driven fuel pump necessary with gravity feed tank?? Lycoming | RonLee | Home Built | 2 | May 8th 05 06:10 PM |
fuel tank plumbing | pwm | Home Built | 18 | January 27th 05 04:54 AM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
