Libelle 301 water ballast
Old January 14th 08, 10:50 AM posted to rec.aviation.soaring
Default Libelle 301 water ballast
Do 301's have water ballast as an option?
Thanks
Al
Old January 14th 08, 02:37 PM posted to rec.aviation.soaring
JJ Sinclair
On Jan 14, 2:50*am, "
Thanks
Al
No, but some in the US have added water ballast to ships licenced in
the experimental category. The Feds won't let you go over the 660 GW
in standard category.
JJ
Old January 15th 08, 07:29 AM posted to rec.aviation.soaring
Thanks
Al
JJ
Thanks JJ.
What ever happened to your 301 from doug and the full canopy franken
libelle?
Regards
Al
Old January 15th 08, 02:40 PM posted to rec.aviation.soaring
JJ Sinclair
On Jan 14, 11:29*pm, "
Thanks
Al
JJ
Thanks JJ.
libelle?
Regards
Al
I gave it a good annual last year, it was in good shape except for
blisters because the owner didn't open the trailer for a year. He said
it was up for sale at 12ish, last I saw it was at Williams Soaring.
You'd fit in the franken' cockpit real well, Al and your young enough
to get in and out without shoulder pain. I had a cherry 301 that I
flew in the Reese nats, but my shoulder hurt for 6 months afterwards.
It's down at Tehachapi. The unmodified 301 is a good machine for
sports class, climbs like stink, doesn't run all that well above 70
knots. Bet it could win in weak conditions. The Schuemanized Libelle
goes well, but they knock off 5% on the handicap and I don't believe
its all that good.
Cheers,
JJ
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Water Ballast Upgrade P.Corbett Soaring 5 December 5th 05 02:32 PM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
