#11
Belly Landing - Involve the insurance company?
On May 25, 5:40*pm, David wrote:
On May 24, 1:22*pm, "noel.wade" wrote: All - Would love opinions from anyone who's been through an insurance- related claim on a glider... *My DG-300's gear collapsed on landing Saturday. *The down-lock tab squished into the rubber "donut" spacer, .............. Thanks, --Noel Noel, Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Try it and see. I recommend you have your mechanic check the landing gear gas strut. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. David My 300 has done this as well, it very important to make sure the handle is really engaged hard, I was lucky we had come to a halt before it subsided rather majestically with no damage. Obviously slipped out at that point. |
On May 25, 6:30*pm, brianDG303 wrote:
On May 25, 9:40*am, David wrote: On May 24, 1:22*pm, "noel.wade" wrote: All - Would love opinions from anyone who's been through an insurance- related claim on a glider... *My DG-300's gear collapsed on landing Saturday. *The down-lock tab squished into the rubber "donut" spacer, .............. Thanks, --Noel Noel, Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Try it and see. I recommend you have your mechanic check the landing gear gas strut. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. David David, What happened to you and to Noel almost happened to me, but the gear warning buzzer went off. It is possible to set up the gear warning microswitch/magnet pair so that the gear handle has to be hard against the stop or the alarm will sound. Easy way to save some money. Brian Do you have a copy of how to do that? I would be bery nterested. Jackie |
On Tue, 25 May 2010 09:40:30 -0700 (PDT), David
wrote: Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. There's a modification available since about 1990 - it's a brass half-tube that shields the rubber and forces the pilot to push the lever fully forward before he can turn it towards the sidewall. Works like a charm. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Indeed - this is probably the most important point to know if you're flying a DG-30x - the gear lever must touch the sidewall if the gear is extended. I recommend you have your mechanic check the landing gear gas strut. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. Good advice, too. Cheers Andreas Bye Andreas |
On May 26, 12:55*am, JAS wrote:
On May 25, 6:30*pm, brianDG303 wrote: On May 25, 9:40*am, David wrote: On May 24, 1:22*pm, "noel.wade" wrote: All - Would love opinions from anyone who's been through an insurance- related claim on a glider... *My DG-300's gear collapsed on landing Saturday. *The down-lock tab squished into the rubber "donut" spacer, .............. Thanks, --Noel Noel, Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Try it and see. I recommend you have your mechanic check the landing gear gas strut. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. David David, What happened to you and to Noel almost happened to me, but the gear warning buzzer went off. It is possible to set up the gear warning microswitch/magnet pair so that the gear handle has to be hard against the stop or the alarm will sound. Easy way to save some money. Brian Do you have a copy of how to do that? I would be bery nterested. Jackie Jackie, the gear handle is attached to a tube that runs behind a removable panel, take that off. The micro-switch/magnet pair can be there. Move the magnet on the tube so that the switch opens if the handle is not in exactly the right place. Brian |
On May 26, 5:23*am, Andreas Maurer wrote:
On Tue, 25 May 2010 09:40:30 -0700 (PDT), David wrote: Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. There's a modification available since about 1990 - it's a brass half-tube that shields the rubber and forces the pilot to push the lever fully forward before he can turn it towards the sidewall. Works like a charm. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Indeed - this is probably the most important point to know if you're flying a DG-30x - the gear lever must touch the sidewall if the gear is extended. I recommend you have your mechanic check the landing gear gas strut. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. Good advice, too. Cheers Andreas Bye Andreas Andreas, Do you have a pointer to the brass half-tube mod? Is it on the DG web site? Thanks. Noel, One more thing. The black gear handle has two obvious orientations, 180 degrees to each other. One of those orientations will let the tab go a little "deeper" behind the end of the rod. After my incident I noticed I really wanted the handle turned by 180 degrees from what it was. Hope this makes sense, otherwise let me know. David |
On May 26, 3:27*pm, brianDG303 wrote:
On May 26, 12:55*am, JAS wrote: On May 25, 6:30*pm, brianDG303 wrote: On May 25, 9:40*am, David wrote: On May 24, 1:22*pm, "noel.wade" wrote: All - Would love opinions from anyone who's been through an insurance- related claim on a glider... *My DG-300's gear collapsed on landing Saturday. *The down-lock tab squished into the rubber "donut" spacer, .............. Thanks, --Noel Noel, Same exact thing happened to me in my DG300. The fact that the tab can get in between the rubber and the end of the rod is an unfortunate byproduct of this design. I now make sure every time that the tab goes beyond the end of the rod. The handle should be spring loaded (there is a mod for that) so make sure the handle applies touches the sidewall firmly. If it is pushing against the rubber it will not. So that's an indicator as well. Try it and see. I recommend you have your mechanic check the landing gear gas strut.. Mine needed to be replaced. The gas strut is what keeps the gear over center in the extended position. David David, What happened to you and to Noel almost happened to me, but the gear warning buzzer went off. It is possible to set up the gear warning microswitch/magnet pair so that the gear handle has to be hard against the stop or the alarm will sound. Easy way to save some money. Brian Do you have a copy of how to do that? I would be bery nterested. Jackie Jackie, the gear handle is attached to a tube that runs behind a removable panel, take that off. The micro-switch/magnet pair can be there. Move the magnet on the tube so that the switch opens if the handle is not in exactly the right place. Brian Many thanks, a job for Friday! I have had a couple of scares and this would be a useful mod. Jackie |
Similar Threads | ||||
How would you explain this to the insurance company? | Alan Erskine[_3_] | Aviation Photos | 2 | April 23rd 08 11:09 PM |
Safety Pilot restrictions by the Insurance Company? | Mark Hansen | Instrument Flight Rules | 14 | February 28th 07 12:29 AM |
Insurance company recommendation? | John Doe | Owning | 7 | October 27th 05 08:07 PM |
Getting around company insurance policy | Iain Wilson | Piloting | 19 | May 22nd 04 05:43 PM |
Belly Landing | Emilio | Military Aviation | 12 | November 26th 03 06:41 PM |
