Corroded main pins?
Old June 6th 20, 03:10 PM posted to rec.aviation.soaring
Default Corroded main pins?
If there is significant "pitting," the corrosion is probably advanced enough that the strength is compromised to some extent. If it takes more than polishing to remove rust, you are probably taking off enough material to affect the fit in the bushings, and that is most definitely a bad idea.
Pins for L33 Solo [email protected] Soaring 3 September 3rd 19 05:03 PM
Lift pins jp Soaring 25 July 30th 19 12:06 AM
Tapered pins (again) [email protected] Soaring 22 April 28th 18 03:06 AM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 12:46 AM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
