best IFR configurations/power settings for Cessna TR182
I am trying to determine the best IFR configurations/power settings for
my Cessna TR182. For example: APPROACH LEVEL GEAR UP: MP 17 in, RPM 2300, IAS 100, VS 0, Mix Rich, Carb Heat OFF, Flaps UP, Cowl flaps closed seems to work but I would like to hear from other 182 pilots: What approach level config/power setting do you use? Should Carb Heat be ON so monitoring carb temp not so important on final approach course? Do you put gear down before or at (as I was taught) FAF/point? Do you use 10 degrees of flaps in this configuration? If you put gear down at FAF, what other adjustments are needed to get VS = -500 at 100 KIAS? (I have to put Carb Heat ON and/or pull power back a bit to 16 in) thanks Greg |
Don't know much about T-182, but from an engine management point of
view, shouldn't a lower RPM, higher MP, and lean mixture work better for the engine during the approach? That way you keep the BMEP high, cylinders warm, and plugs clean. I, too, would suggest a higher MP, lower RPM. If your instructor warned you never to run you engine "oversquare," he was very seriously mistaken, and gave you bad advice.. vince norris |
vincent p. norris wrote:
I, too, would suggest a higher MP, lower RPM. If your instructor warned you never to run you engine "oversquare," he was very seriously mistaken, and gave you bad advice.. Too true. I generally will use the lowest RPM consistent with my power needs just for the noise relief. -- Mortimer Schnerd, RN VE |
Similar Threads | ||||
Cessna TR182 IFR configurations/power settings | Greg | Piloting | 1 | June 12th 06 05:41 PM |
TR182 cost of ownership - maintenance, etc. | john szpara | Piloting | 20 | March 29th 06 12:11 AM |
Lat/Lon to country codes/political boundaries | rutledge | Simulators | 9 | March 4th 06 03:59 AM |
Transmittion Noise - High Power Settings | Paul Smedshammer | Owning | 6 | August 20th 05 06:17 PM |
Cessna 404 Cruise settings | Katia | General Aviation | 0 | December 19th 03 05:04 PM |
