battery self-destruct
"Dave Stadt" wrote in message y.net... "Robert M. Gary" wrote in message ups.com... If the battery is 3 years old I probably wouldn't have even bothered trying to mess with the battery. After a few years of ownership now I replace my battery every 2 years. Seems to avoid a lot of hard starts that seem to appear out of nowhere leaving you stuck somewhere. -Robert With proper care they will last much longer. Mine is 6 years old and still going strong. Keep the posts clean and corrosion free, water at the proper level and the battery charged without using a high amp charger and they will last a long time. Keeping the engine in tune, keeping the battery warm in the winter and using the proper starting procedure also helps Agree on all points. Also, Battery Terminal Protection Spray from EPM Products helps a lot. In five years, have never had even the slightest hint of corrosion on the terminals. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
Dave Stadt wrote: | With proper care they will last much longer. Mine is 6 years old and still going strong. Keep the posts clean and corrosion free, water at the proper level and the battery charged without using a high amp charger and they will last a long time. Keeping the engine in tune, keeping the battery warm in the winter and using the proper starting procedure also helps I'm parked outside so there isn't a lot of warmth to come by. I would assume, like everything else, the battery would last longer in a heated hanger. -robert |
hanger. -robert Actually I understand a battery will last longer in a cold hangar assuming it isn't allowed to discharge and freeze. The internal corrosion of the battery rate doubles like every 18 deg F. Heat is a battery killer. I can't explain then though why my 172M batteries, located under the cowl, have each lasted 8 years for the last three batteries. I make sure the plates stay covered, but only rarely trickle charge it. |
If the engine starts quickly and the equipment load requirement is
met by the alternator then the battery does little work and will be expected to last longer. Empirical examples are not a foundation for logic and reason but are quite interesting. |
Similar Threads | ||||
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Battery life...how to test? | Jim Kelly | Soaring | 2 | July 11th 03 09:12 PM |
