#51
VW Reality
jan olieslagers wrote:
cavalamb himself schreef: oilsardine wrote: the modern 'VW engine': http://www.ulpower.com/ Now that is a sweet little motor! looks good indeed, strange to find such a nice offer from my own country without ever hearing about it otherwise... Only problem - I didn't catch the price? well, you could check out http://www.ulpower.com/price.htm where I read 12400 euro's, ex VAT of course, but including more accesories than most That being said, I am intrigued by your mention of a 500 hrs TBO. Still on their own website, I read quote ULPower has decided not to publish a TBO for our UL260i engine until we have gained sufficient insight into how a significant number of our engines are actually holding up to operating in real flying conditions. /quote which sounds wise to this beginner's ears In their download section - the Maintenance Manual.PDF file - under "Time Limits". 500 Hrs or 8 years. whichever comes first... |
#52
VW Reality
Charles Vincent wrote:
cavalamb himself wrote: oilsardine wrote: the modern 'VW engine': http://www.ulpower.com/ Now that is a sweet little motor! 165 pounds 2600 cc claims 81 HP at 2800 RPM 500 hour TBO FADEC No Carb Ice problems Only problem - I didn't catch the price? Isn't it more aptly a modern Continental C-85? I think the "modern VW" as far as homebuilts go is one of the subaru's. Charles A lot of people seem to think that about the Suburu, but they weight quite a bit more than you'd think. The extra weight means a PSRU is really mandatory to get reasonable propeller output (HP/LB) - with all the attendent complexity, harmonic, and weight issues. In my mind that takes them out of the "modern VW" class. They seem to be more at home on the nose of RV/Tailwind class airplanes. Richard |
#53
VW Reality
RST Engineering wrote:
Come on, Bob. How do you expect the EAA to make a buck out of something as useful as this? Sheesh, man, cherchez le dinero. Jim Indeed, these things are so simple -- and so fundamental to engines -- that it is difficult to understand why the EAA does NOT endorse a program of publicly testing engines at its annual convention. Endorsement would equate to liability. BEsides, EAA has never really been about the reality of it - they sell the dream. Richard |
#54
VW Reality
"cavalamb himself" wrote in message
... Charles Vincent wrote: cavalamb himself wrote: oilsardine wrote: the modern 'VW engine': http://www.ulpower.com/ Now that is a sweet little motor! 165 pounds 2600 cc claims 81 HP at 2800 RPM 500 hour TBO FADEC No Carb Ice problems Only problem - I didn't catch the price? Isn't it more aptly a modern Continental C-85? I think the "modern VW" as far as homebuilts go is one of the subaru's. Charles A lot of people seem to think that about the Suburu, but they weight quite a bit more than you'd think. The extra weight means a PSRU is really mandatory to get reasonable propeller output (HP/LB) - with all the attendent complexity, harmonic, and weight issues. In my mind that takes them out of the "modern VW" class. They seem to be more at home on the nose of RV/Tailwind class airplanes. Richard A lot of good points, and the radiator plumbing also seems to provide many happy hours of tinkering for a lot of folks. Actually, some of the small inline engines, such as those from the Geo/Chevy Metro, have shown some promise--which was unfortunately mixed with far too much hype. Actually, it the basic weight is anywhere near as light as was claimed, then a realistic power rating should work quite well. Regrettably, I have had no opportunity to weigh any of the engines in question. Peter |
#55
VW Reality
"Peter Dohm" wrote in message .. .
A lot of good points, and the radiator plumbing also seems to provide many happy hours of tinkering for a lot of folks. Actually, some of the small inline engines, such as those from the Geo/Chevy Metro, have shown some promise--which was unfortunately mixed with far too much hype. Actually, it the basic weight is anywhere near as light as was claimed, then a realistic power rating should work quite well. Regrettably, I have had no opportunity to weigh any of the engines in question. Peter One of our neighbors is flying a Geo Metro engine in his RagWing Special. Great sound and he loves it, very reliable (so far!) and simple key start... |
#56
VW Reality
"Ernest Christley" wrote in message
... cavalamb himself wrote: There was a Neiuport 12 project (two seater) published in Kit Planes a few years ago. He used a Yamaha engine and transmission - locked in second gear. (IIRC!) Real nice article about the airplane and engine. But no a mumblin' word about how the gearbox cratered a few hours into the test period. But, for Pete Sakes! Run a bike at 80% power continuously - in second gear(!) - what do you expect is going to happen? TANFL... George Graham ran a rotary conversion with the stock rotary manual transmission as a PSRU. It lasted a couple hundred hours before disintegrating (if I remember correctly). -- Actually, that makes a lot of sense. Reduction gear problems were explained to me, there are essentially two causes of uneven wear in a spur gear transmission; both of which lead to failure. The worse of the two occurs if the gear ratio allows some the teeth on each gear to transmit power more frequently than the others--a classic example would be a propeller shaft turning exactly half the speed of the crank shaft. The slower cause of uneven wear would occur whenever the driving gear is permanently oriented in the same relation to the crankshaft so that the same quadrants of the gear always transmit the power pulses--a condition that is normally avoided by the clutch, and can presumably be resolved by the installation of a centrifugal clutch. I don't personally know how the problem is usually solved in purpose built PSRU's and the only possibility that I find obvious is that the driving gear might be harder than the driven gear. That might slow the process, but the PSRU would still be a major component in calculating the TBO. Perhaps some here have experience in this area. Peter |
#57
VW Reality
On Feb 6, 8:03 am, Charles Vincent wrote:
Isn't it more aptly a modern Continental C-85? I think the "modern VW" as far as homebuilts go is one of the subaru's. Charles They're not the big solution, either. I installed a Subaru 2.2 litre on a Glastar, using an RAF redrive. The problems I encountered: -Some vibration at around 1400 engine RPM. Caused by the very light RAF aluminum flywheel, which doesn't absorb all that much pulsation, and this interacts with the prop's mass, which has a different resonance. We had initially used an Ivoprop, and could not balance it chordwise because the blades would shift a little on the hub bolts. The subsequent Warp Drive prop was better, but had much narrower chord and did not pull as well as the Ivo. Further, the Ivo's blades would flutter if there was too little tension on the torque rods. Scary. -Burned valves. The engine had a converted Holley two-barrel, with mixture control that was way too sensitive, to the point that it either ran or didn't. I modified the valve to get some range. On a short-field takeoff, usual SOP with an aircraft engine is to lean to max RPM with the brakes locked and throttle wide open; do that with the Soob and the valves will burn real quick. The engine has four valves per cylinder and they're about the size of the valves in a Briggs and Stratton lawnmower engine. Tiny, with little skinny stems. Compare them to a Lyc's valves. The 16-valve Soob was designed for computerized fuel injection, for good reason. -Couldn't install a mechanical fuel pump in it. No place for one. So, since you can't rely on gravity feed (the Holley has a small float valve designed for a 4 to 7 psi fuel pressure) you need an electric pump. Two of them, just in case. And the ignition is run off the aircraft's fuel system. So, since (as anyone with car or airplane mechanical experience knows) 90% of all engine problems are electrical, it's asking for trouble. Real quiet trouble. Avoiding that requires another battery and a big diode to protect it, more weight and complexity and cost and room that isn't there. -The engine was rated at 130 hp at 5600 RPM. The Glastar was designed for engines from 125 to 180 hp. Should be good enough, right? It was OK for takeoff and climb, but for cruise it was lousy. A Lycoming, redlined at 2700 RPM, is easily cruised at 2500 or even 2600. The engine is rated for 2700 continuous, if you want that. The Subaru, if you try to cruise it at an equivalent RPM of, say, 5300 or 5400, will wear out in no time flat and will burn phenomenal amounts of fuel, too. And makes the most awesome cabin noise. So you end up cruising at 4700 max, which gives an anemic cruise of 110 mph instead of the 135 that the Lyc 125 would give you. Both engines will give the claimed 143 mph at full RPM, so it's not a propeller pitch issue. -The exhaust system was two tiny mufflers that did little to contain the noise. There's no room under the heads, inside the cowl, since the engine sits low to get the thrust line up where it belongs. I could hear this airplane 7 miles away. When I flew it, I stayed away from town. -The engine compartment was very tight, once the radiator and its associated baffling was put in. The cooling system was the one thing I built that worked really well. The cabin heater was the Subaru's heater core. -The ultimate cost, in terms of the stupidly complicated engine mount I had to build and have professionally tigged (17 pieces of tubing and four special engine brackets), the time I spent, the constant tinkering, the cowling modifications necessary to make it fit, and the ultimately much lower resale value it had (half or less than a Lyc- powered Glastar), it just wasn't worth it. Dan |
#58
VW Reality
#59
VW Reality
On Feb 7, 3:42 pm, cavalamb himself wrote:
Dan! You are not going to sell magazines that way... Good thing I don't rely on magazine sales, huh? Funny, though. People are always asking me for my opinions on mechanical stuff. Sometimes they don't like the answers. Sometimes they want to buy an airplane, so I tell them what to look for and be aware of and be scared of and that the pretty airplane can clean out your bank account real fast. They don't like that because they want that airplane so bad. They buy it and find out I was right. Usually. I'm supposed to be working on my Hummelbird. That's why I asked Veeduber about the 1/2 VW, and he says they aren't so good. I believe that, and have to take it into account. Maybe, if I don't fly much, it'll be good enough, as long as I expect to be doing the valves every 50 hours or so. I have been warned, see. I 'm considering sticking the whole four-cylinder VW on it, like Bruce King did; a weight penalty, but a little less work expected from each jug. Sometimes we don't like the opinions of others. We need to evaluate the source, and if it's experienced in the matter at hand, we should shut up and listen. Even if it hurts magazine sales. Dan |
#60
VW Reality
wrote in message ... On Feb 7, 3:42 pm, cavalamb himself wrote: Dan! You are not going to sell magazines that way... Good thing I don't rely on magazine sales, huh? Funny, though. People are always asking me for my opinions on mechanical stuff. Sometimes they don't like the answers. Sometimes they want to buy an airplane, so I tell them what to look for and be aware of and be scared of and that the pretty airplane can clean out your bank account real fast. They don't like that because they want that airplane so bad. They buy it and find out I was right. Usually. I'm supposed to be working on my Hummelbird. That's why I asked Veeduber about the 1/2 VW, and he says they aren't so good. I believe that, and have to take it into account. Maybe, if I don't fly much, it'll be good enough, as long as I expect to be doing the valves every 50 hours or so. I have been warned, see. I 'm considering sticking the whole four-cylinder VW on it, like Bruce King did; a weight penalty, but a little less work expected from each jug. Sometimes we don't like the opinions of others. We need to evaluate the source, and if it's experienced in the matter at hand, we should shut up and listen. Even if it hurts magazine sales. Dan Dan: Totally agree. Being the Publisher of Experimental Helo magazine I had to address the problem of publishing ethics vs money. Ethics won out. Stu |
Similar Threads | ||||
HondaJet a reality | [email protected] | Piloting | 3 | July 28th 06 01:50 AM |
Pilot deviations and a new FAA reality | Chip Jones | Piloting | 125 | October 15th 04 07:42 PM |
Pilot deviations and a new FAA reality | Chip Jones | Instrument Flight Rules | 36 | October 14th 04 06:10 PM |
Reality of Tie Down (Tiedown) Space at SNA | Tie Town | Owning | 1 | May 6th 04 07:43 AM |
Reality of Tie Down (Tiedown) Space at SNA | Tie Town | Piloting | 1 | May 6th 04 07:43 AM |
