#11
Fatalities: Rentals vs Owned?
Interesting. I don't have any studies, but from a strictly maintenance
standpoint, I see things completely opposite. Every single rental aircraft I have flown is meticulously maintained, by certificated and qualified mechanics with factory training. I'm picky about what I fly. Well, with FBOs hurting to make a penny, I can vouch for the fact that they sometimes cut corners on maintenance to "keep 'em flying". My '75 Warrior was such a bird. This was my first plane, back in '98, and I bought it from a Wisconsin FBO who (unbeknownst to me at the time) was in the process of going belly up. We found all sorts of things wrong at the first annual, but the one that blew me away (and could have killed me) was the fact that they had not installed the proper length push-rods after replacing a cylinder. When the cylinder failed (again) after less than 100 hours, my mechanic found that that FBO simply had omitted the rotator cap, to make the (too long) push rod work. Obviously this is an extreme example, but I flew all sorts of rental birds before then that were, well, rough. Knowing what I know now, there are at least two that I should have refused to fly -- but I was inexperienced with maintenance matters, as are most renters. When you're a renter, you write stuff on a squawk sheet (if there *is* a squawk sheet), and hope for the best, never knowing what (if anything) is actually done. I've had throttle cables break on rentals, I've had doors not latch, I've experienced TWO complete electrical failures (in two different planes, from two different FBOs), and I once drained over a QUART of water from the tanks of a rental Cherokee. As for owners who cut corners, I guess it depends on what you mean by a "corner." If you mean installing a tractor light bulb instead of an "aircraft" light bulb, sure, I know LOTS of owners like that. But I don't know any owner who would cut a safety corner. I'm sure they're out there, but I haven't met them. I suppose there is no way to glean any kind of valid information from the accident reports, but it sure seems like the rental fleet in some markets is, at best, suspect. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
snip If you mean installing a tractor light bulb instead of an "aircraft" light bulb, sure, I know LOTS of owners like that. Well, that's illegal. And I'm coming from a work standpoint here, but you don't see mechanics doing that on transport catergory aircraft and engines. Why should GA owners feel they are exempt from the same rules? And I'll stop there before it turns into an EAA rant. but it sure seems like the rental fleet in some markets is, at best, suspect. Maybe I've just had good luck, but I've never seen it. |
Emily writes:
Every single rental aircraft I have flown is meticulously maintained, by certificated and qualified mechanics with factory training. But who knows where those aircraft have been, and how pilots have treated them when away from the eyes of their owners? For example, an airframe could be overstressed and not show any visible anomalies, until it fails. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Jay Honeck writes:
If you mean installing a tractor light bulb instead of an "aircraft" light bulb, sure, I know LOTS of owners like that. But I don't know any owner who would cut a safety corner. Why wouldn't a light bulb be important for safety? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Dudley Henriques writes:
I've seen operations that maintained their airplanes like a Swiss watch and many I wouldn't touch with a 10 foot pole. I've seen owners who maintained perfectly and owners whose airplanes I absolutely would not fly. Is it a question of will, or a question of money? -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Sun, 22 Oct 2006 09:31:55 +0200, Mxsmanic wrote:
Emily writes: Every single rental aircraft I have flown is meticulously maintained, by certificated and qualified mechanics with factory training. But who knows where those aircraft have been, and how pilots have treated them when away from the eyes of their owners? For example, an airframe could be overstressed and not show any visible anomalies, until it fails. Same argument could be made for *any* airplane...you don't know what the previous owner did to it. But there are admittedly more people who have previously flown a renter than a used plane. To quote myself, "Renting airplanes is like renting sex: It's harder to arrange at short notice on Saturday, you worry about what previous customers left for you, and someone is always looking at their watch." Ron Wanttaja |
On Sun, 22 Oct 2006 09:35:12 +0200, Mxsmanic wrote:
Jay Honeck writes: If you mean installing a tractor light bulb instead of an "aircraft" light bulb, sure, I know LOTS of owners like that. But I don't know any owner who would cut a safety corner. Why wouldn't a light bulb be important for safety? Some are, some aren't. A landing light, for instance, is not required for night flight. I've flown my plane at night, and it doesn't have one. Heck, it doesn't have instrument lights, either... I used a chemlight. If it *did* have a landing light, I'd feel no compunction about using a tractor bulb instead. If one ain't required, there's no reason to get all formal about it. It would at least feel at home with all the other "Aircraft and Tractor Supply Company" and "Home Depot Aerospace" parts on board.... :-) Ron Wanttaja |
Ron Wanttaja writes:
Same argument could be made for *any* airplane...you don't know what the previous owner did to it. If it has a previous owner ... but a brand-new plane does not. But there are admittedly more people who have previously flown a renter than a used plane. If they are anything like rental cars or other rental equipment, they may be in very sorry shape. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Sun, 22 Oct 2006 10:27:39 +0200, Mxsmanic wrote:
Ron Wanttaja writes: Same argument could be made for *any* airplane...you don't know what the previous owner did to it. If it has a previous owner ... but a brand-new plane does not. The average General Aviation aircraft is more than 30 years old. A new plane requires a cash outlay an order of magnitude higher. And *no* buyer is the very first person to fly the aircraft. Not all ferry pilots are as genteel as NW_Pilot. :-) But there are admittedly more people who have previously flown a renter than a used plane. If they are anything like rental cars or other rental equipment, they may be in very sorry shape. With one exception, the rental cars I've driven have been in pristine shape, compared to the clapped-out 172s I rent every two years for my BFR. I've never had a rental car more than a year old, haven't had a rental airplane less than ten years old for at least the last 20 years. My last two personal cars were bought used from the rental agencies. Both went to 100K miles with few problems (GM cars, even). (The rental-car exception was a Toyota rented at a location which had mostly gravel roads. The rental agreement required that I clean any blood out of the trunk before turning it back in....no, it wasn't New Jersey :-) Ron Wanttaja |
Ron Wanttaja wrote:
Some are, some aren't. A landing light, for instance, is not required for night flight. unless of course you are operating it for hire as required by 14 CFR 91.205(c)(4) --Sylvain |
Similar Threads | ||||
Florida Rentals | Arnold Sten | Piloting | 0 | December 14th 04 02:13 AM |
Wreckage of Privately Owned MiG-17 Found in New Mexico; Pilot Dead | Rusty Barton | Military Aviation | 1 | March 28th 04 10:51 PM |
Deliberate Undercounting of "Coalition" Fatalities | Jeffrey Smidt | Military Aviation | 1 | February 10th 04 07:11 PM |
Rentals in Colorado | PhyrePhox | Piloting | 11 | December 27th 03 03:45 AM |
Rentals at BUR | Dan Katz | Piloting | 0 | July 19th 03 06:38 PM |
