#11
iPhone in a glider?
"Martin Gregorie" wrote in message ... On Fri, 19 Sep 2008 10:25:42 -0500, Michael Ash wrote: Anyone know more about it? I'd like to know more than my patchwork memory.... In the UK, anyway, the base station transmission patterns are quite flat which can stop you getting a signal in the air. A year or two back I wanted to annoy a friend with the "ring him and hold phone by the audio vario" trick, but at 3000ft over Huntingdon, i.e. above a flat bit of Cambridgeshire, there was no signal at all. I was using a GSM phone, so the radiation pattern was evidently flat enough the exclude not only Huntingdon masts but also those further away (Cambridge, Northampton). This makes sense to me. Why should a telco waste electricity transmitting a hemispherical pattern when a pancake pattern will give a better signal strength for less radiated power throughout its service area. IIRC this has been noticed and commented on in the USA too. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | My experience with Verizon in the US is that it usually works fine from a glider. I used it once to call a tower after my radio failed - but they didn't answer. They later told me that they couldn't take time to answer the ringing phone, "because there was some guy in a glider with an inoperative radio" they had to deal with. Instead they just shot me a green light and I landed. |
iPhone in a glider?
On Sep 19, 8:25*am, Michael Ash wrote:
Alan wrote: I just took my new 3G for a flight. gpstracker application works very well to track flights on google earth. Also gives Long/Lat speed as well as altitude every 5 seconds. Check it out. *It might be fun, but it is also quite illegal. *47 cfr 22.925 states: * * 22.925 * Prohibition on airborne operation of cellular telephones. [snip] Aside from the use of "airplane mode", I seem to recall a discussion about this a while ago wherein it was concluded that modern mobile phones don't meet the FCC's definition of a "cell phone". The reasoning behind this regulation is that using a cell phone in flight plays merry havoc with the cell network due to seeing towers farther away than the network is designed for. But modern networks work differently and are immune to this problem, and I *think* the conclusion was that the regulation does not apply to them. Anyone know more about it? I'd like to know more than my patchwork memory.... -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon As pilot in command of a non-IFR flight I grant myself permission to use all kinds of electronic toys in flight. So that gets rid of FAA concerns. However my belief is that 47 CFR. 22.925 does apply to the iPhone since it is quad-band GSM that uses the GSM 850MHz band in the USA. If you have say a different brand PCS phone that exclusively uses 1800MHz then this would not apply to you. There is a wiki entry about this at http://en.wikipedia.org/wiki/Mobile_phones_on_aircraft In reality I turn my phone off to save battery life and distractions like the phone ringing while I'm on final (it's happened). So would I really want some new soaring software running on an iPhone? Sure I could see lots of neat UI things that could be done (Cocoa is a lovely UI to develop for) and the platform is powerful etc. The screen is a bit more visible in sunlight than most PDA screens, but it is still not really great. The downside of that is I'm set in my ways with SeeYou, so if Naviter wanted to port across SeeYou keeping some of it's core behavior/feature but offering an updated Cocoa UI/feel then I might be interested. Except for a few issues... I'm not going to use anything that does not talk to an external flight computer, e.g. for extended NEMA sentences for improved wind calculations etc. and I want to be sure my IGC logger is working OK so getting the GPS from it is a way to test this. Also I really don't want to mess with my iPhone as the display device in my glider, it's my phone that gets messed with a lot. But I'd be happy to dedicate an iPod Touch to this - in which case since it has no GPS you really need an external interface. Unfortunately the iPhone SDK does not give access to the serial port, and even if you had access to the serial port you will need some RS-232 line driver hardware to shift voltages to interface with a real RS-232 serial port in the GPS. The fact that Apple did not include that in the iPhone makes me think they really don't want to expose the serial port. The iPhone has bluetooth but does not support a serial profile, so you can't connect to a bluetooth GPS, or try to run a serial-bluetooth convertor on a flight computer serial port etc. over bluetooth. And it's just a USB slave (like a PDA) so you can't use a USB to serial translator. Then there is the issue of no way to use a CF or SD card or USB dongle etc. for flight log transfers and there is no third party code to run on it to download flight traces from loggers etc. Sure something like ConnectMe could be ported over (oops if there was just access to that danged serial port), oh and opps there is no file management UI in the iPhone so doing things nice and easily with log files etc. will be clumsier than it should). You could use or implement something like FileMagnet or DataCase and transfer log files over WiFi (of course that requires a WiFi setup), or email the file, otherwise you are going to stuck emailing file attachments or having to sync the iPhone to get off any log files. As it currently stands Apple's iPhone SDK license agreement has the restrictions mentioned already in this thread "Applications may not be designed or marketed for real time route guidance; automatic or autonomous control of vehicles, aircraft, or ..." (it is the real time route guidance that likely gets us, the "aircraft" stuff is irrelevant since we are not talking about an automatic or autonomous control". This restriction is in the SDK agreement, not just the iTunes store, so the only way around this is to use a non-Apple SDK with a jail broken phone. Then you are (questionably) violating other agreements. For anybody to put serious effort into developing such software, even if they wanted to open source it or give away binaries I doubt there is a significant enough "market" in jail broken 3G iPhones and their owners who want to put up with this. And while distributing through the AppStore is neat, it has some serious pain in the ass issues for higher end applications, starting with customer support say worthy of 0.99c applications. If somebody was serious and could get around the serial I/O and other issues then they could try talking to Apple, they might agree to modify route guidance restriction for a specific application (but don't hold your breath). Darryl |
iPhone in a glider?
In reality I turn my phone off to save battery life and distractions like the phone ringing while I'm on final (it's happened). I do now. I was on short final when my wife decided to call me. My student did a double take and said "what the f...?". The name of my ring tone is "vario rising". Tony V. |
iPhone in a glider?
On Sep 18, 1:32*am, "Matt Herron Jr." wrote:
Come up with some good ideas, and maybe I will implement one! How about porting GlidePlan? Or a nice user friendly sectional chart viewer? Unless someone comes up with moving map software that can display CURRENT sectional chart information, I'll still need to carry paper charts. What I do now, is use GlidePlan to print up a 60% 'booklet' of the charts I plan to fly with. I forget the actual percent shrinkage, but it's just small enough so one side of the chart fits on a portrait sized 8.5x11 sheet of paper. I then use 20% page overlap, so I'm always looking near the middle of a page. The text is pretty small, but still just barely legible so I can pick up any needed frequencies, etc. The viewer program should provide pan and zoom functionality as well as an automated switch to the next chart as one scrolls off the edge. It should use the GPS to select the right chart, as well as have a database of airports & cities, so I could enter such and the proper chart will be displayed and centered on that location. -Tom Who has ATT service with a 5 month old Samsung BlackJack that's way too dim to use for color apps in sunlight. |
iPhone in a glider?
On Sep 20, 3:34*am, Michael Ash wrote:
Bruce Hoult wrote: The main problem is the risk. It *shouldn't* apply to an aviation application, but the only way to really find out is to actually build the app, submit it, and see if they let it through. If they don't, that's a lot of work potentially lost. Not lost. If you make your plans based on surviving using distribution independent of Apple then you can submit to the AppStore and see what happens. If you get in then bonus. The PodCaster guys are reportedly doing brisk business despite not being in the AppStore. |
iPhone in a glider?
On Sep 19, 5:53*pm, Bruce Hoult wrote:
On Sep 20, 3:34*am, Michael Ash wrote: Bruce Hoult wrote: The main problem is the risk. It *shouldn't* apply to an aviation application, but the only way to really find out is to actually build the app, submit it, and see if they let it through. If they don't, that's a lot of work potentially lost. Not lost. *If you make your plans based on surviving using distribution independent of Apple then you can submit to the AppStore and see what happens. *If you get in then bonus. The PodCaster guys are reportedly doing brisk business despite not being in the AppStore. The Podcaster guys sell a ~$10 application that Apple can apparently turn off at any time. The logic why they don't just submit through the iTunes store is questionable. This is not just an issue if you want to distribute through the store, it's a base restriction in the SDK. Anybody wanting to put real effort into doing this is going to want to sort this out before building the application. Then it's a closed system and you are always pretty much at Apple's mercy. Which I assume Bruce is used to thinking about - since if his product is doing Java compilation then unless you've got a deal with Apple that software is going to run up against the "other executable code"/interpreted languages restriction in the SDK agreement... ....Just to hammer this to death I disagree that the comment that the ecosystem of distributing apps for the iPhone is like other mobile device. The iPhone is designed to be a closed system. But hey it's a very pretty closed system. The App store infrastructure is nice for low margin micro-applications (and why others like Microsoft are running to catch up) but has more issues for serious applications. Like the software vendors inability to very rapidly patch things, Apple being able to make fairly arbitrary decisions, etc. etc. But again, I'd claim there are practical restrictions today that probably are showstoppers for a serious application... no I/O over serial port, bluetooth or USB, no CF/SD card, no file system/file UI, ... Of all these I'd hope that Apple would add a serial profile to bluetooth and a (limited) filesystem like UI in future. Darryl |
iPhone in a glider?
Bruce Hoult wrote:
On Sep 20, 3:34?am, Michael Ash wrote: Bruce Hoult wrote: The main problem is the risk. It *shouldn't* apply to an aviation application, but the only way to really find out is to actually build the app, submit it, and see if they let it through. If they don't, that's a lot of work potentially lost. Not lost. If you make your plans based on surviving using distribution independent of Apple then you can submit to the AppStore and see what happens. If you get in then bonus. Well, that's why I said "potentially", since the end result depends on your planning and your market. For a small, cheap app you really lose out, but a more specialized expensive app is in a better position to use alternative venues. The PodCaster guys are reportedly doing brisk business despite not being in the AppStore. Not sure how it compares to being in the official store, though, particularly in the long run. And it's a *lot* more work for them the way they're currently doing it. Every customer has to be manually added through Apple's rather cumbersome tools (because they're not meant for this) and this may have to be re-done for every update they release, I'm not sure on that point. However this is considerably less of an issue for specialist soaring software. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
iPhone in a glider?
Darryl Ramm wrote:
The Podcaster guys sell a ~$10 application that Apple can apparently turn off at any time. The logic why they don't just submit through the iTunes store is questionable. Perhaps I'm misunderstanding you, but they did submit through the store and were rejected, and for rather questionable reasons. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
iPhone in a glider?
On Sep 19, 8:16*pm, Michael Ash wrote:
Darryl Ramm wrote: The Podcaster guys sell a ~$10 application that Apple can apparently turn off at any time. The logic why they don't just submit through the iTunes store is questionable. Perhaps I'm misunderstanding you, but they did submit through the store and were rejected, and for rather questionable reasons. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon Oops, sorry your completely correct, I had a brain fade. Yes Apple trying to protect the iTunes WiFi store podcast downloads they don't support! Darryl Darryl |
iPhone in a glider?
In article Darryl Ramm writes:
As pilot in command of a non-IFR flight I grant myself permission to use all kinds of electronic toys in flight. So that gets rid of FAA concerns. Sounds good. It has long worked for me, too. However my belief is that 47 CFR. 22.925 does apply to the iPhone since it is quad-band GSM that uses the GSM 850MHz band in the USA. If you have say a different brand PCS phone that exclusively uses 1800MHz then this would not apply to you. Perhaps not, because some call those PCS instead of cellphones, but I don't know what the FCC's reaction would be. I would not want to be explaining it when they are pointing out some definition in another part of the rules that says cell phone covers both... I'm not going to use anything that does not talk to an external flight computer, e.g. for extended NEMA sentences for improved wind calculations etc. and I want to be sure my IGC logger is working OK so getting the GPS from it is a way to test this. Also I really don't want to mess with my iPhone as the display device in my glider, it's my phone that gets messed with a lot. How true. A well integrated system could reduce pilot workload and increase safety. The iPhone is cute, and a system one could use on the ground to play with would be fun, but it really doesn't fit well into a fully integrated flight and nav computer. Alan |
Similar Threads | ||||
iPhone and /G | A Guy Called Tyketto | Piloting | 2 | June 17th 08 12:01 AM |
iPhone and /G | A Guy Called Tyketto | Instrument Flight Rules | 2 | June 17th 08 12:01 AM |
iPhone in the air | Ramy | Soaring | 2 | June 3rd 08 12:03 AM |
IPhone On gliders? | Mitch[_2_] | Soaring | 0 | February 26th 08 08:14 AM |
E6B for iPhone? | C J Campbell[_1_] | Piloting | 16 | September 27th 07 03:54 AM |
