Understanding fuel servo maintenance
Old November 21st 06, 06:17 PM posted to rec.aviation.piloting,rec.aviation.owning
Mark Hansen
Default Understanding fuel servo maintenance
On 11/21/06 09:23, Robert M. Gary wrote:
[ snip ]
I just need to know that its not going to need to be adjusted again
while I'm flying over the Sierras. I like to fly to some very remote
areas of Mexico. Taking a 2 week donkey ride back to the states through
the desert isn't appealing.
I hear you can ride on the tops of trains ;-\
-Robert
Old November 22nd 06, 09:22 PM posted to rec.aviation.piloting,rec.aviation.owning
Robert M. Gary
Jon Kraus wrote:
10 hours? And you said OK to that? I was hoping you were a little
smarter than that ;-)
We had our servo replaced at annual and were charged 2 hours for the
R&R.
Just curious, did you already have the lower cowl dropped during the
R&R? If you went through the lower cowl vs. removing the intake stacks
I usually get charged 3 hours just to drop and return the lower cowl. I
can usually do it myself but it takes me 4-5 hours myself.
-Robert
Old December 17th 06, 12:44 PM
Randolph Sumner Randolph Sumner is offline
Junior Member
First recorded activity by AviationBanter: Dec 2006
Quote:
Originally Posted by Robert M. Gary
The fuel shop fixed my fuel servo by replacing the spring that holds
the fuel regulating diaphragm. The tech said the previous spring was
very stiff and he replaced it with one that was softer. Does that
indicate that the previous spring was broken (i.e. stiffer than it
should have been) or does Lycoming (Airmotive really) have a variety of
springs for adjustment purposes?? Did they fix the problem or just
adjust the fuel servo to work "post-problem".
-Robert, IO-360-A3B6
I just got my 2001 Cessna 172SP with 350 hours on it back from annual and paid 2K for a fuel servo overhaul noted as fuel stain around the control arm connectors. My A&P at a busy high end facility called Lycoming for an explanation for the reason for a gummed up low time Servo and was told it was overpriming. I never prime over 3 sec which is POH.The only performance issue was some subtle power loss but this issue can cause engine failure/shutdown. I am going to call the overhaul facility for their rendition of this but it is a very under reported issue and hard to diagnose short of an annual.I do not know about the spring issue but these servos obviously have some insidious degradation problems.Since your life depends on it, I would have it overhauled and then watch this carefully and maybe have some one pull it or look up into the throttle body with a scope at each annual to be sure there is no recurring gum up since this cannot be seen from outside til late in the game.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Jet fuel A-1 specific gravity [email protected] Piloting 7 May 20th 06 04:39 PM
"Out of fuel, out of hope: 'Help, I'm in the water'" [email protected] Piloting 145 May 3rd 05 11:21 PM
