Weak link - single or reserve?
On Fri, 18 Jan 2008 16:16:22 GMT, "Malcolm Austin"
wrote: At our club (Denbigh GC, UK) we changed the steel wire for a type of polypropylene rope. The shock absorbing properties of this have reduced the incidence of weak link breaks to almost zero. I know of a club that also used a polypropylene rope between aircraft and weak link. They stopped using that after this rope got entangled within the gear of an ASK-21, leading to a severe ground loop immediately prior to lift-off. The stiffness of the steel wire prevents such an event. Bye Andreas |
Andreas,
I agree that would seem to be a problem for that location. But I have not seen it arise for the main winch rope. We do use a 15 metre length of stiffer and thicker rope after the main winch rope which also might help counteract that. The cost and wear properties on our grass strip, plus the almost complete lack of winch failures is a real plus. Even nicer is the handling side for the winch man. It's 100% safer and we get no cut fingers. A repair (splice) can be carried out in a few minutes with a pen knife and some tape to cover the 3 ends of the rope. The section closest to the winch suffers the most wear, but this is easily and quickly replaced and minimal cost.Also the guide rolls on the winch after about 8 months of use show zero wear. I drive the winch every few weeks and after the 18 months of so of usage I would hate to go back to steel. And as said before the amount of weak link failures is virtually nil now. Cheers, Malcolm... "Andreas Maurer" wrote in message ... On Fri, 18 Jan 2008 16:16:22 GMT, "Malcolm Austin" wrote: At our club (Denbigh GC, UK) we changed the steel wire for a type of polypropylene rope. The shock absorbing properties of this have reduced the incidence of weak link breaks to almost zero. I know of a club that also used a polypropylene rope between aircraft and weak link. They stopped using that after this rope got entangled within the gear of an ASK-21, leading to a severe ground loop immediately prior to lift-off. The stiffness of the steel wire prevents such an event. Bye Andreas |
On Jan 18, 5:04*pm, Andreas Maurer wrote:
On Fri, 18 Jan 2008 16:16:22 GMT, "Malcolm Austin" wrote: At our club (Denbigh GC, UK) *we changed the steel wire for a type of polypropylene rope. *The shock absorbing properties of this have reduced the incidence of weak link breaks to almost zero. I know of a club that also used a polypropylene rope between aircraft and weak link. They stopped using that after this rope got entangled within the gear of an ASK-21, leading to a severe ground loop immediately prior to lift-off. The stiffness of the steel wire prevents such an event. That's partly why the strops our weak links are attached are inside some kind of plastic tube. I have a feeling the BGA recommends this but I can never find stuff on their website, so don't know if I'm imagining that. |
On Fri, 18 Jan 2008 16:13:36 -0800 (PST), Cats
wrote: That's partly why the strops our weak links are attached are inside some kind of plastic tube. I have a feeling the BGA recommends this but I can never find stuff on their website, so don't know if I'm imagining that. If you need some written arguments: The German SBO explicitly demands a stiffened rope between glider and weak link. See here (if you speak German): http://www.daec.de/se/downfiles/sbo.pdf Bye Andreas |
On 19 Jan, 00:13, Cats wrote:
That's partly why the strops our weak links are attached are inside some kind of plastic tube. I have a feeling the BGA recommends this but I can never find stuff on their website, so don't know if I'm imagining that. http://www.gliding.co.uk/forms/clubm...t/winchops.pdf and http://www.gliding.co.uk/bgainfo/doc...chguidance.pdf Finding stuff on the site is a pain, especially since the search facility is useless! Ian M |
At 15:48 18 January 2008, Andreas Maurer wrote:
- weak links that impact tarmac after release are more prone to fail Install weak links within an equivalent length of narrow steel channel (with a hole at one end and a slot at the other) as protection from wear/impact damage. |
On 18 Jan, 23:23, Z Goudie
wrote: At 15:48 18 January 2008, Andreas Maurer wrote: - weak links that impact tarmac after release are more prone to fail Install weak links within an equivalent length of narrow steel channel (with a hole at one end and a slot at the other) as protection from wear/impact damage. I thought that was part of the standard Tost kit. Ian |
At 00:18 19 January 2008, Cats wrote:
The stiffness of the steel wire prevents such an event. That's partly why the strops our weak links are attached are inside some kind of plastic tube. I have a feeling the BGA recommends this but I can never find stuff on their website, so don't know if I'm imagining that. From the BGA website http://www.gliding.co.uk/forms/lawsandrules.pdf Page 52, RP (Recommended Practice) 7 Gavin Std Cirrus, CNN now G-SCNN, #173 |
At 10:36 19 January 2008, Ian wrote:
I thought that was part of the standard Tost kit. Use a SERIOUS piece of steel channel! |
"Z Goudie" wrote in message ... At 10:36 19 January 2008, Ian wrote: I thought that was part of the standard Tost kit. Use a SERIOUS piece of steel channel! I'm pretty familiar with steel channel shapes and I don't know of one I'd use for this purpose. The Tost stainless steel 'envelope' does a great job of protecting the 'dogbone' weaklinks. It's unlikely you will wear one out in less than 5 - 10 years. Get the official one - they're worth the money. On this subject, the Tost winch line hardware is very, very good and well thought out. Use it for a while before trying to experiment. Bill D |
Similar Threads | ||||
OLC - 2008 - DO NOT USE 2007 URL LINK, or current ssa.org link | [email protected] | Soaring | 1 | October 25th 07 05:37 PM |
IFR w/pax under Single-Pilot/Single Aircraft 135 | Bravo8500 | Owning | 20 | March 9th 05 09:37 PM |
Weak link for PW-5 | Nyal Williams | Soaring | 4 | June 1st 04 08:46 AM |
Weak link for winch launch - 1-26E??? | Mark Zivley | Soaring | 4 | April 29th 04 11:38 PM |
Blanik Weak Link for Winch Launch??? | Gary Emerson | Soaring | 6 | February 24th 04 08:08 PM |
