Glider Batteries and Chargers
Old August 24th 10, 03:03 PM posted to rec.aviation.soaring
Grider Pirate
Default Glider Batteries and Chargers
VSLA? A123? Cycling chargers?? I think this subject should have it's
own thread. Unlike transponders, we almost all need them.
Old August 24th 10, 03:59 PM posted to rec.aviation.soaring
T8
On Aug 24, 10:03*am, Grider Pirate wrote:
VSLA? A123? Cycling chargers?? *I think this subject should have it's
own thread. *Unlike transponders, we almost all need them.
Powersonic batteries. Battery Tender Plus charger. Bullet proof,
inexpensive. Excellent technical info available at both
manufacturers' websites.
I like the Battery Tender Plus because it is a reasonable size
capacity three mode charger that also includes a 6 hour limit on
absorption mode. If you read the tech info on those two sites, you'll
understand why that might be a good thing. That charger will safely
and correctly charge almost any 12V AGM battery from about 5 AH up.
The Powersonic chargers also work great, but need to be matched to
battery capacity, making them less universal.
More exotic and expensive solutions work also, but unless you need
more than 14 AH capacity or have weight or space constraints I don't
see it as worth the bother. Of course, some people just like
exotica... nothing wrong with that.
-Evan Ludeman / T8
Old August 24th 10, 04:14 PM posted to rec.aviation.soaring
T8
One other thing... DO include a fuse or circuit breaker at the battery
and do make certain that the connections between the CB and the
battery are absolutely as reliable as you can make them (as mentioned
on another thread, problems here aren't covered by your CB). I
recommend a 5 amp push to reset CB, provided that you have some place
to mount it correctly, teflon insulated aircraft wire of 18ga and
Molex or equivalent industrial quality crimp on connectors which are
*far* better than consumer grade stuff at your hardware store. This
is a great area to solicit some help if you aren't completely
confident in your ability.
That's my public service announcement for the day :-).
-T8
Old August 24th 10, 04:39 PM posted to rec.aviation.soaring
rlovinggood
on another thread, problems here aren't covered by your CB). *I
*far* better than consumer grade stuff at your hardware store. *This
-T8
And Evan, why do we put fuses on the batteries and why do we use
aircraft wire? I wonder if the aircraft in the following report had
a fused battery and aircraft wire?
http://www.ntsb.gov/ntsb/brief.asp?e...01X51612&key=1
Ray Lovinggood
Carrboro, North Carolina, USA
Old August 24th 10, 04:58 PM posted to rec.aviation.soaring
T8
-T8
aircraft wire? * I wonder if the aircraft in the following report had
Ray Lovinggood
Yeah, there's one convert, for sure!
Btw, if anyone wonders where to get them, McMaster Carr is a good
source of Molex connectors and crimp on terminals. Get a good quality
crimper and a wire stripper while you are at it. They also sell
teflon insulated wire. Mouser Electronics is another source for good
quality electrical bits, including circuit breakers (but not teflon
wire IIRC). Some of the glider supply guys have a pretty good
selection of stuff too.
-Evan Ludeman / T8
Old August 25th 10, 02:16 PM posted to rec.aviation.soaring
-T8
Ray Lovinggood
We put the fuse right at to the battery so there is never a high
current running through the rest of the circuitry.
Wire short anywhere- fuse blows.
This simple protection prevents having to deal with the consequences
of many sins, including the PVC insulated wire many production gliders
are incorporating.
This is a simple and very useful safety enhancement which costs about
$3 and takes 20 minutes to accomplish.
Unless something falls on the battery terminals, you're pretty well
covered.
FWIW
UH
Old August 25th 10, 02:01 AM posted to rec.aviation.soaring
Donald S Brant Jr
recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors
-T8
For any battery connections I highly recommend Anderson Powerpole
connectors: http://www.andersonpower.com/product...onnectors.html.
They are hermaphorditic (sexless) and are being used as a defacto
standard in the Amateur Radio community for battery connections. This
article:
http://www.westmountainradio.com/supportrr.htm gives details on their
application. There was a recent article in one of the ham magazines
discussing their advantages over
Molex-type connectors. The use of 30-amp size connectors has been
suggested as standard due to their rugged construction and low contact
resistance.
Don.
Old August 25th 10, 02:25 PM posted to rec.aviation.soaring
-T8
connectors:http://www.andersonpower.com/product...onnectors.html.
standard in the Amateur Radio community for battery connections. *This
article:http://www.westmountainradio.com/supportrr.htmgives details on their
application. *There was a recent article in one of the ham magazines
Molex-type connectors. *The use of 30-amp size connectors has been
resistance.
Don.
We also use Powerpoles for the same reason. They will take much more
abuse than Molex connectors and have virtually no power loss. Can get
them at any hobby shop that handles RC cars. Note these are not hobby
products, they are industrial connectors.
UH
Old August 25th 10, 03:28 PM posted to rec.aviation.soaring
T8
-T8
article:http://www.westmountainradio.com/sup...tmgivesdetails on their
resistance.
Don.
UH
I'll have to check these out.
FWIW, my Molex recommendation was intended for the spade lug
connectors that attach directly to the battery -- these are bullet
proof. I agree that the Molex disconnects are a little light duty.
-T8
Old August 24th 10, 04:17 PM posted to rec.aviation.soaring
Grider Pirate
Powersonic batteries. *Battery Tender Plus charger. *Bullet proof,
inexpensive. *Excellent technical info available at both
understand why that might be a good thing. *That charger will safely
see it as worth the bother. *Of course, some people just like
-Evan Ludeman / T8
Hmm, that's EXACTLY what I use in my motorcycle! I'll have to see if
the Battery tender will deal with my 14v (10ah) glider battery.
Still interested in Lithium batteries for your glider? Eric Greenwell Soaring 5 March 5th 05 02:32 PM
Battery Chargers Stan Amyett Soaring 2 March 12th 04 05:27 AM
Battery Chargers Mike Rapoport Owning 11 December 2nd 03 11:55 PM
Rechargable AA batteries and chargers TripFarmer General Aviation 2 October 17th 03 06:34 PM
Rechargable batteries and chargers....... TripFarmer Products 2 October 17th 03 06:31 PM
