#21
"Steven P. McNicoll" wrote: Separation between participating VFR and IFR aircraft in the outer area is the same as within the Class C airspace proper; target resolution, 500 feet vertical, or visual. Can you tell me a little more about what that means? Does "or visual" mean that adequate clearance exists when both planes have visual contact and miss each other? George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
A Lieberman wrote: If it was me deciding, I'd blame the pilot. Sounds like he launched into IFR conditions. Dan later said the airport is BFM. That's on Mobile bay. Cloud conditions are usually odd along coastlines. George Patterson Battle, n; A method of untying with the teeth a political knot that would not yield to the tongue. |
"G.R. Patterson III" wrote in message ... Can you tell me a little more about what that means? Does "or visual" mean that adequate clearance exists when both planes have visual contact and miss each other? Only one aircraft has to sight the other one to use visual separation, the other one just has to be informed that visual separation is being used. There is no minimum distance in visual separation, it's whatever the pilot is comfortable with. |
#24
I'd wager the local MVA is 2200'. I'll try to find out. |
#25
G.R. Patterson III wrote:
Dan later said the airport is BFM. That's on Mobile bay. Cloud conditions are usually odd along coastlines. A while back, I departed a beautiful and otherwise-clear ACK right into a big mucking cloud sitting on runway heading. The VFRers were taking a quick turn to stay VMC, but I used this as a good excuse to get my wife into the clouds for the first time (but brief enough that she'd no need to be concerned). [I needn't have worried. Her major concern was getting the trip on video.] - Andrew |
Similar Threads | ||||
cleared, then busted | virga | Piloting | 88 | January 22nd 05 07:43 PM |
Want KLN 88-90 Parts Unit -- Sell that busted unit | Bill Hale | Aviation Marketplace | 0 | June 16th 04 07:16 PM |
Busted IFR Checkride | Jon Kraus | Instrument Flight Rules | 77 | May 4th 04 02:31 PM |
rec.aviation.questions is busted | Dan Jacobson | General Aviation | 2 | November 18th 03 05:39 PM |
Help - I busted into the Class B SEATAC airspace last night, does anyone have any advice ? | steve mew | Piloting | 38 | October 28th 03 06:08 PM |
