MP / FF guage slow to respond
Old May 16th 04, 08:25 PM
Steve
Default MP / FF guage slow to respond
my manifold pressure gauge is being really slow to respond - was just
wondering if there is something I should look at before just replacing it.
we blew out the lines at the last inspection and also checked the lines for
any leaks. Has the guage just gone bad ? also - would it be better to send
it in for service or just replace it ?
Steve
Old May 17th 04, 04:33 PM
Michelle P
Steve,
is the engine running normally? You may have a cracked line. There may
be moisture in the line as well.
Michelle
Steve
Michelle P ATP-ASEL, CP-AMEL, and AMT-A&P
"Elisabeth" a Maule M-7-235B (no two are alike)
Volunteer Pilot, Angel Flight Mid-Atlantic
Volunteer Builder, Habitat for Humanity
Old May 17th 04, 11:27 PM
Steve
On a lot of 'em, removing the inlet fitting will expose an adjustment
screw. This screw is turned in and out to vary the damping effect of
the adjustable orifice.
The screw can be carefully removed (counting the number of turns) and
the crud cleaned off/out of it.
TC
Deployments Slow Fire Training For Military Pilots Otis Willie Military Aviation 0 July 8th 04 12:19 AM
Deployments Slow Fire Training For Military Pilots Otis Willie Naval Aviation 0 July 8th 04 12:19 AM
Why were the George and Jack so slow? old hoodoo Military Aviation 3 December 10th 03 02:01 AM
Posting problem-plese Respond Nele_VII Military Aviation 2 December 7th 03 06:26 AM
Refurbishing indicator guage faceplates Merle Wagner Home Built 2 August 20th 03 05:18 AM
