PDA touch-screen failure at 8000 feet?
Old September 24th 05, 05:21 AM
John Clonts
Default PDA touch-screen failure at 8000 feet?
I use my Sony Clie TJ37 a lot, but rarely while flying. The other day I tried to use it at 8000 feet and the
touch screen was very unresponsive. I could *sometimes* get a click to register but I had to press very hard
or "whack" it with the stylus. Back on the ground it works fine. Anybody have any similar experience, either
GA or airline (cabin alt== 8000 feet)?
I have heard of bad effects of altitude on hard disks, but it's hard to imagine such an effect on a touch
screen!
Cheers,
John Clonts
Temple, Texas
N7NZ
Old September 24th 05, 05:30 AM
Newps
I have a Dell Axim X50v, never had a problem on airline flights. I'll
have to climb high in the Bo and see if that does anything.
Old September 24th 05, 01:16 PM
John T
"John Clonts" wrote in message
day I tried to use it at 8000 feet and the touch screen was very
to press very hard or "whack" it with the stylus. Back on the ground
it works fine. Anybody have any similar experience, either GA or
No, my current iPAQ hx4700 and older 3955 screens work fine at 9000' (the
highest I've used them in a plane).
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
Reduce spam. Use Sender Policy Framework: http://spf.pobox.com
____________________
Old September 24th 05, 03:36 PM
Paul kgyy
Had my Ipaq 5550 up to 13.5 a while back, no problem.
Old September 25th 05, 07:10 PM
rod
Probably tiny (invisible) air bubbles between layers of your screen. As you
decrease ambient air pressure these bubbles expand and push the layers
farther apart. That's why you have to press harder to make an impression.
Rod
more radial fans like fw190? jt Military Aviation 51 August 28th 04 04:22 AM
Hiroshima/Nagasaki vs conventional B-17 bombing zxcv Military Aviation 55 April 4th 04 07:05 AM
Use of 150 octane fuel in the Merlin (Xylidine additive etc etc) Peter Stickney Military Aviation 45 February 11th 04 04:46 AM
Ta-152H at low altitudes N-6 Military Aviation 16 October 13th 03 03:52 AM
