Jet fuel has a larger nozzle. I don't know whether you can fuel a gas 172
with the larger nozzle. I know at one time Beech was trying to get restrictors in the openings of Bonanzas. -- Cy Galley Editor, EAA Safety Programs or "Big John" wrote in message news Cy Wonder how they are going to prevent miss-fueling 172's with two types of engines? Have different nozzles like used for unleaded gas in automobiles or??????????? If I had a 172 with a Lyc or Con, I'd stand and watch each fueling to be sure I got the correct fuel when the Centurions start showing up.. Big John On Mon, 26 Jan 2004 04:21:08 GMT, "Cy Galley" wrote: Hans Conser wrote: Page 18 Feb issue of Flying: "FAA Certifies Auto Engine Conversion ----clip---- |
"Cy Galley" wrote in message news:W9GRb.167062$I06.1661204@attbi_s01...
Jet fuel has a larger nozzle. I don't know whether you can fuel a gas 172 with the larger nozzle. I know at one time Beech was trying to get restrictors in the openings of Bonanzas. Make it even easier to prevent misfueling....go to single point refueling... Craig C. |
I don't understand how single point fueling will do a better job of
preventing using the wrong fuel. "Craig" wrote in message om... "Cy Galley" wrote in message news:W9GRb.167062$I06.1661204@attbi_s01... Jet fuel has a larger nozzle. I don't know whether you can fuel a gas 172 with the larger nozzle. I know at one time Beech was trying to get restrictors in the openings of Bonanzas. Make it even easier to prevent misfueling....go to single point refueling... Craig C. |
"Cy Galley" wrote in message news:msVRb.177072$na.286827@attbi_s04...
I don't understand how single point fueling will do a better job of preventing using the wrong fuel. Going to a single point system requires the use of a special pressure feed nozzle. The nozzle locks onto a mating recepticle on the a/c. With this system, all tanks are filled through the single connection. The system is a bit of overkill ( to put it mildly ) for small a/c, but we are going to start seeing it soon with the practicality of the personal jet ever closer. Craig C. |
Similar Threads | ||||
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
