Flarm/ClearNav Help Needed
Old December 21st 16, 12:48 AM posted to rec.aviation.soaring
Dan Marotta
Default Flarm/ClearNav Help Needed
Hi All,
I built a cable for My Power FLARM portable according to the drawing on
the Tech Tips portion of the ClearNav site but The CN does not connect
to the Flarm. I have a cable tester and the cable checks good. I've
tried baud rates from 19.2 to 57.6K and still no luck.
I also spoke with another CNII user at Moriarty and he asked me if I'd
enabled FLARM on my CNII. I've looked and can't find anything other
than Flarm Status - There is none, and Flarm Alerts and I have the
longest alerts selected.
What about the Flarm dataport strings? Flarm Only or Flarm and Nav
(I've tried it both ways without success)? Does anyone have any other
suggestions?
Dan, 5J
Old December 21st 16, 01:25 AM posted to rec.aviation.soaring
RW[_2_]
On Tuesday, December 20, 2016 at 7:48:11 PM UTC-5, Dan Marotta wrote:
Hi All,
suggestions?
Dan, 5J
Power Flarm has to finish power up dance before you start CN.
Ryszard
Old December 21st 16, 01:49 AM posted to rec.aviation.soaring
JS
Hi All,
suggestions?
Dan, 5J
Ryszard
Also the higher the baud rate, the longer the connection process. The CN2 starts looking at low rates then goes higher.
Old December 21st 16, 03:44 AM posted to rec.aviation.soaring
Tango Eight
Dan -- pls check the forum.
Thx
Evan
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 3 April 10th 16 04:13 AM
trying to work out how you connect the flarm view 57 to mini box flarm running a V7 and Oudie Michael Marshall[_2_] Soaring 0 April 8th 16 08:57 PM
Information for all users of Flarm, OEM FLARM supplier and Flarm PowerFlarm [email protected] Soaring 28 March 12th 16 04:31 AM
Integrating Flarm with Clearnav [email protected] Soaring 8 September 6th 12 01:33 PM
Help needed: ILEC SN10 pilots with FLARM Dave Nadler Soaring 2 December 1st 09 12:03 AM
