Flight review required?
Old April 22nd 16, 04:42 AM posted to rec.aviation.soaring
Jim Lewis[_2_]
Default Flight review required?
On Thursday, April 21, 2016 at 6:05:28 PM UTC-7, wrote:
Terry said "Most training gliders fit in light sport.". The 2-33 certainly does, but the Blanik L-23 or the Ask 21 does not due to Vne - or am I missing something?
It is kind of a curious circumstance with the ASK-21. The POH specifies a max all-up weight of 1320 lbs - on the button for the max weight of a light sport aircraft, but the Vne is specified as 151 kts.. - more than a little faster than the 120 kts. Vne the FAA (14 CFR 1.1) limits a light sport aircraft to.
  #32
Old April 22nd 16, 01:50 PM posted to rec.aviation.soaring
N97MT
As well, the Grob 103 does not qualify as Light Sport due to too high of a stall speed with the spoilers extended.
Aside from the 2-33, I have not yet seen a popular training glider that fits into Light Sport.
  #33
Old April 22nd 16, 02:08 PM posted to rec.aviation.soaring
Bruce Hoult
On Friday, April 22, 2016 at 6:11:19 AM UTC+3, Bill T wrote:
Light sport aircraft directly limits gliders to a Vne of 120kcas to qualify as light sport.
Seems very inconsistent, as I don't recall a Vne limit for non-gliders.
In any case, what is to prevent you from simply re-placarding your glider to a 120 knot Vne?
  #34
Old April 22nd 16, 04:07 PM posted to rec.aviation.soaring
120 knots is not Vne for Light Sport. The limit is 120 kts max speed in level flight (Vh). I believe this is also at sea level on a standard day. Vne is probably tailored to the individual aircraft model accounting for structural and flutter concerns.
  #35
Old April 22nd 16, 04:25 PM posted to rec.aviation.soaring
This is a direct copy from 14 CFR 1.1 under the definition of Light Sport Aircraft:
(3) A maximum never-exceed speed (VNE) of not more than 120 knots CAS for a glider
  #36
Bruce Hoult
That's what I said.
  #37
Old April 22nd 16, 05:37 PM posted to rec.aviation.soaring
Jim Lewis[_2_]
Yes, that's what you said but it is still not correct. 120 kts. is the specified Vne for Light Sport aircraft. See 14 CFR 1.1.
  #38
Old April 22nd 16, 07:14 PM posted to rec.aviation.soaring
Here is the link to 1.1
http://www.ecfr.gov/cgi-bin/text-idx....0.1.1.1.0.1.1
See the entire definition of Light Sport Aircraft, specifically item 3 under the definition.
Light-sport aircraft means an aircraft, other than a helicopter or powered-lift that, since its original certification, has continued to meet the following:
(1) A maximum takeoff weight of not more than--
(i) 1,320 pounds (600 kilograms) for aircraft not intended for operation on water; or
(ii) 1,430 pounds (650 kilograms) for an aircraft intended for operation on water.
(2) A maximum airspeed in level flight with maximum continuous power (VH) of not more than 120 knots CAS under standard atmospheric conditions at sea level.
(3) A maximum never-exceed speed (VNE) of not more than 120 knots CAS for a glider.
(4) A maximum stalling speed or minimum steady flight speed without the use of lift-enhancing devices (VS1) of not more than 45 knots CAS at the aircraft's maximum certificated takeoff weight and most critical center of gravity.
(5) A maximum seating capacity of no more than two persons, including the pilot.
(6) A single, reciprocating engine, if powered.
(7) A fixed or ground-adjustable propeller if a powered aircraft other than a powered glider.
(8) A fixed or feathering propeller system if a powered glider.
(9) A fixed-pitch, semi-rigid, teetering, two-blade rotor system, if a gyroplane.
(10) A nonpressurized cabin, if equipped with a cabin.
(11) Fixed landing gear, except for an aircraft intended for operation on water or a glider.
(12) Fixed or retractable landing gear, or a hull, for an aircraft intended for operation on water.
(13) Fixed or retractable landing gear for a glider.
  #39
Old April 22nd 16, 08:00 PM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Because the FAA already thought of that dodge! Notice the words "since
its original certification" in the excerpt below.
"Light-sport aircraft means an aircraft, other than a helicopter or
meet the following:"
Now if you are certifying a new glider, I see nothing stopping you from
doing something like that. In fact, I think it happens every day in the
Light Sport world. That explains how they can sell a 2-seat Light Sport
airplane that (on paper) has barely enough useful load to carry one
USA-sized pilot. Obviously there is an official gross weight, and
another, higher "wink wink" gross weight.
  #40
Old April 23rd 16, 03:33 AM posted to rec.aviation.soaring
Jim Lewis[_2_]
On the other hand, the POH for the ASK-21 and for the DG500 both indicate that the Vne is rather like a TAS, so the Vne CAS decreases with altitude. The 120 kts. Vne limit for Light Sport Aircraft (14 CFR 1.1) is a CAS.
Flight line trailer ideas required mas Soaring 2 September 1st 15 10:59 AM
Organizational Skills Required During Instrument Flight [email protected] Instrument Flight Rules 71 February 23rd 07 05:28 AM
Flight over water...required equipment? ET Piloting 14 March 27th 06 11:47 PM
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
Is there a FAA Manual for Heli flight examiners? gps required? Eric D Rotorcraft 2 October 29th 03 11:34 AM
