Taildragger Technique for Gliders
As a (retired) tow pilot, I have many, /many/ takeoffs and landings in
tail draggers and the vast majority of my glider operations are in tail wheel equipped gliders, as well.Ā* To put it bluntly, I see no comparison between the two except for those gliders equipped with /steerable/ tail wheels (mostly self launchers), and in those, the distance between the main and tail wheels is so great and the steering authority of the tail wheel so small (and non castering) that there is no need (in my opinion) to worry about it. In nose or tail dragger gliders, my best advice is to get onto the main wheel only as quickly as possible for directional control with the rudder.Ā* With either end of the glider dragging on the ground there is not much directional control. Best, Dan On 12/27/2018 5:43 PM, Papa3 wrote: Is anyone aware of a glider textbook or manual which teaches the details of taildragger takeoffs and landings in gliders? I have lots of examples that I've used personally with students based on my power training a Champ and dozens of available texts oriented at the power taildragger training. Looking back through RAS, I found a couple of old threads but not what I was looking for. I just want to re-use someone else's diagrams and text. Failing that, I'll end up formally writing up my own notes along with those from a couple of other club CFIGs. Not necessarily looking for a new thread on "why learning in Schweizers sucks" or "how come Americans don't know how to land." But it's Winter in the northern hemisphere, so I can probably predict where this will end up. Erik Mann (P3) -- Dan, 5J |
On Friday, December 28, 2018 at 9:33:48 AM UTC-7, 6PK wrote:
I will be shocked if there is too much difference of opinion at least on this subject.... I had to land my RS-15 on its main wheel and continue to "fly" it on the ground, while still on its main, until I used the effective wheel brake to slow and stop. As soon as the tail wheel would touch the ground there would be very little aileron control. Landing that sailplane in a conventional two point landing would cause a wing drop soon after touchdown resulting in a trip off the edge of the runway. Reworking the flap/aileron mixing cam helped but did not solve the problem. Other RS-15's had the same behavior. My Mini Nimbus was fine with two point landings as well as main wheel landings. Mike |
On Friday, December 28, 2018 at 11:51:25 AM UTC-5, Dan Marotta wrote:
As a (retired) tow pilot, I have many, many takeoffs and landings in tail draggers and the vast majority of my glider operations are in tail wheel equipped gliders, as well.Ā* To put it bluntly, I see no comparison between the two except for those gliders equipped with steerable tail wheels (mostly self launchers), and in those, the distance between the main and tail wheels is so great and the steering authority of the tail wheel so small (and non castering) that there is no need (in my opinion) to worry about it. I agree 100% with Dan's comments. There is no comparison between the two, nothing about them is anywhere near a comparison. Keep the glider straight and wings level is my advice. In nose or tail dragger gliders, my best advice is to get onto the main wheel only as quickly as possible for directional control with the rudder.Ā* With either end of the glider dragging on the ground there is not much directional control. Best, Dan On 12/27/2018 5:43 PM, Papa3 wrote: Is anyone aware of a glider textbook or manual which teaches the details of taildragger takeoffs and landings in gliders? I have lots of examples that I've used personally with students based on my power training a Champ and dozens of available texts oriented at the power taildragger training. Looking back through RAS, I found a couple of old threads but not what I was looking for. I just want to re-use someone else's diagrams and text. Failing that, I'll end up formally writing up my own notes along with those from a couple of other club CFIGs. Not necessarily looking for a new thread on "why learning in Schweizers sucks" or "how come Americans don't know how to land." But it's Winter in the northern hemisphere, so I can probably predict where this will end up. Erik Mann (P3) -- Dan, 5J |
I agree too, no issue.
Then again : some people should just take up golf. Tom |
you donāt say what you are looking for.
1: my experience is that aviation insurance companies do not consider glider time to be ātail wheel timeā. I expect that this is because gliders don't want to swap ends while taxiing.. 2: there are significant differences in ground controllability along gliders. Important factors include A: whether the tail wheel is fixed, āsteerableā, or castering B: the degree of rudder and aileron authority at taxi speeds. For example, a Blanik L-13 with a castering tailwheel retains rudder and aileron authority to extremely low speeds, and can be turned rather sharply with opposite aileron, simply not possible in a glider with a fixed tail wheel once that's on the ground. Each glider had its own nuances. |
Similar Threads | ||||
Aerotow Technique Flapped gliders | Don Johnstone[_4_] | Soaring | 0 | December 16th 16 12:00 AM |
There's No Taildragger Like A Texas Taildragger - TT3.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | June 6th 09 02:00 PM |
There's No Taildragger Like A Texas Taildragger - TT1.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | June 6th 09 02:00 PM |
There's No Taildragger Like A Texas Taildragger - 001index.jpg (0/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | June 6th 09 02:00 PM |
There's No Taildragger Like A Texas Taildragger - 001index.jpg (1/1) | Mitchell Holman[_4_] | Aviation Photos | 0 | June 6th 09 02:00 PM |
