Oxygen- EasyPulse 5 conserving regulator?
Old September 28th 06, 07:52 PM posted to rec.aviation.piloting,rec.aviation.owning
Ron Natalie
Default Oxygen- EasyPulse 5 conserving regulator?
Peter wrote:
The Mountain High regulator is worse than the Nelson one?
Precisely.
That's suprising since it's electronic.
Maybe a little, but not if you actually look at the specs
(neither company seems to inflate their own specs, but Montain
High's sales pitch to me at Oshkosh seemed to consist of 90%
untruths about the Nelson unit).
Old September 28th 06, 08:03 PM posted to rec.aviation.piloting,rec.aviation.owning
Grumman-581[_3_]
"Peter" wrote in message
Any comments/corrections much appreciated.
Just a bit of trivia... A 2-liter plastic soda bottle is supposedly rated
for around 200 psi... If you filled it with O2 and put a valve on it that
would feed into your regulator, you would have a very lightweight O2 supply
for about 13 minutes... I've never filled them to that pressure though... I
routinely fill them to 75 psi when I'm carbonating a beverage... I also
tried oxygenating beverages at one time, but the taste was too light...
Old September 28th 06, 08:29 PM posted to rec.aviation.piloting,rec.aviation.owning
Ron Natalie
Well, if you ask a U.S. pilot shop what they think of Nelson (a.k.a.
Precise Flow) they say the stuff doesn't work at all. This is because
Nelson took their sales in-house so the retailers can't make the
margin on them anymore.
These weren't pilot shops. This was talking to the companies
directly at their respective booths in Oshkosh year before
last. I've never seen a pilot shop (at least not around
here) selling oxygen setups at all. It's way too much
of a niche market. You're lucky to find headphones, etc..
at most shops here (most rarely carry more than sectionals).
Old September 29th 06, 12:20 AM posted to rec.aviation.piloting,rec.aviation.owning
Peter Duniho
"Ron Natalie" wrote in message
m...
[...] I've never seen a pilot shop (at least not around
Huh. It's unfortunate you don't have better-stocked pilot shops where you
are. I have bought most of my pilot accessories from local shops, including
my headsets, handheld radio, and yes...my portable oxygen system.
The shop currently closest to my hangar also sells things like grease,
engine oil, hydraulic fluid, tires, and a variety of other owner
accessories. Granted, they are part of the FBO there, so those sorts of
maintenance items are stuff they have to stock anyway. But I'm surprised to
hear your local pilot shops are so limited.
Pete
Old October 1st 06, 02:36 AM posted to rec.aviation.piloting,rec.aviation.owning
Aviation Consumer tested both units in June 2006. They liked both units
alot and raved about them. They preferred the Precise Flow for a single
user unit, due to its lower cost and more simple installation. For 2
users, you need another unit for the Precise Flow, so its lower cost is
negated, and the Mountain high hooks up for 2 users more easily, so
they preferred it for a 2 place installation.
Bud
Ron Natalie wrote:
Precisely.
Oxygen- EasyPulse 5 conserving regulator? Dan Youngquist Piloting 14 October 1st 06 02:36 AM
Oxygen regulator Roger Fowler Soaring 3 December 26th 05 11:29 AM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Oxygen mask and regulator sale - update nzuri Soaring 0 October 1st 03 09:31 AM
Scott oxygen mask and diluter-demand regulator for sale in UK nzuri Soaring 0 September 28th 03 10:46 PM
