Looping a standard cirrus
Old January 16th 18, 12:57 AM posted to rec.aviation.soaring
Default Looping a standard cirrus
Who has done a loop in a standard cirrus? Any comments or hints. Currently getting some acro training with the goal of looping my cirrus.
Old January 16th 18, 02:17 AM posted to rec.aviation.soaring
I do not believe the Standard Cirrus can be looped safely. Don't try it, or the world will spontaneously combust and all life will end.
Old January 16th 18, 03:39 AM posted to rec.aviation.soaring
Key Dismukes
I started to do a loop long ago in my standard Cirrus, but as i put the nose for speed started to get some flutter from the flying stabilizer. Quickly (but oh so gently) aborted the loop.
Old January 16th 18, 03:48 AM posted to rec.aviation.soaring
Check the operating manual. If the manual doesn’t tell you how to do the loop, don’t do it. The manual for any good glider will have a section that explains the procedure and entry speed for a loop.
Old January 16th 18, 04:32 AM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
Flight manual predicts the end of life as we know it maybe!
http://www.standardcirrus.org/flight...vicemanual.pdf
Richard
Old January 16th 18, 05:24 AM posted to rec.aviation.soaring
It’s rated for loops. All it says is that the entry speed is 97 knots
Old January 16th 18, 05:38 AM posted to rec.aviation.soaring
The glider is rated for loops. Entry speed 97 knots. Im just wondering if any other cirrus owner frequently loop and how it behaves
Old January 16th 18, 09:42 AM posted to rec.aviation.soaring
Dave Nadler
Accidentally or intentionally?
If you don't know what I'm talking about, you should...
Old January 16th 18, 10:17 AM posted to rec.aviation.soaring
Surge
The Cirrus may have been rated for loops when it was new and free of repairs, control slop, etc. so unless your 40+ year old glider is in pristine condition with no accident history you will need to take all those approved maneuvers and Vne with a pinch of salt.
I would not try it myself.
Old January 16th 18, 02:17 PM posted to rec.aviation.soaring
Tango Whisky
Le mardi 16 janvier 2018 11:17:54 UTC+1, Surge a écritÂ*:
A loop means entry speed of about 100 kts and pulling 3-3.5 g.
If you don't think you can do that with a certain glider, that glider is probably not airworthy in the first place.
Standard Cirrus Walt Connelly Soaring 10 December 31st 11 04:03 PM
Standard Cirrus Walt Connelly Soaring 23 March 20th 11 03:14 AM
Standard Cirrus C-Hook Randy[_2_] Soaring 26 September 26th 08 10:24 PM
Standard Cirrus Don Burns Soaring 0 January 10th 07 05:24 AM
F/S - Standard Cirrus 75 Bob Soaring 0 October 4th 04 12:23 AM
