Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Radio band scanner
Old October 13th 04, 09:20 PM
Fritz
Default Radio band scanner
Living and working near an airport, I'd like to listen some times to
Air-Ground communications. Do you have any suggestion on a good,
portable, lightweight scanner with rechargable batteries?
Fritz
Old October 14th 04, 05:38 AM
Matthew Chidester
depends on really how close you are.. I bought a small $30 radio where I
basically have to be right AT the airport to hear anything..and AM stations
would mix in with the audio.
I got fed up with that and bought a ICOM A5 (sport) I think with the
cigarette adapter so I could listen in the car as well. It's a really nice
unit and you can use rechargable batteries since the sport model gives you a
battery case instead of the nicad battery.
pricey but I like it,
Matthew
(plus it records.. kinda cool)
"Fritz" wrote in message
Fritz
Old October 14th 04, 07:27 PM
Fritz
Workplace 1.000 meters fom the airport tower
Home 4-5 km from the airport.
Fritz
Old October 14th 04, 07:36 PM
Matthew Chidester
i'm about a 25 min drive from the airport.. 20~25nm not sure what the
conversion is but I can pick up approach and atis, sometimes tower and
ground on a good day (weather affects it)
I think you'd easily be able to listen using the A5.. it's a little pricey
and when I bought it was $300 but it should work
(plus it has a coax connection where the ant. comes off, you could hook it
up carefully looking at specs to a bigger ant but you being that close you
won't need it)
Matthew
(hope that helps, i'm glad I bought mine - helps me with radio work here in
the US)
(sorta OT) Free Ham Radio Course RST Engineering Home Built 51 January 24th 05 08:05 PM
Jim Weir or other qualified persons: a tangent on the 2 radio 1 antennathread Dave S Home Built 12 June 23rd 04 01:03 AM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Radio silence, Market Garden and death at Arnhem ArtKramr Military Aviation 4 February 12th 04 12:05 AM
Ham Radio In The Airplane Doug Carter Home Built 24 July 8th 03 03:30 AM
