2018 - AN EXCITING YEAR
Old February 18th 18, 04:15 PM posted to rec.aviation.soaring
Default 2018 - AN EXCITING YEAR
On Saturday, February 17, 2018 at 7:38:01 PM UTC-5, Jeff Morgan wrote:
On Saturday, February 17, 2018 at 12:42:17 PM UTC-7, Scott Manley wrote:
The airlines fully qualify pilots in simulators, essentially reaching 100%.
A bit overstated.
After 6-8 sessions in a full motion Level D sim and the Check Ride airline pilots require 20-40 hours Initial Operating Experience in the airplane under the supervision of a Check Airman before being "finished" and signed off for line operations.
The flight footprint is often larger than the sim footprint.
And then if the new airline pilot fails to gain 100 flight hours within 90 days of the simulator check ride (IOE counts towards this), the entire training process must be repeated - FAA requirement.
I stand corrected. I should know better than to use 100% in any argument.
But most importantly, airline pilots are not primary students.
'Not sure why that is "most" important. Both are simply humans trying to learn something. The use of simulation is about improving human learning.
Understand I'm not downing your product. Sims have their place. Primary students need to actually fly and land the real aircraft too.
For clarification: Condor is not "my product". (I should probably stop using the nickname "The Condor Guy", given to me by others. I am actually the "Advocate for the use of flight simulation in glider flight training GUY"). I have no financial stake in Condor. I am a professional educator who understands the value of simulation in the human learning process. I use Condor because it is the best glider flight simulation available. When a better glider flight simulation becomes available, I will use it.
It has never been my position that "all" flight training, primary or otherwise, can or should be conducted in simulation, only that a very large percentage of it (approximately, IMHO, based on my 10 years of experience in simulation-based flight training, 80%) can and should be. Simulation is the superior "learning" environment. Actual flight is the superior "application of learning" environment.
My original reply to this post was not intended to highjack the thread and spur yet another debate over the value of simulation in human learning.
My intent was to provide clubs / commercial operations who struggle with the cost and complexity of maintaining actual aircraft for the purpose of providing flight training, what I believe to be a viable solution for their consideration.
Scott Manley 3167160CFI ---- Out!
Old February 18th 18, 05:26 PM posted to rec.aviation.soaring
So, my club has a new K21 arriving for the upcoming season. For the price of the glider, instruments and trailer ($140K +/- I think) we might be able to get a used Duo Discus and have some cash left over. For instance, there is what appears to be a nice, 20 year old Duo an W&W for $115,000. Are Duos that unsuitable for training or are K21s simply more robust and better able to handle the inevitable hard landings by students/low time pilots. Both? I have no dog in the fight as the decision has been made and I, as an owner of my own ship, will fly the K21 only for flight reviews the occasional passenger flight. Maybe. We also have a Grob Twin and L23 and either of those is suitable for those needs. I'm just curious.
Old February 18th 18, 05:33 PM posted to rec.aviation.soaring
Bruce Hoult
Duos are beautiful machines.
I think the main areas of concern for initial training (valid or not) a
- unsprung wheel
- not the most powerful airbrakes in the world
- not a good idea to do inadvertent extreme attitudes
- wings lowish and 10% - 15% longer than most trainers
The DG1000 with 18m tips is better in all those areas.
  #24
Old February 18th 18, 06:47 PM posted to rec.aviation.soaring
Dave Springford
I think that you will find the primary difference between the Duo and K-21 is energy management. Teaching students to manage energy and land is one of the keys to getting them solo in a reasonable amount of time. My club purchased a Duo XL last year and while we have been training in K-21's for 10 years, the transition to the Duo was not easy for some licensed pilots.
It is much quieter than the K-21 so the noise feedback for speed control is gone.
It is much slipperier than the K-21 so subtle changes in attitude result in much larger changes in speed. Couple this with the lack of noise and pilots were finding themselves over 70 kts on final.
It carries more energy into the landing than does a K-21, although the addition of landing flaps to the XL version resolves much of this.
Besides its handling and performance, another nice advantage is the sideways opening canopy does not result in burn marks on the instrument panel in the front and headrest in the back. We've sent an S3 vario back 2 times for screen replacement because of sun burns that happen almost instantly when the sun is in the worst possible spot for a K-21.
  #25
Old February 18th 18, 07:08 PM posted to rec.aviation.soaring
Chris Rowland[_2_]
The question to ask is would you send an average pilot solo in a Duo?
Chris
K-21
o=
pu=
10=
=20
is=
gone.
in=
pilot=
addi=
sideway=
t=
for=
when
  #26
Old February 18th 18, 09:12 PM posted to rec.aviation.soaring
krasw
Chris
Would you send pilot trained in Duo to solo in any other type?
  #27
Old February 18th 18, 09:42 PM posted to rec.aviation.soaring
Bruce Hoult
My club has sent dozens of average pilots solo in DG1000 in the last ten years.
  #28
Old February 18th 18, 10:04 PM posted to rec.aviation.soaring
Jonathon May[_2_]
Duo?
last ten
years.
A Duo xl much easier to land .
In fairness if you loose control in a duo it picks up speed very
quickly.
Easier in a K13 but the spars are going to get worse not better
  #29
Old February 19th 18, 02:33 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Sunday, February 18, 2018 at 12:47:54 PM UTC-6, Dave Springford wrote:
Snippage
Not an instructor but my solution is one of training. Enter the patter, gear down, side window scoop open. Instant audio airspeed. Maybe not as sensitive as an ASI, but certainly provided clues as to what you are doing.
I would assume that your club's Duo has windows with scoops on them. Try it, particularly with those who tend to wander a bit on speed.
Steve Leonard
  #30
Old February 19th 18, 02:40 AM posted to rec.aviation.soaring
Chris
K-21
o=
pu=
10=
=20
is=
gone.
in=
pilot=
addi=
sideway=
t=
for=
when
Yes, I would send a student solo in a Duo Discus. But a better question is how much longer would it take to get the student to solo standard vs a K21.. I am not sure what the average amount of flights to solo would be in each aircraft but I am certain it would be more in a Duo. For the sake of argument, lets say it would take 5 more flights to solo in a Duo. If you have 10 students, you will need 50 more flights from your instructor group. If that is not a big deal than get a Duo. If like most clubs your instructor time is at a premium then get a K-21 (or 2-33,L-23).
Any news from this exciting design? TRKA Soaring 9 January 4th 11 02:17 PM
out of focus can sometimes be exciting too Pensacola Beachcomber Aviation Photos 3 May 5th 08 03:27 PM
Read an exciting, intelectual Novel after flight? The Masconi's a Novel Owning 0 May 4th 06 07:19 PM
How come military aviation is so exciting....? Garamondextended Military Aviation 1 May 13th 04 03:49 PM
EXCITING NEW POSSIBILITIES John Roake Soaring 0 December 9th 03 12:59 AM
