'Retard, retard'
Is that rather uncomplimentary pre-recorded playback near the end of
flights generated by the radio altimeter or GPWS? Ramapriya |
'Retard, retard'
'Retard, retard'
"Beavis" wrote in message (The radio altimeter is one of the primary
inputs to the GPWS.) However, the GPWS was no integration with autothrust, autopilot, or FADEC on the A-320. The message is generated by the radio altimeter if the autothrottles are still in the climb detent. It sounds at 40'AGL if one or both APs are engaged, or at 20'AGL if the APs are not engaged. D. |
'Retard, retard'
Capt.Doug wrote:
However, the GPWS was no integration with autothrust, autopilot, or FADEC on the A-320. The message is generated by the radio altimeter if the autothrottles are still in the climb detent. It sounds at 40'AGL if one or both APs are engaged, or at 20'AGL if the APs are not engaged. D. So Capn, the 'Retard' in the A320 is generated by what - GPWS? The AutoThrottle can't be in climb detent so near the ground on finals, right? Ramapriya |
