Future of 100LL?
It has been my experience that autogas runs definitely leaner
carburated engines. I know autogas also has a higher specific gravity - although I don't know the numbers off hand. But it does mean that the calibration of a carb venturi will change - probably being leaner for autogas. That you had the greatest problem in the winter, when the air is most dense, also suggests that your engine was marginally starving for fuel most of the time for whatever reason. It is probably also still running lean on avgas. An earlier post somewhere else accused autogas of causing carb ice because his engine ran rough unless he used carb heat. I'd bet icing isn't his issue, as carbs will naturally run richer with a higher carb air inlet temp. He too was probably marginally lean even with avgas under most conditions, but that it took carb heat application just got him to a runable condition with autofuel. I knew of a freshly overhauled O-300 powered 172 that then required carb heat on climbout to run smoothly. Everyone assumed it was somehow icing, but it went less than 100 hours before it burned a piston from too-lean operation. After complying with the one-piece venturi AD in our 172M, things were so lean (especially in the winter) that we had to change the main jet nozzle to get it to run right. I understand others have reported problems in this area too. When an engine is cold, idle operation with autofuel will behave differently again, with liquid fuel accumulating on the walls of the intake manifold. This liquid will go into the engine and cause rich-induced stumbling on power application. The real question for autogas vs avgas - is the engine operating at a reasonable mixture over a wide range of air inlet temperatures when warm? What symptoms can be expected when when the carb is out of a reasonable calibration? Engine air intake systems are critical, and an engine/carb system that runs well in one installation won't necessarily run even well in another. I'm an advocate of having an EGT (even if only temporary) for any homebuilt, or any other installation that is showing mixture problems. |
Similar Threads | ||||
What is missile defense? An expensive fraud Bush needs Poland as a future nuclear battlefield | Paul J. Adam | Military Aviation | 1 | August 9th 04 08:29 PM |
Future of 100LL? | Michael | Owning | 0 | August 2nd 04 09:29 AM |
Future military fighters and guns - yes or no ? | championsleeper | Military Aviation | 77 | March 3rd 04 04:11 AM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
UNMANNED, THE WAY OF THE FUTURE | Larry Dighera | Piloting | 11 | November 28th 03 05:02 PM |
