Recording Hobbs
Does anyone use a PDA to record in a small spreadsheet the departure
airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks |
Recording Hobbs
airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks I don't, although I will sometimes record (temporarily) in my Palm (Tungsten E) the hobbs and tach numbers until I can transfer them to my paper logbook. My palm came with Documents To Go, which lets me work with Excel spreadsheets. It also has a sketchpad function which I use to scrawl the numbers until I get to my logbook. For what you are asking, just about any PDA should do fine. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Recording Hobbs
I do the same with my Palm Z22, it has a note pad feature that turns the
tough screen into a note pad. Just scribble away. Temporary document until I can transfer it to my personal log book. I do the same with logging time with my students. Any PDA with a spreadsheet function will do what you want. BT "Jose" wrote in message t... Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks I don't, although I will sometimes record (temporarily) in my Palm (Tungsten E) the hobbs and tach numbers until I can transfer them to my paper logbook. My palm came with Documents To Go, which lets me work with Excel spreadsheets. It also has a sketchpad function which I use to scrawl the numbers until I get to my logbook. For what you are asking, just about any PDA should do fine. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
Recording Hobbs
fwiw, I use a steno pad. Wx notes go on top, flight plan under it,
startup tach/hobbs, clearance under all of that, then freqs, estimates at fixes, actuals at fixes, and so on. I have a number of those pads, each page holding the complete contemporaneous record of a flight. The pads hold 90 sheets, I keep some reference notes on some pages, so there may be 150 or 170 flights in each book. What makes it especially neat is I can look at how I filed a particular flight from some time ago, or look at a given flight and remember more details than the single line in my log book provides. The pencil gets stuck in the spring, the pad is easy to write on (no knee clips or things like that, they tend to wrinkle up suit pants). That brings up a long ago memory. I remember sometime in the 60s seeing the Blue Angels at South Waymouth Naval Air Station in MA. There was a P51 Spitfire out on the field, and I remember watching a guy go out wearing a suit. He took off his coat, climbed in, strapped on the chute, then took off and did things (I wasn't a pilot then) that I had never seen done before -- high speed low passes inverted, following the dip in the runway so he seemed to disappear -- that sort of thing. He landed, got out, put on his suit coat, and walked away. Much later I'd fly with my friends in their C172s and the like and they'd put on their flying boots and flying gloves and God knows what else. It made me smile. I did a lot of flying on business, and would remember that Spitfire jockey when I'd go out to the Mooney, fold my suitcoat and put it in the backseat, then fly off. However, I remember a couple of times finishing my meetings or whatever, go out to the airplane in a rainstorm and find water in the tanks! Draining a lowwing tanke in the rain is NOT a suit and tie job! I know the last few paragraphs do not have anything to do with the OP's question -- but the steno pad does. Give that way of keeping flight plans and notes a try, you may find you like it a lot. On Dec 5, 5:34 pm, "BG" wrote: Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks |
Recording Hobbs
Tony wrote:
That brings up a long ago memory. I remember sometime in the 60s seeing the Blue Angels at South Waymouth Naval Air Station in MA. There was a P51 Spitfire out on the field, and I remember watching a guy go out wearing a suit. He took off his coat, climbed in, strapped on the chute, then took off and did things (I wasn't a pilot then) that I had never seen done before -- high speed low passes inverted, following the dip in the runway so he seemed to disappear -- that sort of thing. He landed, got out, put on his suit coat, and walked away. A P-51 SPITFIRE you say? ;-)) A man wearing a suit, you say? Did he perchance wear a straw hat? Was he tall and thin with a mustache? Did he make the aircraft dance down the runway from one wheel to the other and back again? If you answered yes to all of the above, you were priviledged to see a performance by "The Pilot's Pilot", aka Robert A "Bob" Hoover. |
Recording Hobbs
That was before I knew what a Bob Hoover was, but it all fits together. That must have been before he mostly worked in an Aero Commander. Too bad about his Aero Commander, him having so much trouble keeping both fans turning. . .and he had a lot of trouble with straight and level too, didn't he? You must have seen the videos of him flying the Commander without spilling anything from an open container. Do you know if he did other things that took advantage of his remarkable coordination, or was it only obvious when he flew? On Dec 5, 10:49 pm, John Smith wrote: Tony wrote: That brings up a long ago memory. I remember sometime in the 60s seeing the Blue Angels at South Waymouth Naval Air Station in MA. There was a P51 Spitfire out on the field, and I remember watching a guy go out wearing a suit. He took off his coat, climbed in, strapped on the chute, then took off and did things (I wasn't a pilot then) that I had never seen done before -- high speed low passes inverted, following the dip in the runway so he seemed to disappear -- that sort of thing. He landed, got out, put on his suit coat, and walked away.A P-51 SPITFIRE you say? ;-)) A man wearing a suit, you say? Did he perchance wear a straw hat? Was he tall and thin with a mustache? Did he make the aircraft dance down the runway from one wheel to the other and back again? If you answered yes to all of the above, you were priviledged to see a performance by "The Pilot's Pilot", aka Robert A "Bob" Hoover. |
Recording Hobbs
crossposting-snipped
On Tue, 05 Dec 2006 14:34:18 -0800, in om, BG wrote: Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? I use a Navman PiN 100... I picked it up at Fry's one day for less than $200... It has a GPS built into it and I've loaded PocketFMS onto it... I use the notepad feature of it to just write down the hours and then I'll enter them into my electronic logbook whenever I get a chance... I've probably got a year's worth of entries that I need to enter in by now... I have enough hours that I don't need to log them for an advanced rating and I'm never going to be a professional pilot, so I'm rather lax about logging my hours... |
Recording Hobbs
I don't know why you would need to write them down with such precision.
Is it for tax purposes? Or is it an employer requirement? If it is just for the personal logbook, I don't see why you need a PDA to do this. Just remember it in your head, or write it down on a scrap piece of paper until you get home. BG wrote: Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks |
Recording Hobbs
"Andrew Sarangan" wrote in message
ups.com... I don't know why you would need to write them down with such precision. Is it for tax purposes? Or is it an employer requirement? If it is just for the personal logbook, I don't see why you need a PDA to do this. Just remember it in your head, or write it down on a scrap piece of paper until you get home. BG wrote: Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? If so, what would be the brand and the main features of the PDA? Thanks I have a PocketPC with a small version of Excel. I have a W&B (including the chart) customized for my plane. The Lake is somewhat CG limited. It's easy to be too far aft starting out. And just as easy to be too far forward after fuel burns off. So anything other than typical loads gets put in to check the range as fuel burns. My chart plots the line from starting fuel down to 5 gal. remaining. I figure if I have less than 5 gal, a little forward CG is the least of my problems. I do have an Excel file with my flight information. I use it as an easier way to determine flight currency for medical applications, insurance forms, IFR currency, and the trivial passenger currency. It's also a backup, in case I lose my logbook. It's kind of nice to be able to crunch Excel formulae to determine, for example, how many hours do I have in C172s? in the last six months. At night. Solo. I have a section at the bottom that lists the typical currency numbers and displays colored text to warn me that I need to, for example, get some IFR approaches in before it's too late. I do copy this chart to my PocketPC but I don't enter numbers using the PDA. Too small and I really want the master on my PC anyway. I have flight note sheets in my kneeboard that have a customized form at the top with room for start-up/shutdown time, start-up/shutdown tach, start-up/shutdown hobbs, and othe stuff. One sheet per flight. I collect them and transfer the info to my logbook and the Excel file periodically. ------------------------------- Travis Lake N3094P PWK |
Recording Hobbs
BG wrote:
Does anyone use a PDA to record in a small spreadsheet the departure airport, your destination airport, and the Hobbs & Tach readings when you land? I do it with a paper kneeboard fuel log form created in Excel. The kneeboard is already there, the PDA isn't. When I get home or to a hotel, the fuel log easily recreates my log entries. I only bother with tach time as a reality check, because we've had two occasions in two years where the Hobbs didn't move. The log lists start times, start fuel, and on/off times for each tank. I verify each time I land, and enter any added fuel as necessary during the trip. There is blank space at the bottom of the form for random notes, ATIS ID's etc... My PDA does have a weight and balance spreadsheet I created that works very well for on the spot W&B. |
Similar Threads | ||||
fwd: For Hobbs | Jack | Soaring | 9 | November 26th 06 05:28 AM |
Engine noise recording in Motor Gliders | Ian Strachan | Soaring | 2 | October 16th 06 12:32 PM |
Hobbs Day 3 7-06 # 711 reporting | TomnKeyLargo | Soaring | 12 | July 9th 04 04:38 AM |
Tach Vs. Hobbs Time | John Roncallo | Owning | 33 | January 7th 04 12:42 AM |
