Battery health tesing
I'm wondering if there's a simple or straightforward way to test an SLA battery for general condition. Or a device I can buy that sucks a charge out of a battery over a few hours and reports its actual amp-hour capacity? I've built Peter Nyffelers amperehour tester: http://www.ppc.ethz.ch/~peny/sf/ah_test.html The simple circuit is easy to build out of standard components. It discharges the batteries with a fixed constant current until the voltage is down to 10.5 V then it switches the battery back to the charger. With a discharge current of 1 A the timer shows the capacity in ampere hours.(at 1/2 A multiply by two). This tester is convenient when you take care of a lot of batteries: - Charge battery (I do this with a second charger) - Connect the battery - Reset the hour meter - press the discharge button - The next day the battery is fully charged and the hour meter shows you its capacity. Sometimes it is possible to revive tired batteries with a few cycles of discharge and recarge (use a smart 3 phase charger). If 5 cycles don't help you can give up. George |
Georg, what is the "M1 Elapsed Time Meter"? This looks like a simple
enough project but I'm not sure I can identify enough of those components (ask me about software!). I do know how to handle a soldering iron though... |
"Eric Greenwell" wrote in message ... It sounds like you are effectively doing an internal resistance measurement. Exactly. I find that internal resistance is a great measure of the health of a battery. Do you have chart of volt drop, load, and good/ok/bad decision for various size batteries? No, but I usually consider any drop over a volt or so to be suspect (assuming an appropriate load for the size of battery). In my work, I often have the advantage of having identical batteries to compare against each other. I've not seen that sort of thing in battery data sheets, so I assume you have to develop the numbers empirically. True, but for auto-sized batteries the tester I mention (a very common type) comes with markings that make a great starting point. Vaughn |
Similar Threads | ||||
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 01:37 AM |
Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 01:29 PM |
Becker AR 4201 or Microair 760 Transceiver | Steve B | Soaring | 23 | September 15th 03 06:32 PM |
