#31
The airlines have been flying the RNAV overlays of the conventional
terminal routes on an ILS for over 20 years. What the airlines do is irrelevant to General Aviation operations. They're using different equipment and operating under different rules. You don't need to be checking underlying nav facilities during such an operation. That's your opinion, for which you have been unable to offer supporting evidence. The AIM says differently. It sounds like your both anal retentive You mean "you're". ;-) Is it anal retentive to want to follow the law? Ok, guilty. and spring-loaded to being unreasonably argumentative I must admit that I find it annoying and insulting when someone tries to pass off a series of irrelevancies and non sequiturs as an explanation. I usually associate this with someone hiding a lack of knowledge. yet you are unwilling to do your own leg work to get to the folks in the FAA who can answer your unnecessary question. This is my own leg work. ;-) I have also exchanged emails with the folks at Garmin, who were also unable to offer a coherent explanation as to why I could use their equipment in this fashion. Finding someone knowledgable at the FAA is a real chore. There also I run into people who try to "explain" things to me, only to find out they know less than I do on the subject. |
#32
Even though you seem to have all the terms down pat, you don't seem
to be able to explain how you would apply them to real-life scenarios. How much clearer can I be when I say that I'm using a Garmin 430 as the only navigation insturment turned on in the airplane. (Teenagers are also very good at this.) :-) |
#33
Maybe he's not talking about a Garmin unit.
He should be, since that what this thread is about. If I am not mistaken, the KLN units use "APPR" mode as Garmin uses "ACTV" when within two miles of the FAF, on the intermediate segment. Different animals. The KLN unit doesn't have the concept of "Activate Approach." When you load an approach on the KLN94, you then have to set the IAF as the active waypoint. This is a separate operation. When you load an approach on the 430, you are prompted "Activate Approach?" If you choose it, then the IAF becomes the active waypoint. Otherwise, the approach is simply "loaded" and you later have to change your waypoint to the IAF, just like the KLN94. |
#34
Greg Esres wrote: The airlines have been flying the RNAV overlays of the conventional terminal routes on an ILS for over 20 years. What the airlines do is irrelevant to General Aviation operations. They're using different equipment and operating under different rules. The different equipment does pretty much the same thing as a Garmin 400/500 series, at least as to LNAV. And, the rules pertaining to air carrier navigation in the national airspace system are the same rules you use. Or, if you think I am wrong, provide specifics. |
#35
Greg Esres wrote: If I am not mistaken, the KLN units use "APPR" mode as Garmin uses "ACTV" when within two miles of the FAF, on the intermediate segment. Gee, my Garmin goes from TERM to APR when within two miles of the FAF. |
#36
airspace system are the same rules you use. ...Or, if you think I am wrong, provide specifics. Fair question. Hmmm...do takeoff minimums apply to me? Do they apply to airlines? Can I shoot the approach anyway if the ATIS is reporting zero/zero conditions? Can airlines? Can I fly non-precision approaches using precision approach technique (DA)? Can some approved operators? Am I required to come up with a set of operating specifications that govern my activities once they are approved by the FAA? Do airlines? I have no specific information that relates to our current topic of discussion, but there are clearly different sets of rules that apply to Part 91 vs. 121 flyers. |
