#21
Filling with nitrogen
I was thinking about this kit for my struts. The hand pumps are nice for an emergency fill with air or H if you have a tank sitting around, but this kit isn't too much more money and stowes nicely away. http://www.polyperformance.com/shop/...&cat=11&page=1 On Mon, 4 Dec 2006 17:28:07 -0600, "Fly" fly at Tulsaconnect.com wrote: Expensive. My set up costs: Bottle of Nitrogen is about $100 A set of victor guages that the refirgeration guys use is about $110. 0-600 PSI on the low side. $13 for the gooseneck to fit the schrader valve and $25 to have a long hi-pressure hose made. Keep in mind that it a takes high pressure to force the schrader's needle valve open. Kent Felkins Tulsa "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message ... "scott moore" wrote in message . .. Hi, I am considering purchase of a nitrogen fill system. I don't have power at my tiedown, and filling the tires with a 12 volt portable compressor is a pain due to having to park the car near the tire, move to the other side, etc. I figgured a nice nitrogen tank system would give me a power free solution and fill the tire with the best possible kind of gas. I found a fill system online: http://www.aircraftspruce.com/catalo...trogenTire.php My only question is why it says "no struts". That would seem to me to be one of the best uses of this system, that I can top off my strut, which is forever going low (on a Cessna). Is there a reason for this restriction, and is there a system that can do struts? Thank you. Scott Moore A $40 ten gallon air tank is way more than enough for tires. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
http://www.aircraft-tool.com/shop/flyer.aspx
Shows a strut pump coupler. My regulator says Victor Medalist P250-500 Kent |
Similar Threads | ||||
Military falls on hard times in filling key jobs, report says | Otis Willie | Naval Aviation | 1 | November 26th 05 02:00 PM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
filling Oxygen tanks | Bruce McFadden | Piloting | 40 | January 3rd 05 03:25 AM |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
172 Nosewheel Struts Leak Nitrogen | jls | Owning | 4 | April 9th 04 06:28 PM |
