Re Dyneema Launch failures
We currently have 1 cable with Dyneema shock rope attached
to semi rigid strop with weak link and 1 cable with a more traditional 2/3rd in hemp rope, the hemp shock rope has more weight and makes cable drop clear quicker than the floaty Dyneema set up - it has been mentioned that we will return to the old setup as it appears safer |
Do you use a parachute?
Martin Roberts wrote: We currently have 1 cable with Dyneema shock rope attached to semi rigid strop with weak link and 1 cable with a more traditional 2/3rd in hemp rope, the hemp shock rope has more weight and makes cable drop clear quicker than the floaty Dyneema set up - it has been mentioned that we will return to the old setup as it appears safer |
Similar Threads | ||||
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Aerotow with Diesel engine? | Olfert Cleveringa | Soaring | 44 | November 2nd 04 10:22 AM |
spaceship one | Pianome | Home Built | 169 | June 30th 04 05:47 AM |
Vandenberg Launch, April 17 | Piloting | 5 | April 9th 04 02:21 AM |
