#41
How to run a wing?
On Aug 10, 11:23*pm, Derek C wrote:
On Aug 10, 8:36*pm, bildan wrote: On Jul 13, 4:46*pm, Grider Pirate wrote: On Jul 13, 3:14*pm, 150flivver wrote: On Jul 13, 1:33*am, Derek C wrote: On Jul 13, 12:31*am, Bob Whelan wrote: As for 'the silver bullet' in wing-tip-holding-methodology, I've (for many years now) asked my runners to let the wing rest on their flat palm, give me the best run they can, and let the tug pull the wing ahead/away from their open palm...no risk of a(n accidentally held-back) run; eliminates any winglet issues; never flown (or encountered) a glider with a downstream protuberance that could hang on anyone's hand (though I've little doubt one - somewhere - exists!). If you let the wing rest on the palm of your hand as a wing runner, how do you prevent the wing lifting off it in a crosswind, if a gust of wind comes through, or if the tug propwash gets underneath it? I personally hold the wing as lightly as possible between my thumb and first finger and at arms length. Some clubs I fly at also require the wing tip runner to signal, so the two-handed method would not be practical at these. Derek C As a tow pilot I'm looking for a rudder wag, radio call and or arm signal from the wingrunner that the sailplane is ready to launch. Lifting up the wing is gonna make me think that the glider's almost ready but until I see a positive launch signal I'm gonna be waitin' (and wondering if none of the three launch signals are forthcoming).- Hide quoted text - - Show quoted text - This was what I was taught to do: *Once the pilot signals readiness by giving me a thumbs up, I raise the wing to a wings level condition. After the wing is level, I allow it to climb or descend, to cue the pilot that he needs to apply some aileron to hold the wings level. *If the pilot doesn't get the clue, and the takeoff roll starts, I was taught again to allow the wing to move up or down SOME. *Most pilots 'get it' at this point, and start flying the wing. When I'm flying the glider, I prefer the wing runner to hold the wing as lightly as possible. *If there's a significant headwind, I often wave off the wing runner altogether. My pet 'wing runner' peave: Wing runners that 'help' by pushing forward on the wing tip. On Sunday, I flew 12 CAP Cadet orientation rides in an ASK-21. *The Cadets only training for wing running was the on-line wing runner course they swore they had taken before hand. *They had never touched a glider before. I added one additional instruction to what they had learned. *Instead of holding the wings "level", I told them to BALANCE the glider with their fingertips wherever it needed to be so there was no up or down force on the wing tip. *They were to run the wing at the angle where it balanced. *LEVEL was not applicable or important. In cooperation with the wing runners, I placed the stick in the exact center by reference to a mark on the instrument panel and held it there as long as the wing runner held the wing. I got 12 ABSOLUTELY PERFECT wing runs. *In most cases, I didn't have to move the stick until the glider was airborne. *I didn't care what hand they used or where they stood as long as they were safely outside/ behind the wing tip. *In fact, they don't even have to run at all if the glider starts out balanced - it'll take long enough for a wing to fall, the glider will have plenty of airspeed before any aileron is needed.- Hide quoted text - - Show quoted text - Obviously no crosswinds, gusts or thermals on that day? The ASK-21 has plenty of mass and stability, so it is the best possible candidate for this technique. May not work quite as well for many single seaters, especially if carrying water ballast, or if you have a tug aircraft that generates a lot of propwash (e.g PZL Wiga). Derek C Yes, there was a crosswind which is why it worked so well. It works even better with ballasted single seaters. |
#42
How to run a wing?
On Aug 11, 9:07*am, "Larry Goddard" wrote:
"bildan" wrote in message : On Jul 12, 10:30*am, Bart wrote: On Jul 11, 2:01*am, Bruce Hoult wrote: I disagree. Depending on conditions, the pilot might need a substantial amount of aileron in one direction of the other to keep the forces neutral. If I feel pressure on the wingtip while the slack is being taken up then I allow the tip to go markedly high or low until the pilot notices the glider is not level and applies the appropriate aileron.. That's what I like as a pilot, and that's how I will run a wing, unless the glider pilot requests a different technique. B. I observed this example. The pilot was holding full left aileron against a very light (2 - 3 Kt.) left crosswind component making the tip very heavy. *The wing runner, on the left wing, allowed the wing to go to the ground whereupon the pilot jerked his thumb up indicating he wanted the wing raised all the while still holding full left aileron. The wing runner did his best but when the wing was released, it slammed down and the glider ground looped. *The pilot jumped out and ran back demanding to know why the wing runner didn't know his job. The group of observers tried to tell the pilot it was his fault for holding left aileron but he insisted that was the right thing to do and it wasn't his fault. *He had a very hard time finding willing wing runners after that. My take home: *If I were the pilot, I'd center the stick and let the wing runner do the job right. *If I were the runner, I'd just put the wing down and walk away. If the pilot is not correcting properly when I have the wing "leveled", I will allow the wing to rise or drop according to what it wants to do so that the pilot will realize that he had the wrong inputs into the stick. *Seems to work every time. Larry That's the backup action. If the pilot is holding neutral aileron, the issue doesn't arise. |
#43
How to run a wing?
On Aug 11, 7:32*pm, bildan wrote:
On Aug 10, 11:23*pm, Derek C wrote: On Aug 10, 8:36*pm, bildan wrote: On Jul 13, 4:46*pm, Grider Pirate wrote: On Jul 13, 3:14*pm, 150flivver wrote: On Jul 13, 1:33*am, Derek C wrote: On Jul 13, 12:31*am, Bob Whelan wrote: As for 'the silver bullet' in wing-tip-holding-methodology, I've (for many years now) asked my runners to let the wing rest on their flat palm, give me the best run they can, and let the tug pull the wing ahead/away from their open palm...no risk of a(n accidentally held-back) run; eliminates any winglet issues; never flown (or encountered) a glider with a downstream protuberance that could hang on anyone's hand (though I've little doubt one - somewhere - exists!). If you let the wing rest on the palm of your hand as a wing runner, how do you prevent the wing lifting off it in a crosswind, if a gust of wind comes through, or if the tug propwash gets underneath it? I personally hold the wing as lightly as possible between my thumb and first finger and at arms length. Some clubs I fly at also require the wing tip runner to signal, so the two-handed method would not be practical at these. Derek C As a tow pilot I'm looking for a rudder wag, radio call and or arm signal from the wingrunner that the sailplane is ready to launch. Lifting up the wing is gonna make me think that the glider's almost ready but until I see a positive launch signal I'm gonna be waitin' (and wondering if none of the three launch signals are forthcoming).- Hide quoted text - - Show quoted text - This was what I was taught to do: *Once the pilot signals readiness by giving me a thumbs up, I raise the wing to a wings level condition. After the wing is level, I allow it to climb or descend, to cue the pilot that he needs to apply some aileron to hold the wings level. *If the pilot doesn't get the clue, and the takeoff roll starts, I was taught again to allow the wing to move up or down SOME. *Most pilots 'get it' at this point, and start flying the wing. When I'm flying the glider, I prefer the wing runner to hold the wing as lightly as possible. *If there's a significant headwind, I often wave off the wing runner altogether. My pet 'wing runner' peave: Wing runners that 'help' by pushing forward on the wing tip. On Sunday, I flew 12 CAP Cadet orientation rides in an ASK-21. *The Cadets only training for wing running was the on-line wing runner course they swore they had taken before hand. *They had never touched a glider before. I added one additional instruction to what they had learned. *Instead of holding the wings "level", I told them to BALANCE the glider with their fingertips wherever it needed to be so there was no up or down force on the wing tip. *They were to run the wing at the angle where it balanced. *LEVEL was not applicable or important. In cooperation with the wing runners, I placed the stick in the exact center by reference to a mark on the instrument panel and held it there as long as the wing runner held the wing. I got 12 ABSOLUTELY PERFECT wing runs. *In most cases, I didn't have to move the stick until the glider was airborne. *I didn't care what hand they used or where they stood as long as they were safely outside/ behind the wing tip. *In fact, they don't even have to run at all if the glider starts out balanced - it'll take long enough for a wing to fall, the glider will have plenty of airspeed before any aileron is needed.- Hide quoted text - - Show quoted text - Obviously no crosswinds, gusts or thermals on that day? The ASK-21 has plenty of mass and stability, so it is the best possible candidate for this technique. May not work quite as well for many single seaters, especially if carrying water ballast, or if you have a tug aircraft that generates a lot of propwash (e.g PZL Wiga). Derek C Yes, there was a crosswind which is why it worked so well. *It works even better with ballasted single seaters.- Hide quoted text - - Show quoted text - Would only work if the wing tip runner holds the downwind tip and runs pretty fast before letting go. The aileron response of a fully water ballasted glider can be pretty minimum until a good airspeed is reached, or there is a good headwind to start with. It may be necessary to hold the wings level for quite a few seconds before starting the launch to allow the water to equilibrate in the tanks or bags. Derek C |
#44
How to run a wing?
#45
How to run a wing?
This is not rocket science. Actually, if I hadn't witnessed the
confusion at Hobbs this summer and read some of the responses to this thread, I wouldn't have believed it possible that this subject could generate so much controversy. So permit me to add to it. The pilot keeps the stick neutral (that should only be a problem with a side stick). The wing runner BALANCES the wings (may take many seconds with water ballast). The wings may not be level when they're balanced if the ballast is uneven and/or there's a steady crosswind. The wing runner RUNS--holding the tip from the trailing edge, palm under/thumb over--until the wingtip flies out of the hand (i.e., don't hold it back). In normal US club and commercial operations, the wingtip runner doesn't raise the tip until the pilot is ready and he also signals the towplane to take up slack. At a contest, everything is specialized and the wing runner may do nothing but hold the tip to keep the wings balanced after the wingwheel is removed and then run like crazy when another ops person gives the signal. I personally don't want anyone touching the winglet but other pilots may think it's OK. Ask first. I've run tips where the aileron comes all the way out and never had a problem. If there's a gusty crosswind, the wing runner may have to work hard to prevent the upwind wing from being lifted. Ditto if the ballast shifts slightly. Or if a gust rolls through during the first few seconds of takeoff roll. If the glider has a tailskid instead of a rubber tailwheel or for some other reason it starts to swing (e.g., a Ka-6 or early ASW 15 with an off-center towhitch), a savvy wing runner can apply a bit of fore or aft force to help correct the direction. Don't try this unless you really know what you're doing or the pilot has asked you to because the glider has intentionally or accidentally been positioned off heading. When running a 1-26 or 2-33 with tip wheels towed by a strong towplane into a nice headwind on a cool day at sea level, you can probably take two steps and let go. When running a modern competition glider with water ballast on a narrow runway with a crosswind at higher altitudes when it's 100F behind the one of six tugs NO ONE wants to get because his engine is anemic, run as fast and as far as you can and hope for the best. As with most things in life, no single identical technique works every time. Chip Bearden ASW 24 "JB" USA |
Similar Threads | ||||
Low wing landing, high wing taking off...oops | [email protected] | Piloting | 1 | May 16th 08 09:41 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 11:10 AM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
