Alternative to IPAQ PDA's
Old August 8th 06, 11:16 AM posted to rec.aviation.soaring
marc_dg400
Default Alternative to IPAQ PDA's
Hello,
since I was robbed of my ipaq 3970 running winpilot,
i am looking for an alternative. 2nd hand ipaq's can be found but are
relatively expensive compared with modern alternatives .(which have
wifi , GPS etc..)
I have been looking at the asus 636 and the mio P550 . Both have build
in GPS , which can be usefull when the electrics of the glider die.
The have no serial port however . Only HP still features serial ports
to connect to , for example , your LX5000.
The serial port can be usefull to download the flight log , connect to
LX5000 for winpilot pro etc.
However , serial ports are dissapearing slowly.
The battery of the asus seems to be very good , however , an external
12V will propably be needed.
Any experience around concerning
-stability
-GPS antenna reception
-screen brightness ?
Any alternatives ?
Thanks
Marc
DG400
Old August 8th 06, 08:59 PM posted to rec.aviation.soaring
palombian
no PDA is perfect for all use
buy a second hand IPAQ 3850 or 3950 on eBay for your glider
and the latest fancy mobile for yourself
JW
"marc_dg400" wrote in message
Hello,
wifi , GPS etc..)
-stability
Any alternatives ?
Thanks
Marc
DG400
Old August 11th 06, 03:43 AM posted to rec.aviation.soaring
Perhaps this is an apt replacement ?
http://www.boatersworld.com/product/...g%3Bcianc hor
Old August 11th 06, 01:19 PM posted to rec.aviation.soaring
Bullwinkle
On 8/10/06 8:43 PM, in article
http://www.boatersworld.com/product/...03%3Bcidocking
%3Bcianchor
Dave,
I have no experience with those kinds of people, so perhaps you can explain
why a hooker requires an anchor? Or is that too kinky to explain on a public
newsgroup? (;-O)
Bullwinkle
Old August 11th 06, 02:10 PM posted to rec.aviation.soaring
COLIN LAMB
The anchor is for use after you are through with the hooker
Old August 11th 06, 04:22 PM posted to rec.aviation.soaring
kirk.stant
It's also useful to keep your boat from drifting in front of a barge
while you are busy "interviewing" the hooker...
66
LX20 + Ipaq wiring Bruce Soaring 2 February 4th 06 10:40 PM
Ipaq and Sunglasses Ray Lovinggood Soaring 2 June 27th 05 08:25 PM
Commercial - iPAQ Cradle Changes Paul Remde Soaring 0 April 9th 04 03:29 PM
iPaq wiring, cradles and mounts for gliders - Ideas?? Jim Kelly Soaring 12 December 4th 03 11:45 PM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
