Using the 430
Old June 5th 04, 03:50 PM
PaulaJay1
Default Using the 430
I tried something with my Garmin 430 yesterday that worked out well so I
thought I would pass it along.
I was doing a series of practice approaches to the area airports that are 10
miles or so apart. The problem was setting up for the next approach while
climbing out from the last. With only a few miles, it was easy to over run the
IAF during setup.
So I put all the airports in a flight plan before takeoff (doesn't matter the
order). Then at any time you can call up the flight plan and with the curser
select any of the airports and do a "direct to". Then select the approach and
you are finished. After the first approach select the flight plan again,
curser to the next airport, "direct to",etc. Sure faster that entering the
next airport identifier one character at a time.
Chuck
Old June 5th 04, 03:58 PM
Bravo Delta
Or you can call up the nearest airport list and go direct to one of them,
then you don't have to mess with creating a flight plan.
"PaulaJay1" wrote in message
10
run the
IAF during setup.
curser
and
Chuck
Old June 6th 04, 04:42 PM
Jerry Kurata
You can also stack the approaches into a flight plan if you know the order
your going to fly them.
Old June 7th 04, 02:47 PM
Dave Butler
IAF during setup.
On the GX50/GX60, the airport has to be the last element in the flight plan in
order to load an approach for it. Evidently that's not true for the 430.
Dave
Old June 8th 04, 04:22 PM
PaulaJay1
In article , Dave Butler
writes:
curser
and
in
Same with the 430 if you are flying the flight plan. I am using the flight
plan only to store the identifiers ( which I can load before the takeoff). For
each approach I bring up the flight plan, curser to the airport of choice, and
do a "direct to". The flight plan remains stored to be used for the next
approach by again cursering to the airport of choice, etc.
Old June 8th 04, 04:59 PM
Dave Butler
in
AFAIK in order to do an approach with the GX50/60 you MUST be flying the flight
plan. If you do a DIRECT TO and want to do an approach at the end of the DIRECT
segment, the DIRECT TO must become the flight plan. You specifically can not do
an approach at an airport that's an intermediate waypoint in the active flight
plan. The destination airport for the approach has to be at the end of the
flight plan.
Do you still say "same with the 430"? I have no experience with the 430..
Dave
Remove SHIRT to reply directly.
Old June 8th 04, 08:09 PM
PaulaJay1
writes:
For
and
flight
DIRECT
do
flight
flight plan.
Well, I checked it out on simulator on my PC. Yes, the approach and hold does
get put at the end of the flight plan even tho you may have selected airport
number 2 out of say a list of 4. However, the list of the 4 airports remains
in the flight plan above the approach and hold. So you can call up the flight
plan and page up to select another airport and then "direct to". Again, the
approach and hold is placed at the end of the flight plan with the first
approach removed and the second one in place.
Chuck
