WTB Blanik Tow Bridle for L13 or L23
Anyone have one to sell, not being used?
To reply to address, remove "nospam" Thank you. Karen |
I did not realize the L-23 needed the bridle.. I thought (at least the ones
I've been associated with) L-23s came with a TOST CG hook. BT " wrote in message oups.com... Anyone have one to sell, not being used? To reply to address, remove "nospam" Thank you. Karen |
BTIZ wrote: I did not realize the L-23 needed the bridle.. I thought (at least the ones I've been associated with) L-23s came with a TOST CG hook. Some have it. I have two Blanik L-23's for training and checkrides at Marfa. One has the side bridal attachments like on the L-13, the other has the CG hook. Both have nose hooks, of course. Keep those side bridal release mechanisms clean and lubricated as they are activated by the same yellow release handle as your nose hook, and can get a bit sticky. Check them often even if you are not using them. I use Kroil brand aviation spray lubricant. Burt Marfa Gliders, west Texas USA |
Thanx Burt.. I'm only familiar with the newer CAP L-23s.
Bill "Burt Compton - Marfa" wrote in message oups.com... BTIZ wrote: I did not realize the L-23 needed the bridle.. I thought (at least the ones I've been associated with) L-23s came with a TOST CG hook. Some have it. I have two Blanik L-23's for training and checkrides at Marfa. One has the side bridal attachments like on the L-13, the other has the CG hook. Both have nose hooks, of course. Keep those side bridal release mechanisms clean and lubricated as they are activated by the same yellow release handle as your nose hook, and can get a bit sticky. Check them often even if you are not using them. I use Kroil brand aviation spray lubricant. Burt Marfa Gliders, west Texas USA |
Similar Threads | ||||
Blanik L-13 CG Tow Bridle | [email protected] | Soaring | 1 | June 11th 06 11:15 PM |
Q: Bridle hooks for Blanik L13? | Roger Worden | Soaring | 2 | March 4th 06 12:59 AM |
Blanik tire problem | Greg Arnold | Soaring | 5 | September 30th 05 06:02 PM |
Is a Blanik L-33 rugged enough for a club? | Val | Soaring | 0 | May 14th 04 02:23 AM |
Is a Blanik L-33 rugged enough for a club? | jeff rothman | Soaring | 19 | May 13th 04 06:17 AM |
