Turbo prop question
Old April 29th 08, 03:23 AM posted to rec.aviation.piloting
muff528
Default Turbo prop question
"muff528" wrote in
news:SMuRj.25645$TS5.1624@trnddc08:
"muff528" wrote in
news:krtRj.968$lc6.775@trnddc04:
wrote in news:e508d435-db20-4b21-9c9b-
On Apr 25, 4:37 am, Bertie the Bunyip wrote:
wrote in news:de5298d4-778b-475f-9321-
On 25 Apr, 11:53, Frank Olson
Chris W wrote in
news:74gQj.67968$y05.19485 @newsfe22.lga:
I was channel surfing the other day and caught the tail end
of
some
show
about rich people and their planes. Anyway the pilot of
this
one
single
engine turbo prop said there was no mechanical connection
between
prop and engine. How can that be?
It's a free turbine. Most modern turboprops use that system.
There's a
seperate turbine that runs the prop geabox. He's technically
incorrect
since that turbine is part of the engine...
Bertie
Rich people. More money than brains.- Hide quoted text -
I'm not in disagreement with Bertie, wouldn't dare, but it
"could be" electric drive, hydraulic drive.
Nah, not on a turbine.
These are used in other vehicles. Most cars in the US
use an automatic transmission that includes a
torque convertor for example.
I am sure that it is in this case a free turbine - gas drive -
that connects to a propellor - gas-gas drive.
http://www.gasgas.com/index.shtml
Yeah, almost all modern turboprops use this system. Some of the
older ones, like the RR Dart or the Allisons were gear driven off
the main turbine, but this is all but abandoned these days. In
fact, even
"jets"
are really just ducted fan turboprops with the fan driven by a
turbine
in the exhaust.
Bertie
The Garrett TPE 331 is still a fixed turboprop. Lots of
those
flying, especially on some upscale kitplanes. Isn't the Swearingen
Merlin powered by those, too?
http://www.aircraftenginedesign.com/pictures/TPE331.gif
Dan
Yeah, Garret are one of the holdouts. They're on alot of airplanes.
the Metro, the turbine commanders. I think there's a Walter that's
in th esame class being used on quite a few airplanes as well. The
Pratts are all free turbines, AFAIK. The older ones are centrifugal
engines with a revese flow, that is, the intake is on the back and
they exhaust in front, which is why the PT6 's have those
stovepipes just behind the prop, and the newer 120 and newers are
axial with the air coming in the front and the fire going out the
back. The 120 has a prop brake with which you can stop the prop
while the engine is running ( on the ground) and use the engine for
an APU.
Bertie
Amazing how after a while you can tell the difference between the
Pratts and the Garretts from the ground while the plane is at 13,500
ft above you. Many times we had a Twin Otter with Pratts and a Casa
212 with Garretts flying on the same day and you could tell which
was on jump run just by the sound. I just assumed it was because of
the different methods of coupling the props to the powerplant.
!!! I don't think I could except by seeing the airplane. Yeah, you
get tuned in to any engine you're familiar with, though, don't you?
Bertie
Yeah, I think the fact that they were flying within a few minutes of
each other all day makes the comparison easier. The main difference
seems to me to be the "loudness" of the beat freq. generated by
slightly "out-of-sync" props, especially when the "cut" occurs just
before exit time. The Garretts sounded "gutsier" for lack of a better
term and the beat frequency amplitude was much greater than the PT6's.
Even during the climbout to jump altitude the Garretts seemed to sound
more authoritative. But that brings up another question that I have
wondered about. For a twin, for example, does the force of the
atmosphere pushing against the props have an "equalizing" effect on
the propeller speeds of turbine-coupled props on slightly out-of-sync
engines? I would intuitively think that such a moderating effect would
account for differences in beat sounds between them and direct-coupled
twins which were a few rpm's out.
Well, I've only flwon one type with the turbine directly geared to the
prop and it was a single lever operation which meant you were altering
the power as well as the prop pitch whne you mover the lever. it had no
autosynch so you did it the old fashioned way and it was out of synch a
good bit of the time. I can't remember hat we had in the King Airs I
flew, but the PW120 had an autosynch so that might account for it.
Bertie
Thanks, I never thought of propellers as such complex devices. Dan's link to
Hartzell was pretty informative.
TP
Old April 29th 08, 04:03 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"muff528" wrote in
news:REvRj.11461$Rk6.9130@trnddc07:
"muff528" wrote in
"muff528" wrote in
wrote in
Chris W wrote in
end of
some
show
this
one
single
between
system.
There's a
technically
incorrect
Bertie
- that connects to a propellor - gas-gas drive.
off the main turbine, but this is all but abandoned these days.
In fact, even
"jets"
turbine
in the exhaust.
Bertie
those
Swearingen Merlin powered by those, too?
Dan
airplanes. the Metro, the turbine commanders. I think there's a
Walter that's in th esame class being used on quite a few
airplanes as well. The Pratts are all free turbines, AFAIK. The
older ones are centrifugal engines with a revese flow, that is,
the intake is on the back and they exhaust in front, which is why
the PT6 's have those stovepipes just behind the prop, and the
newer 120 and newers are axial with the air coming in the front
and the fire going out the back. The 120 has a prop brake with
which you can stop the prop while the engine is running ( on the
ground) and use the engine for an APU.
Bertie
13,500 ft above you. Many times we had a Twin Otter with Pratts
and a Casa 212 with Garretts flying on the same day and you could
tell which was on jump run just by the sound. I just assumed it
was because of the different methods of coupling the props to the
powerplant.
Bertie
better term and the beat frequency amplitude was much greater than
the PT6's. Even during the climbout to jump altitude the Garretts
seemed to sound more authoritative. But that brings up another
question that I have wondered about. For a twin, for example, does
the force of the atmosphere pushing against the props have an
"equalizing" effect on the propeller speeds of turbine-coupled props
on slightly out-of-sync engines? I would intuitively think that such
a moderating effect would account for differences in beat sounds
between them and direct-coupled twins which were a few rpm's out.
the prop and it was a single lever operation which meant you were
altering the power as well as the prop pitch whne you mover the
lever. it had no autosynch so you did it the old fashioned way and it
was out of synch a good bit of the time. I can't remember hat we had
in the King Airs I flew, but the PW120 had an autosynch so that might
account for it.
Bertie
link to Hartzell was pretty informative.
On the fixed shaft turboprops they're extremely complex. All sorts of
gadgets on them to keep them under control. on the old Allisons the most
common reason for shutdown by far was a prop problem of one type or
another. but giving your observation about the Garret vs PW it's
probably due to the Garret fineing off as the throttles close as opposed
to the Pratts where they do, but not so much...
Bertie
Old April 29th 08, 05:31 AM posted to rec.aviation.piloting
K l e i n
On Apr 28, 9:03*pm, Bertie the Bunyip wrote:
"muff528" wrote innews:REvRj.11461$Rk6.9130@trnddc07:
"muff528" wrote in
"muff528" wrote in
. 130...
wrote in
Chris W wrote in
end of
some
show
about rich people and their planes. *Anyway the pilot of
this
one
single
between
prop and engine. *How can that be?
system.
There's a
technically
incorrect
Bertie
Rich people. *More money than brains.- Hide quoted text -
In fact, even
"jets"
turbine
in the exhaust.
Bertie
* * * * The Garrett TPE 331 is still a fixed turboprop. Lots of
* * * * those
* Dan
Bertie
powerplant.
Bertie
account for it.
Bertie
Bertie- Hide quoted text -
- Show quoted text -
Here are a few numbers for you (taken from my Flight Safety big book
on the Twin Commander 1000). This airplane uses the Garrett TPE331-10
engines with 1000 shaft horsepower, flat rated back to 800 hp. The
800 hp are available up to 18,000 ft. Naturally, this means these
airplanes climb like scalded cats (3000+ fpm.) The engine has all the
turbines on a single shaft which runs at 41,730 rpm maximum. Cruise
rpm is 96-100%. This shaft is geared down by a planetary gear
reduction with 26:1 ratio, giving a max prop rpm of 1591 rpm. Engine
rpm is pretty much controlled by propellor blade angle. A Beta mode
(reverse thrust) is available for ground use only. No question about
it, they are very loud. Even in ground idle mode, the prop rpm is 65%
of max. One always receives the Twin Commander salute (index fingers
in both ears) from anybody standing around on the ramp. One advantage
of the single shaft design is fuel efficiency. The airplane cruises
at 300+ knots true at 26,000 ft on 80 gph after a maximum gross weight
takeoff of 11,700 lbs. Try that in your P&W turboprop. ;-) Beside
the Twin Commanders, these engines are also used in the Mitsubishi
MU-2. TBO on the engines is 5,000 hours with a hot section inspection
at 2500 hours.
K l e i n
Old April 29th 08, 12:02 PM posted to rec.aviation.piloting
muff528
at 2500 hours.
K l e i n
Yes!.........LOUD...........That's the word I was looking for! :-))
Always a treat to get on a Casa load and watch runway rapidly drop away
through the open tailgate when the pilots decided to do a "high-performance"
takeoff.
With 23-24 people sitting toboggan-style on the floor the only outside view
is through the tailgate.
TP
turbo prop first officer needed pcj Piloting 0 October 27th 04 05:13 AM
turbo prop first officer needed pcj Piloting 2 October 27th 04 05:07 AM
Turbo prop AT-6/SNJ? frank may Military Aviation 11 September 5th 04 02:51 PM
Piston V.S Turbo Prop Vigo Owning 10 July 2nd 04 06:15 PM
A36 Bonanza turbo prop Jeff Owning 46 January 7th 04 02:37 PM
