Types of Waypoints
Old January 9th 05, 06:06 AM
Gene Whitt
Default Types of Waypoints
Y'All,
I've been digging through FAA-H-8261-1 Instrument Procedures Handbook and
cannot find the answer clearly stated.
I would like to know in what respects the following types of waypoints are
differentiated by creation, useage, and otherwise.
A source text would be helpful as well.
Charted waypoint
Floating waypoint
Phantom waypoint
Gene Whitt
Old January 9th 05, 01:34 PM
I work with ARINC 424 RNAV specs all the time, and have never heard those
terms.
Gene Whitt wrote:
Y'All,
Charted waypoint
Floating waypoint
Phantom waypoint
Gene Whitt
Old January 9th 05, 02:39 PM
Cheetah236
waypoints are
Charted waypoint
Floating waypoint
Phantom waypoint
I think the Phantom waypoint might just be any that doesn't exist in
the database. For example, on MMV VOR/DME or GPS-B approach,
(http://www.naco.faa.gov/d-tpp/0413/05626VDGB.PDF), UBG 13.5 DME is the
last stepdown fix but is not in the GPS database. It can be legally
calculated as the DME difference between it and the MABEZ intersection
(MAP).
My NOrthstar GPS manual refers to what they call a phantom waypoint
that is created by using the lat/lon from a Loran. They acknowledge in
the manual that this could be inaccurate given any reception anomalies
in the area. (And of course would be illegal to use in any primary IFR
operations).
My _guess_ is that, in this context, a charted waypoint would be in the
database instead of home-brewed?
Old January 9th 05, 04:36 PM
kage
These are FMS terms. A charted waypoint is just that, one on the charts, and
it's in the box. A floating waypoint is one which the FMS computes, like TOD
(top of descent), it's position changes with groundspeed.
A phantom waypoint is one where the pilot builds a waypoint in the box. Say
your clearance is out the 270SEA radial to intercept some other radial. It
is often easier to build a waypoint at the intersection than to mess with
VHF nav. FMS likes to go point to point.
Karl
"Cheetah236" wrote in message
waypoints are
Charted waypoint
Floating waypoint
Phantom waypoint
(MAP).
operations).
Old January 9th 05, 09:29 PM
Gene Whitt
Karl, et al,
Thank you for the information. Is is so much like the FAA to print a
text for all of aviation without clarifying the level of aircraft involved
and the equipment required.
I am in the process of making a selective revision of the material so that
the inappropriate material for Part 91 pilots is mentioned but not
emphasized.
Gene
"kage" wrote in message
and it's in the box. A floating waypoint is one which the FMS computes,
like TOD (top of descent), it's position changes with groundspeed.
Say your clearance is out the 270SEA radial to intercept some other
radial. It is often easier to build a waypoint at the intersection than to
mess with VHF nav. FMS likes to go point to point.
Karl
waypoints are
Charted waypoint
Floating waypoint
Phantom waypoint
(MAP).
operations).
How come you ATC types ALWAYS know Ash Wyllie Instrument Flight Rules 7 August 16th 04 11:01 PM
Exotic New Aircraft Types Added Tim Home Built 0 November 21st 03 07:10 PM
Rare aircraft types photographed Bob Home Built 0 October 17th 03 08:27 PM
Terminology of New WAAS, VNAV, LPV approach types Tarver Engineering Instrument Flight Rules 2 August 5th 03 03:50 AM
