Safety Pilot Qualification?
Old November 22nd 03, 06:31 PM
Ron Natalie
"Casey Wilson" wrote in message ...
I've been following this thread all along. It seems to me the simple answer
at the very beginning is that the "safety pilot" must be legal to fly the
airplane, period.
Your simple answer is wrong. The safety pilot only need posess a private (or better) pilot
certificate with category and class ratings and a medical. He is not required
to meet the specific pilot in command requirements (currency, BFR, HP/complex
endorsements) etc... unless he is specifically serving in that role.
Here are the only two rules that apply to safety pilot qualifications:
91.109
(b) No person may operate a civil aircraft in simulated instrument flight unless -
(1) The other control seat is occupied by a safety pilot who possesses at least a private
pilot certificate with category and class ratings appropriate to the aircraft being flown.
61.3(c)
(1) Except as provided for in paragraph (c)(2) of this section, a person may not act as pilot in command or in any
other capacity as a required pilot flight crewmember of an aircraft, under a certificate issued to that person under
this part, unless that person has a current and appropriate medical certificate...
Nowhere does it say he has to be "qualified to fly the plane." His role is to provide the
see-and-avoid vigilance that the hooded pilot can not provide.
Old November 23rd 03, 12:53 AM
Casey Wilson
answer
airplane, period.
(or better) pilot
required
HP/complex
91.109
unless -
least a private
61.3(c)
certificate...
is to provide the
Well, Ron(s), on at least two occasions while acting as safety pilot I
have assumed control of the aircraft. First, when the hooded pilot blew an
approach and started wandering diagonally across the airport and second when
I had to take evasive action to avoid another aircraft.
But those aside, you cited 91.109(b)(1) above. I don't know any other
way to interpret that other than being qualified for "...the aircraft being
flown." I contend that with my SEL certificate, I may NOT act as safety
pilot in a twin-engine aircraft, nor may I act as safety pilot for an
aircraft on floats. On the other hand, the fact that I have zero time in a
V-35 does not mean I can't go there.
I think you are playing with semantics. Qualified does not mean "checked
out in."
Old November 23rd 03, 02:10 AM
Roy Smith
My standard safety pilot briefing lays out my groundrules. The safety
pilot never touches the controls. First step in traffic avoidance is to
give me a heading to fly. If that's not working, he's to tell me to
take the hood off and point the traffic out to me.
I'm relying on his judgement as a pilot to decide what constitutes safe
separation and to come up with reasonable vectors, but that's it. My
job is to fly the plane. His job is to be my eyes.
In the two situations you cite above, would it have worked to have told
the pilot to take the hood off and go visual?
If you want your safety pilot to take the controls, that's fine. But
make sure you go over expectations, responsibilities, and procedures for
transfer of control before starting up. Close to the ground or close to
traffic is the last place you want there to be any confusion about who's
flying the airplane.
Old November 23rd 03, 03:20 AM
Casey Wilson
"Roy Smith" wrote in message
I
an
when
I have, according to my logbook, only nine entries as safety pilot. To
my recollection, in every case we talked about under what conditions I would
assume controls...not that I would NEVER touch them.
In the first case perhaps he would have eventually gotten it together --
I didn't think so. My first action was to tell the pilot he was drifting way
to the right of centerline after he executed a missed. When he did nothing
to correct, I got the feeling he was very disoriented and assumed control.
When he took the hood off moments later he looked flustered.
In the second case, it was my judgement that immediate action had to be
taken when ATC called "Traffic Alert." The only other earlier call from ATC
(flight following) was that the other aircraft was "...five miles and
climbing, no radio contact." Should I have seen the other plane. I dunno, it
was white against an overcast and virtually motionless. Maybe, maybe not.
Old November 23rd 03, 04:43 AM
Ron Rosenfeld
On Sun, 23 Nov 2003 00:53:56 GMT, "Casey Wilson"
aircraft on floats.
That is certainly true since the safety pilot must have "category and class
ratings appropriate to the aircraft being flown". Twins and seaplanes are
in a different class.
That has nothing to do with the fact that you can be safety pilot in an SEL
a/c for which you could not legally act as PIC.
Old November 23rd 03, 02:34 PM
Roy Smith
That's fine, as long as you both understood the situation so there would
be no surprises. Did you also talk about HOW you would assume control?
Consider the following conversation:
ATC: Cessna 123, traffic one o'clock and a mile, southbound, climbing
out of 3000.
Safety: I've got it.
Pilot Flying: OK
How is the pilot flying to interpret "I've got it"? Does it mean "I see
the traffic", or does it mean, "I'm assuming control"?
How is the safety pilot to interpret "OK"? Does it mean "Now that you
see the guy, I assume you're going to keep your eye on him", or does it
mean, "I'm releasing the controls to you"?
One is the right number of people to be in control of the plane at any
given time. Either zero or two is asking for trouble. Take a couple of
minutes before the flight to make sure you know how you're going to work
things.
Was drifting to the right of centerline a bad thing? If the missed
procedure said, "fly runway heading" and there was a crosswind from the
left, you're going to drift to the right. That's the way it works.
If you never saw the other plane, what information did you have which
put you in a better position than the pilot flying to make an evasive
maneuver? You both heard the same radio calls and neither of you had
visual contact with the traffic.
Old November 24th 03, 03:05 PM
Ron Natalie
Correct, I was just trying to point out that category and class is the limit to the
requirements as far as the FAA is concerned. No tail dragger, complex, or high
performance endorsements are required. Nor is their any requirement for currency
or flight reviews on the part of the safety pilot. I never said "checked out" anywhere.
The FAA has no concept of "checked out."
Old November 24th 03, 03:07 PM
Ron Natalie
Tlhe safety pilot's regulatory job is to not back up deficient pilots in case
they can't hold it together under the hood. They are mandated to be there
to provide the see-and-avoid vigilance. If you want to play flight instructor
by providing other services to the pilot, you'll have to work that out with them
but it's immaterial to what we were talking about here.
Pilot Error? Is it Mr. Damron? Badwater Bill Home Built 3 June 23rd 04 04:05 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 05:39 AM
Share time in Sacramento - Safety pilot needed J Instrument Flight Rules 0 September 26th 03 01:55 AM
Logging instrument approaches Slav Inger Instrument Flight Rules 33 July 27th 03 11:00 PM
