Aspen at night
Old January 2nd 06, 09:33 PM posted to rec.aviation.ifr
Default Aspen at night
All the approach plates for Aspen are marked "Procedure not authorized
at night" (presumably a result of the G4 crash a few years back). And
yet there are commercial flights scheduled to land as Aspen at night.
How do they do it?
rg
Old January 2nd 06, 09:40 PM posted to rec.aviation.ifr
snip
Actually, that night prohibition was in effect when the Gulfstream III
crashed. I recall reading that this was one of the pressures the two
pilots were under to land there, as they were late leaving the LA area.
http://www.ntsb.gov/ntsb/brief.asp?e...12X00738&key=1
Peter
Old January 2nd 06, 10:35 PM posted to rec.aviation.ifr
How do they do it?
rg
Special, carrier-specific authorizations based on specialized,
FAA-approved training and airport familiarity requirements.
Old January 3rd 06, 02:14 AM posted to rec.aviation.ifr
"Ron Garret" wrote in message
How do they do it?
rg
Maybe they only fly in VMC?
Old January 3rd 06, 02:17 AM posted to rec.aviation.ifr
Private non-published approach.
not authorized
back). And
Aspen at night.
| How do they do it?
| rg
Old January 3rd 06, 07:10 AM posted to rec.aviation.ifr
In article N9luf.38962$QW2.6921@dukeread08,
Cool. How do I get me one of those?
rg
Old January 3rd 06, 03:52 PM
clipclip clipclip is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
rg
it's not hard. all it takes is $75-150G's of loose change available to burn rather quickly. then you hire a consulting firm specialised in approaches to draw one up and with minimums tailored to your specific on board equipment and flight crew experience levels (and hope that the minimums are not so high that they're actually useful). then you submit about 50 pounds of paper adorned with letters, numbers and pictures arranged in nice color coordinated patters to the FAA, convince them that you've met all the requirements, fly it a few times with an approved FAA rep, and wallah! you (and your co-pilot) can now take your FLIR equipped G5 in at night.
frank
Old January 4th 06, 02:18 AM posted to rec.aviation.ifr
rg
frank
I like your spin. ;-)
Actually, NetJets has been trying for about three years to get an RNP
advanced procedure into ASE. Their approach path is great, but the
missed approach requires sterling, uninterrupted climb performance.
And, even as good as their concept is, once you get below MDA (or
perhaps DA) and get further behind, missed approach wise, at ASE you are
screw blue missing in a balked landing scenerio.
ASE simply should not be an IFR airport, politics aside.
Old January 4th 06, 02:47 AM posted to rec.aviation.ifr
An AV-8B should have no real problem, if the engine works.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
news:VeGuf.5672$V.531@fed1read04...
| clipclip wrote:
| "Jim Macklin"
| rg
change available to
specialised in
your specific
(and hope that the
then you submit
and pictures
convince them
with an
can now take your
| frank
get an RNP
great, but the
performance.
MDA (or
at ASE you are
Old January 4th 06, 11:20 AM posted to rec.aviation.ifr
Tim, is the US possible going to accept the Panops method of allowing
the application of climb gradients to missed approach segments? After
all, we're expected to be able to perform this ** sterling,
uninterrupted climb performance ** that you mention, on a departure
anyway. So to apply a missed approach gradient requirement when an
aircraft is generally lighter than on departure would be something a
lot of aircraft would be able to execute. Of course, I realize that
those in power would bring up many other issues, but it works in
Europe, and Burbank in Calif already seems to have a waiver for a
gradient greater than 2.5%
Or is Netjets talking less obstacle clearance than present RNAV (gps
or waas) approaches.
Stan
FAA PPL night flight requirement - does it have to be DUAL? Peter Clark Piloting 21 January 6th 05 12:38 AM
Night solo XC? G. Burkhart Piloting 51 October 14th 04 03:11 PM
Night of the bombers - the most daring special mission of Finnishbombers in WW2 Jukka O. Kauppinen Military Aviation 4 March 22nd 04 11:19 PM
