Apis M Owners
Old August 21st 20, 07:23 PM posted to rec.aviation.soaring
Frank Sanches
Default Apis M Owners
Hello, my name is Frank and I recently bought an Apis M 15m 2005 with 300tt hours and 40 engine hours. The glider is very new.
Does someone has any tips to give me about this glider, and if it's easy or some particular thing in flight? I just flew gliders, this is my first motorglider.
Thanks everyone, good flights for all.
Old August 21st 20, 07:54 PM posted to rec.aviation.soaring
son_of_flubber
Is it painted or gel-coated?
Old August 21st 20, 09:42 PM posted to rec.aviation.soaring
Frank Sanches
Em sexta-feira, 21 de agosto de 2020 Ã*s 15:55:00 UTC-3, son_of_flubber escreveu:
Gel-coated, will need to repaint, but I will fly this season and repaint in next year. Gel-coat it's not very well. I bought it from South Africa. I'm from Brazil.
Old August 21st 20, 09:57 PM posted to rec.aviation.soaring
son_of_flubber
A friend of mine has an Apis M of similar vintage/hours at 10 degrees higher latitude and it likewise had gel-coat rot. He thought that the rot was premature.
Old August 22nd 20, 11:50 PM posted to rec.aviation.soaring
Frank Sanches BR
Em sexta-feira, 21 de agosto de 2020 Ã*s 17:57:53 UTC-3, son_of_flubber escreveu:
Do you know if he painted in PU or is still in gel-coat?
Old August 23rd 20, 11:35 PM posted to rec.aviation.soaring
Soartech
It is still in the process of refinishing with Urethane paint. Should be done soon. It's taking a long time!
The person doing the refinishing told me that many sailplanes made in Europe and eastern Europe in the period around 2000 to 2006 did not have UV protection in the gel coat due to some substance being banned because of environmental laws. He said he has refinished many from this period.
Old August 23rd 20, 11:47 PM posted to rec.aviation.soaring
Soartech
Frank, the glider is easy to fly and has no bad habits as far as I can tell.. I have 300 hours on it. The self-launch is easy. Taxi to the launch point and run through your check list. Be sure your spoilers are closed and locked or you will not be able to climb normally. Normal is about 500 fpm. Hold the stick full back (to prevent the nose from hitting the ground) and give it full throttle. When you reach about 15 knots move the stick forward to about center and let the tail come off the ground. Keep it balanced on the main wheel and it will take off soon when it is ready. Keep the speed at 49 knots during climb out.
APIS 13 [email protected] Soaring 0 August 28th 18 03:11 AM
Beech Duke Owners/ex-Owners ple help... Stanley Owning 12 June 10th 16 12:36 AM
Apis M has arived Robertmudd1u Soaring 0 January 31st 04 01:50 AM
Apis report Apis Gliders Soaring 0 September 10th 03 08:34 PM
