Vne
Old November 9th 19, 06:49 PM posted to rec.aviation.soaring
jp
Default Vne
I know that Vne can vary with altitude but does it also vary with aircraft weight?
Old November 9th 19, 08:21 PM posted to rec.aviation.soaring
Never Again 2
Default Vne
aircraft
weight?
Yes
Old November 9th 19, 08:23 PM posted to rec.aviation.soaring
Never Again 2
Default Vne
aircraft
weight?
Yes
Old November 9th 19, 08:53 PM posted to rec.aviation.soaring
Charlie Quebec
Default Vne
Onlynif over max weight and with an engineering order. Within the certified weight range, it stays the same.
Old November 9th 19, 10:45 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Vne
Charlie Quebec wrote on 11/9/2019 12:53 PM:
It may depend on the glider, particularly gliders that carry ballast in the wings.
My guess is pilot weight would have such a small effect, it would not mentioned in
the operating handbook.
Old November 10th 19, 02:22 AM posted to rec.aviation.soaring
Charles Longley
Default Vne
I’ve never seen it vary by weight. Check your POH of course
Old November 10th 19, 04:15 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Vne
Charles Longley wrote on 11/9/2019 6:22 PM:
Now I'm wondering if it's a regulatory requirement that the Vne be set that works
for all allowed weights.
Old November 10th 19, 05:17 AM posted to rec.aviation.soaring
Echo
Default Vne
Ehhhhhhh no. In our very sub supersonic world Vne is based on how fast the molecules actually go over the wing, which is the contributing factor to flutter. That's Vne, more specifically, it's given as a True Air Speed because that's the actual speed against molecules. Now what DOES change is the indicated speed for Vne, since IAS is a function more of HOW MANY molecules are getting rammed into the pitot tube. It's important to know those numbers as you descend out of wave. Vne as marked on the gauge red line is invalid up at the higher altitudes. Flying out west up high it may be more like 110kts indicated when the TAS is actually at redline.
Old November 10th 19, 08:35 AM posted to rec.aviation.soaring
Duster[_2_]
Default Vne
Hmmm, I thought Vne Is basically a guess by the FAA that 10% below Vd is safer than 5% below Vd. Vne = 0.9 X Vd (FAR/JAR 23), dive speed Vd determined emperically and is a function of design cruising speed Vc.
Old November 10th 19, 03:02 PM posted to rec.aviation.soaring
Echo
Default Vne
Haven't read that, would be an interesting one though. I'd always been under the impression Vne is a flutter protection speed. That's why it's a TAS that doesn't change with weight like Va. Wouldn't be surprised if it was from some old math though.
