An amphibian that sank?
Old April 23rd 06, 09:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default An amphibian that sank?
http://www.divingservices.net/aircraft.jpg
http://www.divingservices.net/9bcess2.jpg
Anyone have the story behind this? Strange that a plane designed to
float, sank!
The Monk
Old April 23rd 06, 10:01 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Flyingmonk" wrote in message
float, sank!
Doesn't seem any stranger than a boat sinking. I believe they're designed
to float as well.
Old April 23rd 06, 10:12 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
float, sank!
The Monk
I could be wrong, but wasn't the Titanic designed to float?
DH
Old April 23rd 06, 10:27 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
float, sank!
It broke the law . . . . Law of gravity
(and the law won)
Old April 23rd 06, 11:07 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Steven P. McNicoll" wrote in message
ink.net...
to float as well.
These days, smaller boats often have flotation chambers filled with a closed
cell type foam (e.g. styrofoam) so that in the even that they are filled
with water, they might still remain on the surface, dependent upon what else
might be loaded in the boat... It wasn't always that way though... I've
helped recover sunken boats before that sank after hitting logs and such and
knocking holes in their bottom... Larger boats aren't required to have this
sort of positive flotation though... Don't remember exactly at what length
the requirement no longer applies... Probably around 25-30 ft or so, I
guess... It's quite possible that amphibs don't have this sort of design in
them...
Old April 23rd 06, 11:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
ink.net...
to float as well.
them...
*23.751***Main float buoyancy.
(a) Each main float must have‹
(1) A buoyancy of 80 percent in excess of the buoyancy required by that
float to support its portion of the maximum weight of the seaplane or
amphibian in fresh water; and
(2) Enough watertight compartments to provide reasonable assurance that
the seaplane or amphibian will stay afloat without capsizing if any two
compartments of any main float are flooded.
(b) Each main float must contain at least four watertight compartments
approximately equal in volume.
Old April 23rd 06, 11:23 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Roy Smith" wrote in message
23.751 Main float buoyancy.
I don't see anything in there that would require the supposedly watertight
compartments to still provide floatation in the event of them no longer
being watertight...
On a side note, I've heard that for emergency floats on offshore (oil rig)
helicopters, they often end up with the floats on the surface and the
helicopter suspended underneath it in the water..
Old April 23rd 06, 11:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
float, sank!
You might be surprised how many recreational boats sink. There are dozens
of thing that can happen. Most common are drain plug left out/loose, seals
or hoses leaking and slowly filling the boat.
Jim in NC
Old April 23rd 06, 11:43 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
One of the fundamental truths of boat design is that the center of gravity
has to be lower than the center of bouyancy. If it's not, then eventually
the boat (helicopter, whatever) will figure out how to turn itself over so
that it is.
Old April 24th 06, 12:21 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
that it is.
Not completely true, but right to a degree.
In the case of a heli or plane on floats, the center
of gravity is way higher than the center of buoyancy,
and everything continues to work out OK.
In that case the center of gravity is between the
outer points of buoyancy. Like this:
GGG
BB BB
Then if it gets a little sideways, and the gravity
is on the outside of buoyancy, things will re-adjust.
GGG BB
BB
Ker-splash! Soon it is stable again, but
in a bad (g) way:
BB BB
GGG
Jim in NC
An amphibian that sank? Flyingmonk Piloting 40 April 26th 06 09:32 PM
Amphibian info need Alain Theroux - 2i Solutions Owning 0 July 21st 05 02:21 AM
Adventure Air Amphibian accident Ed Baker Home Built 3 November 12th 04 01:46 PM
New amphibian aircraft Sten-Anders Fellman Products 0 August 28th 04 11:47 PM
Amphibian down on Mt Kearsarge [email protected] Piloting 2 July 7th 04 11:32 AM
