#11
Practicing my scan
In a previous article, "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com said:
Paul Tomblin wrote: Get yourself a yoke. I like the CH which also includes throttle, gear and flap switches, along with several programable other switches. I am a firm believer Many years ago I bought a CH yoke and a copy of Elite, but I never used it because I just hated the feel of the CH yoke. The springs just don't act anything like a real plane, especialy in pitch. I ended up not using it for pitch at all, just flying the trim. Are the new ones better? I don't know. The one thing I did which improved mine no end on controlling pitch was I lubricated the shaft with silicon grease. Before each session I run it back and forth while turning it to its stops, which breaks up any friction points. It operates MUCH more smoothly at that point. I don't think that would help my big problem with the yoke. I mean, just for instance, think of establishing a climb. In the plane, you pull back, adjust a bit to get the pitch right, then adjust the trim to take the force out. With the CH yoke, you can pull back, but if you want to hold that, instead of a natural "trimming out the force", you've got to put in enough trim to hold the climb while letting the yoke return to spring neutral, which requires some bizarre coordination. I don't know what you call that, but it's nothing like flying. Like I said, when I try it, I usually end up ignoring the yoke and using the trim wheel entirely. Same with bank angles - if you let go of the yoke entirely, it sits there at neutral. A real yoke bounces around and requires correction. And if you apply a very small force to one side of a real yoke, like if you're not supporting your arm on the arm rest properly, the plane will slowly follow that force into a bank. The CH yoke will let you know you're doing that by spring force. -- Paul Tomblin http://blog.xcski.com/ Science is like sex: sometimes something useful comes out, but that's not why we're doing it. -- Richard Feynman |
Practicing my scan
On 09/18/07 06:01, Paul Tomblin wrote:
In a previous article, "Mortimer Schnerd, RN" mschnerdatcarolina.rr.com said: Paul Tomblin wrote: Get yourself a yoke. I like the CH which also includes throttle, gear and flap switches, along with several programable other switches. I am a firm believer Many years ago I bought a CH yoke and a copy of Elite, but I never used it because I just hated the feel of the CH yoke. The springs just don't act anything like a real plane, especialy in pitch. I ended up not using it for pitch at all, just flying the trim. Are the new ones better? I don't know. The one thing I did which improved mine no end on controlling pitch was I lubricated the shaft with silicon grease. Before each session I run it back and forth while turning it to its stops, which breaks up any friction points. It operates MUCH more smoothly at that point. I don't think that would help my big problem with the yoke. I mean, just for instance, think of establishing a climb. In the plane, you pull back, adjust a bit to get the pitch right, then adjust the trim to take the force out. With the CH yoke, you can pull back, but if you want to hold that, instead of a natural "trimming out the force", you've got to put in enough trim to hold the climb while letting the yoke return to spring neutral, which requires some bizarre coordination. I don't know what you call that, but it's nothing like flying. Like I said, when I try it, I usually end up ignoring the yoke and using the trim wheel entirely. Same with bank angles - if you let go of the yoke entirely, it sits there at neutral. A real yoke bounces around and requires correction. And if you apply a very small force to one side of a real yoke, like if you're not supporting your arm on the arm rest properly, the plane will slowly follow that force into a bank. The CH yoke will let you know you're doing that by spring force. Well, it's true that the CH yoke does not provide the feel of a real airplane - but I think there is only one person on this planet who would argue with that anyway ;-) However, it's not that hard to get used to. And as for practicing the scan, having the attitude harder to control is not such a bad thing. It really gets you looking at the instruments. When I'm practicing my scan, I'll hand fly the sim, including changes in airspeed, altitude, direction, etc. - all are more difficult in the sim than in the real plane, but that just provide for more practice in watching and reacting to the instruments. When I'm practicing navigation or approaches, I'll make more use of the auto pilot - usually just altitude hold as it can be frustrating trying to hold altitude by hand in the sim. It's been a long time since I've tried to fly with a mouse or keyboard, but the yoke is a big step up in my opinion. By the way, I don't use the mechanical trim wheel mounted on the CH yoke. I use the electric trim via a rocker switch. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Practicing my scan
B A R R Y wrote:
I don't know. The one thing I did which improved mine no end on controlling pitch was I lubricated the shaft with silicon grease. Before each session I run it back and forth while turning it to its stops, which breaks up any friction points. It operates MUCH more smoothly at that point. I have that same yoke, which I hate. Your suggestion sounds like it's got a lot of potential. By silicone grease, do you mean the clear stuff, like "bulb grease?" I'm not sure it's the same. I've got some "bulb grease" which looks like the same stuff but it has the consistency of a bar of soap or a wax candle. The stuff I used on my yoke is the same silicon grease I used to lube o-rings when I worked on scuba regulators. It's translucent, can come in either a squeeze tube or a small tub and has the same consistency as car grease or toothpaste. The reason I use silicon grease instead of car grease is that it doesn't ruin clothes and I know the silicon won't degrade rubber parts. Besides, I've got plenty of it left over from my dive shop days. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Practicing my scan
Paul Tomblin wrote:
I don't know. The one thing I did which improved mine no end on controlling pitch was I lubricated the shaft with silicon grease. Before each session I run it back and forth while turning it to its stops, which breaks up any friction points. It operates MUCH more smoothly at that point. I don't think that would help my big problem with the yoke. I mean, just for instance, think of establishing a climb. In the plane, you pull back, adjust a bit to get the pitch right, then adjust the trim to take the force out. With the CH yoke, you can pull back, but if you want to hold that, instead of a natural "trimming out the force", you've got to put in enough trim to hold the climb while letting the yoke return to spring neutral, which requires some bizarre coordination. I don't know what you call that, but it's nothing like flying. Like I said, when I try it, I usually end up ignoring the yoke and using the trim wheel entirely. I will acknowledge it doesn't operate the same as a real airplane. In fact, the way the trim operates is the main reason it doesn't... at least in normal modes of flight. This is why it's damned near worthless in teaching primary flight. That being said, I've got the trim programmed into the gray momentary toggle on the left horn of the yoke. I handle the adjustment with my left thumb. It's just not that big of a problem. Same with bank angles - if you let go of the yoke entirely, it sits there at neutral. A real yoke bounces around and requires correction. And if you apply a very small force to one side of a real yoke, like if you're not supporting your arm on the arm rest properly, the plane will slowly follow that force into a bank. The CH yoke will let you know you're doing that by spring force. And all of that requires you keep your scan going to catch it, right? You can't just put it somewhere and expect it to stay there without some correction. I will remind you the whole point of this discussion was to assist in keeping scan speed up for someone who doesn't fly IFR often enough. Can you think of a more cost effective way to accomplish that? Only somebody who's never flown is going to think MSFS is very realistic. But it's a very good procedure and scan exercise for IFR purposes. BTW, I always use the 2-D mode with the instrument panel taking up much of the view. I still can't land it worth a damn but that's OK... I can land a real airplane just fine. Like I said, nobody will mistake one for the other. And unlike a regular airplane, I can go back and print out a sheet that shows how closely I followed the ILS on the way down, both hortizontally and vertically. -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Practicing my scan
Mark Hansen wrote:
However, it's not that hard to get used to. And as for practicing the scan, having the attitude harder to control is not such a bad thing. It really gets you looking at the instruments. Which was the point. By the way, I don't use the mechanical trim wheel mounted on the CH yoke. I use the electric trim via a rocker switch. Exactly. It has been said that the measure of a man's genius is how much he agrees with you. You, sir, are a veritable Einstein. G -- Mortimer Schnerd, RN mschnerdatcarolina.rr.com |
Practicing my scan
Mortimer Schnerd, RN wrote:
It's translucent, can come in either a squeeze tube or a small tub and has the same consistency as car grease or toothpaste. Ahhh! I have some of that stuff for mountain bike shocks. |
Practicing my scan
Paul Tomblin wrote:
Many years ago I bought a CH yoke and a copy of Elite, but I never used it because I just hated the feel of the CH yoke. The springs just don't act anything like a real plane, especialy in pitch. I ended up not using it for pitch at all, just flying the trim. Are the new ones better? Exactly my experience. Does the old Elite run under XP? (I think I have version 4.something of elite, which has a box that connectos to the the computer via a serial Rs232 port. |
Practicing my scan
I also use MSFS for getting my head in the game. I 've never tried a yoke,
just a joystick. I have flown IRL with both stick and yoke so don't mind using the joystick. Trim is a bitch. I downloaded real trim from Avsim http://www.avsim.com/ Join the group (free) and download realtrim11.zip from the avsim library RealTrim is a Microsoft Flight Simulator 2004(tm) module that makes trimming aircrafts more realistic and resemble real-life. It can be activated via key-press when the sim-pilot moves the joystick from deflection to neutral, hence converting the movement of the joystick into movement of the trim wheel. This matches real-life where back/forward pressure on the elevator applied by the pilot is trimmed out by ONE operation: moving the trim-wheel. As the sim-pilot smoothly moves the joystick into neutral position RealTrim automatically adjusts the elevator trim by a corresponding amount. The airplane keeps its current pitch configuration - only ONE control input is required instead of the pilots having to move the joystick into neutral WHILE tapping the trim-key at the same time. RealTrim also comes with an option to reduce trim increments making it more precise to adjust trim in flight with the trim up/down keys. It works on MOST of the aircraft models ( I usually stick with the baseline Cessna 182) It is not like the real thing since there are no pressures to trim out but it does allow you to trim to a mainly hands off configuration. I agree with the rest of the guys who advise setting ceiling and visibility to around minimums. Who needs all the outside view eye candy anyway. Well maybe the approach lights at night are neat. The ATC simulation is terrible so I usually ignore it or use the add on product Radar Contact from http://www.jdtllc.com/ This is not free but it does add some realism. I like the after flight review. Even if sometimes they do tell me that FSDO is going to require me to visit them. Now if they just had a good aerodynamic model and a way to integrate GARMIN simulation, all would be perfect. John H. "Peter R." wrote in message ... On 9/17/2007 7:25:32 PM, wrote: Would using it with a mouse provide reasonable scan practice, or do I need to buy a yoke or joystick? IMO, if you can find a cheap yoke (CH Yoke on eBay or via comparison web shopping), consider purchasing it as it will take away the majority of the difficulty in controlling the sim aircraft while you are practicing your scan. Second would be a joystick and third would be the mouse. The keyboard completes the list of easiest-to-most difficult control of the sim aircraft while practicing your scan. -- Peter |
Similar Threads | ||||
Blue Angels are practicing for next year... | Tom Callahan | Aviation Photos | 0 | December 11th 06 09:32 PM |
Icing in the scan... | three-eight-hotel | Instrument Flight Rules | 12 | January 5th 06 06:58 PM |
scan aircraft log to CD | Dave Butler | Owning | 7 | February 4th 05 02:45 PM |
Practicing SFLs with a constant speed prop - how? | Ed | Piloting | 22 | April 16th 04 02:42 AM |
Practicing Chewing Gum | Jerry Kaidor | Instrument Flight Rules | 2 | February 27th 04 09:51 PM |
