Passive Reflective Devices
Old July 12th 04, 02:09 AM
Gordon Schubert
WHAT ABOUT REFLECTIVE TAPE?
GORDY
Old July 12th 04, 05:13 AM
COLIN LAMB
Interesting question - to give a "sparkle" to make the glider more visible.
I have a mirror in my search and rescue pack. The survival mirror has great
range. Mirrors have been spotted 50 miles away. However, they need to be
aimed. What you are proposing is to use an assembly that has multiple
reflecting surfaces so that aiming becomes unnecessary.
There are problems, however. As the surface number increases, the
reflections are reduced in magnitude. Fortunately, the original source is
substantial. A good mathematician could determine the probabilities of a
reflection, knowing the number of surfaces, the various possible locations
of the sun and the other aircraft and and the likely possibility of the
other pilot looking into an area that might contain the glint.
Some collisions are from below or above. The reflector would not do much
good in those directions.
If he (or she) has their head "in the cockpit", it will not be much good. I
fly a helicopter that has a strobe on all the time and it does not do much
good during the day. I still keep my eyes open to keep other things from
running into me (or me running into them).
I am installing a collision avoidance system in my motorglider, but it
depends upon the other aircraft having a transponder - not much good with
the glider circuit.
Colin
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.713 / Virus Database: 469 - Release Date: 6/30/04
Old July 13th 04, 07:15 AM
Mark James Boyd
Seeing that you are going to be using Lawrence Welk's mirrored ball, you
should also attach his perpetual bubble machine, and use it for thermal
location.
We had a real blast yesterday tossing out rolls of toilet paper
and slicing them with the wings. Also seemed good for thermals.
Harder to see than a glider though.
There is reflective tape that I've used before on boats...
Mark Boyd
Avenal, California, USA
Old July 13th 04, 12:52 PM
henkelize
Hi all
Thanks for all the replies. I would be lying if I said I got what I wanted,
but the time spent in replying is appreciated.
Henk Stander
"COLIN LAMB" wrote in message
.net...
visible.
great
I
the glider circuit.
Colin
Old July 13th 04, 10:49 PM
'Reflective tape' is normally 'retroreflective' - it reflects light back
to where it came from.
This only works when whoever you want to see you is shining a bright
light at you - for example cycle reflectors are great at night, but
not much help in the daytime.
VNE
Old July 14th 04, 03:04 AM
Bob C
How 'bout a disco ball helmet? That way you could
be seen even if you bailed out ;o)
I put Whelen strobes on my Salto for night flight and
night airshows. Took 6 months of paperwork and I had
to re-certificate in Experimental-Exhibition category.
On top of that, due to no generator, I'm restricted
to using the anti-collison lights only in Airshow Waivered
(sterile) airspace. Cost me a fortune, even though
Whelen donated the lights. Typical FAA!
Despite the limitations, I turn them on in crowded
air. (I dare them to try to bust me for that!) They
are the newer Whelen 'Comet-Flash lights. They fire
4 rapid pulses, 80 times/minute. They are easily visible
in full sunlight for quite a ways, and very bright
on cloudy days or at dusk.
BTW, ATC radar has no trouble picking us up. Give
them a call and ask them to give you headings for identification.
They'll have you make a couple of 90 degree turns
to identify your blip. After that, they'll know who/where
you are.
reflects light back
shining a bright
at night, but
VNE
Old July 14th 04, 05:23 AM
Eric Greenwell
you are.
When you say "ATC radar has no trouble picking us up", is it because of
the lights? If not, what is the ATC situation: near or inside Class B or
C airspace, inside the Mode C veil, traveling enroute, or? I'm curious,
because our local Class does have trouble picking us up, and I'm
wondering what the difference is.
Eric Greenwell
Washington State
USA
Old July 14th 04, 11:41 AM
Ray Lovinggood
Eric,
The controllers at the Raleigh-Durham (RDU) airport
ATC facility can see my glider with their 'primary'
radar. RDU is within Class C airspace (wanting to
go to Class B, but that's another story) and one time
I called them up while thermalling and they found me.
They kept an eye on me when traffic was light. They
didn't have time to concentrate on looking at primary
returns all the time, but I could and did listen to
them so I could help determine where the traffic was
that they were speaking with. During this one particular
flight as I circumnavigated the RDU Class C airspace,
I always remained outside of the Class C, but was probably
no more than 40 - 50 miles from the control tower.
Ray Lovinggood
Carrboro, North Carolina, USA
identification.
you are.
When you say 'ATC radar has no trouble picking us up',
is it because of
or? I'm curious,
up, and I'm
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Old July 14th 04, 03:55 PM
Tom Serkowski
" wrote in message ...
VNE
I think he's talking about silver mylar tape. S&G had an article
about visibility markings on sailplanes and the conclusion was that
covering the control surfaces with something like this was the best
bet. The surfaces are relatively flat and move around a bit, so
produce frequent 'glints'. Of course, only works in sunlight, and not
very well from the front. So best results are if the target is
circling away from clouds.
-Tom
Aircraft Deceleration Devices SteveM8597 Military Aviation 10 April 13th 04 10:01 AM
Devices for avoiding VNE? John Galloway Soaring 100 April 12th 04 08:53 PM
GPS and Night Vision Devices Steve Products 0 February 12th 04 11:34 AM
WinPilot-compatible GPS devices Ted Wagner Soaring 21 January 12th 04 10:27 AM
Airdropped Fusion Devices Blinky the Shark Military Aviation 4 September 17th 03 05:34 PM
