#21
On Mon, 14 Mar 2005 19:45:09 -0600, "Montblack"
wrote in :: ("Larry Dighera" wrote) It's an interesting design. Is it a home built? I didn't get the feeling from their web page it was being offered for the homebuilt market. Then, why'd you crosspost to rec.aviation.homebuilt? |
You are missing the point. Take a small engine, divide the output in
half, and the prop is going to be small. Why? Because I can. Because that would divide the HP into two, so a smaller size bike belt would be reliable. Pay attention. I am paying attention. I'm trying to learn something, no need to be rude. Seems to me that dividing the HP in two does not mean a smaller prop. The same HP can turn a large prop slowly or a small prop quickly. The same power goes into each prop no matter what. However, with a large prop turning slowly, the =force= on the prop would be smaller (so force times distance remains constant). But the force on the belt should be the same, since the belt is turning at engine speed around the engine shaft, (and at prop speed around the bigger prop shaft). What I have read indicates that props are more efficient turning slower (than 2500 RPM) and (gas) engines are more efficient turning faster than that. Aside from the issue of the large prop pully at the pylon, what am I missing? Jose r.a.homebuilt trimmed, as I don't follow that group -- Math is a game. The object of the game is to figure out the rules. for Email, make the obvious change in the address. |
I'm calling it "dead in the water" :-)
MJC "Montblack" wrote in message ... High Performance Aircraft out of Germany - HPA TT62 http://www.hp-aircraft.de/edoc/tech.html I'm calling it The Little Mermaid. Montblack |
#24
I didn't get the feeling from their web page it was being offered for the homebuilt market. Then, why'd you crosspost to rec.aviation.homebuilt? A: It's an interesting idea ...with pictures. B: It's spawned some "what if" ideas based on HPA's design. http://www.hp-aircraft.de/edoc/tech.html C: It's gennerating an interesting belt-drive propeller discussion. Very 1903. g D: It's not like I cross-posted The Little Mermaid to rec.shipping.propulsion. May I please have my hall pass back? Montblack |
#25
"Jose" wrote i What I have read indicates that props are more efficient turning slower (than 2500 RPM) and (gas) engines are more efficient turning faster than that. Aside from the issue of the large prop pully at the pylon, what am I missing? Jose OK, I'll be nice, since you asked so nice. ;-) Homebuilt group is really where this discussion belongs, but whatever. It is an interesting group, if you like discussions like this. Yes, big props are turning slowly are more efficient, and more efficient, especially at climb. Smaller faster props work better for speed in cruise. The big pulley out on the pylon is a big drawback, due to drag where you don't want it. The other problem of trying to get it to turn slower, is that it would need to done by using gearing, and the gearing I was talking about was a motorcycle gearbox They have been shown to have durability problems, when running a low gear at high power for extended periods of time. The whole issue of a smaller prop turning fast is not that big of a deal, as long as it is not too fast. Yes, the tips definitely have to stay out of the supersonic flow, where big losses occur. There are many very successful designs running around on engines like Volkswagen engines, or Subaru direct drives, or even the small Continentals trying to make more HP. -- Jim in NC |
#26
:Yes, that is all true. The real problem is the rapid decline in the
efficiency of conversion from power to thrust as the propellor rpm increases. The pounds of thrust per horsepower declines like a capacitor discharge curve as the rpm increases and you have lost two thirds by the time the prop rpm gets to 2000! A ducted fan helps a little, but they are much less efficient than a big old lazy unshrouded propellor chugging away. Highflyer Highflight Aviation Services Pinckneyville Airport ( KPJY ) PS: Pinckneyville rec.aviation flyin is coming up May 20, 21, and 22. See the article in AOPA Online. "Morgans" You are missing the point. Take a small engine, divide the output in half, and the prop is going to be small. Small props do not mind turning fast. Also, if you use the belts for the RPM reduction, you have to put the big pulley out on the pylon, where you want a small one. -- Jim in NC |
Similar Threads | ||||
I'm calling it The Little Mermaid | Montblack | Home Built | 28 | March 16th 05 04:27 AM |
US Team Junior News, Calling US Juniors | John Seaborn | Soaring | 0 | October 4th 04 10:36 PM |
Airman Finds True Calling as Part of 'Best Force' | Otis Willie | Military Aviation | 0 | September 10th 04 11:18 PM |
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). | Phillip Rhodes | Military Aviation | 0 | September 7th 04 01:30 PM |
Calling Tom Cooper. . . Iran stuff. . | Drewe Manton | Military Aviation | 6 | August 18th 03 10:35 AM |
