#41
Hi Mike!
On Sun, 13 Mar 2005 18:51:10 -0800, Mike 'Flyin'8' wrote: Dave, Thanks for your input! So if I mount the AM1000 on the Yoke, it does not block any of the instruments in the cockpit? I am 5' 9" , partner is 6'4". He says no, the knob on the mount blocks the 0 -800 RPM portion of the tach for me if I sit perfectly straight..shift my head to the right an inch or two, and my answer is no as well... When you turn the Yoke, does the AM1000 stay vertically aligned, or does it turn with the yoke? It turns with the yoke.. Since the AM500 and AM1000 are pretty much the same unit (Except for size) Is the extra $200 a good trade off for screen size? Yes, absolutely for us... I have not seen either of these units in person so I am not sure how dramatic the difference on the screen is... I drew out two boxes that are the exact size of the units, and the AM1000 is quite a bit bigger... I am certainly leaning toward either the AM500 or AM1000, but trying to justify the money in my head... If the AM500 does exactly what I want, and the screen/button size is usable then I would be happy. If however, the buttons are too small to be easily used during flight, then I would be very disappointed. My currrent solution is jsut not working... The PDA using GPS software and a CF card. It is just not practical. How the heck am I supposed to use the little stylus during flight... :-) I don't know either... the AM 1000 has large widely spaced buttons, easily reached with your thumbs while firmly holding the yoke. We tried several, and the most difficult was a Garmin 196 mounted at arms length in the center of the panel. OK on the ground, but in rough air, just try to push a small (correct) button at arms length with you (and your hand) moving opposite to the panel in rough conditions. Obviously you thought the cost was worth the extra size on the screen... I am just afraid the size of the unit would block some of my view in the cockpit. As above, not an issue with us on our 1974 "M" model What about using this AirMap 1000 on a suction cup mount connected to the lower left side of the front windscreen? Workable? Yes, should work OK, but when it gets bumpy, having your thumbs/hands/buttons/GPS and yoke locked together takes the pain out of the operation.. .. We REALLY happy with the AM..But that is just us, YMMV! Good luck.. Happy to answer any other ???? U may have... As you may guess by now, we tried several (in other 172's) and we shopped hard Dave |
#42
Thanks Dave. Appreciate your input. I actually placed the order for
the AM1000 today. I will first try the Yoke Mount as suggested and if it becomes a distraction I will get one of those suction cup mounts for the windscreen. I think I will like the yoke mount, however, I am not so sure I will like the GPS turning with the yoke, that may be the gotcha for me... On Tue, 15 Mar 2005 22:38:47 -0400, Dave wrote: Hi Mike! On Sun, 13 Mar 2005 18:51:10 -0800, Mike 'Flyin'8' wrote: Dave, Thanks for your input! So if I mount the AM1000 on the Yoke, it does not block any of the instruments in the cockpit? I am 5' 9" , partner is 6'4". He says no, the knob on the mount blocks the 0 -800 RPM portion of the tach for me if I sit perfectly straight..shift my head to the right an inch or two, and my answer is no as well... When you turn the Yoke, does the AM1000 stay vertically aligned, or does it turn with the yoke? It turns with the yoke.. Since the AM500 and AM1000 are pretty much the same unit (Except for size) Is the extra $200 a good trade off for screen size? Yes, absolutely for us... I have not seen either of these units in person so I am not sure how dramatic the difference on the screen is... I drew out two boxes that are the exact size of the units, and the AM1000 is quite a bit bigger... I am certainly leaning toward either the AM500 or AM1000, but trying to justify the money in my head... If the AM500 does exactly what I want, and the screen/button size is usable then I would be happy. If however, the buttons are too small to be easily used during flight, then I would be very disappointed. My currrent solution is jsut not working... The PDA using GPS software and a CF card. It is just not practical. How the heck am I supposed to use the little stylus during flight... :-) I don't know either... the AM 1000 has large widely spaced buttons, easily reached with your thumbs while firmly holding the yoke. We tried several, and the most difficult was a Garmin 196 mounted at arms length in the center of the panel. OK on the ground, but in rough air, just try to push a small (correct) button at arms length with you (and your hand) moving opposite to the panel in rough conditions. Obviously you thought the cost was worth the extra size on the screen... I am just afraid the size of the unit would block some of my view in the cockpit. As above, not an issue with us on our 1974 "M" model What about using this AirMap 1000 on a suction cup mount connected to the lower left side of the front windscreen? Workable? Yes, should work OK, but when it gets bumpy, having your thumbs/hands/buttons/GPS and yoke locked together takes the pain out of the operation.. . We REALLY happy with the AM..But that is just us, YMMV! Good luck.. Happy to answer any other ???? U may have... As you may guess by now, we tried several (in other 172's) and we shopped hard Dave Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
#43
Mike,
I will get one of those suction cup mounts for the windscreen. You'll be pulling it out of the carton the AM1000 came in - it's included. -- Thomas Borchert (EDDH) |
#44
I am not following your comment... I do not have a plane or a GPS. I am in the market for a GPS and came across a good deal on the Airmap 1000. Wasn't meant for usenet, sent a kill request in its regard, that wasn't honored by the ISP... |
#45
("Darrel Toepfer" wrote)
Wasn't meant for usenet, sent a kill request in its regard, that wasn't honored by the ISP... If it was an "unsend" "unsend" that got away from you, how does a kill request work? Have many people used this service/feature? ISTM that a kill request would need to be sent AND processed in the blink of an eye for it to catch an "unsend" "unsend." My posts mostly show up, back on my machine, rather quickly after I send them. Sometimes not so quick. Once in a while it's almost instantaneous. Sync All ..."wow, there's my post." That's rare, but it happens. Montblack |
#46
"Montblack" wrote in message
... ("Darrel Toepfer" wrote) Wasn't meant for usenet, sent a kill request in its regard, that wasn't honored by the ISP... If it was an "unsend" "unsend" that got away from you, how does a kill request work? Have many people used this service/feature? ISTM that a kill request would need to be sent AND processed in the blink of an eye for it to catch an "unsend" "unsend." Usenet supports a device known as a "cancel post". It's similar to the original post, but includes information telling the receiving server to remove the original post. Yes, when it's used there's a brief period during which the original post is still visible, until the cancel post catches up to it. But once the cancel post has made it to the same servers that the original post made it to, the original post disappears. At least, that's the theory. In reality, Usenet has no security or authentication protocols, and cancel posts are (were) regularly abused. A person with a grudge or who disagreed with another person's viewpoint would post a fraudulent cancel post, to remove that other person's post. It used to be that there were so few users on Usenet that the few instances where cancel posts were abused could be easily dealt with. But that hasn't been true in a long time, and most ISPs simply ignore cancel posts altogether. So, Darrel presumably tried to send a cancel post, but since nearly all ISPs simply don't honor them anymore, it had no effect. It's possible that you would have still seen the original post, even if it did have an effect, depending on when he sent the original, when he sent the cancel, and when you checked the latest messages on your news server. But in reality, it's unusual these days for a cancel post to have any effect anywhere. Pete |
#47
As Tom says, "it's in the box"..
And it's a good one.. NOTHING chincy about the "RAM" mounts... Would really be interested in your impressions about the unit when you get it. The manual is one of the best I have seen as well... Dave On Wed, 16 Mar 2005 09:48:31 +0100, Thomas Borchert wrote: Mike, I will get one of those suction cup mounts for the windscreen. You'll be pulling it out of the carton the AM1000 came in - it's included. |
#48
When I get a chance to play around with it I will post a PIREP and
note my first impressions... Should be quite entertaining.... Thanks for everyone's input, very much appreciated!! On Wed, 16 Mar 2005 19:20:36 -0400, Dave wrote: As Tom says, "it's in the box".. And it's a good one.. NOTHING chincy about the "RAM" mounts... Would really be interested in your impressions about the unit when you get it. The manual is one of the best I have seen as well... Dave On Wed, 16 Mar 2005 09:48:31 +0100, Thomas Borchert wrote: Mike, I will get one of those suction cup mounts for the windscreen. You'll be pulling it out of the carton the AM1000 came in - it's included. Mike Alexander PP-ASEL Temecula, CA See my online aerial photo album at http://flying.4alexanders.com |
#49
Montblack wrote:
("Darrel Toepfer" wrote) Wasn't meant for usenet, sent a kill request in its regard, that wasn't honored by the ISP... If it was an "unsend" "unsend" that got away from you, how does a kill request work? Have many people used this service/feature? It removed it from the ISP server, but not fast enough for the rest of the world... Just does... Its typically a part of the newsreader... ISTM that a kill request would need to be sent AND processed in the blink of an eye for it to catch an "unsend" "unsend." Apparently... |
Similar Threads | ||||
Speech: A Question of Loyalty: Gen. Billy Mitchell | Otis Willie | Military Aviation | 0 | September 25th 04 09:30 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Legal question - Pilot liability and possible involvement with a crime | John | Piloting | 5 | November 20th 03 09:40 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
Special Flight Setup Question (COF) | Dudley Henriques | Simulators | 4 | October 11th 03 12:14 AM |
