Pee tube system for ASW-27
Hi All
Like to install a relief tube system in my ASW-27 and looking for some ideas. Ken (KP) |
Hi,
I have a system in my PIK-20 that works very well. I installed a brass tube that has the appropriate ID to slip over a carbon fiber aerrow shaft. I drilled a hole in the fuselage floor behind the stick and through the outside of the aircraft. I then epoxied the brass tube in the hole and cut to be flush on the bottom of the aircraft and the seat floor. One end of the arrow shaft is cut at a slant to create suction in the airstream. The other end of the arrow shaft is glued into a model airplane fuel bulb (looks like a turkey baster bulb, but has a much smaller opening at the bottom. You will have to size the arrow shaft so that you can insert into the brass tube with the canopy closed. In my ship, this results in an arrow shaft that is 20" long. The rear of the fuel bulb has a hole cut in it to provide a friction fit (seal) around your willie. When done, I flush it with a little water put a piece of paper towel in the opening, and stow the assembly. Oh, And I use a bit of mylar over the exit hole so that the hole is sealed unless the arrow shaft pushes the mylar out of the way. Works great - no muss, no fuss, no catheters and no yellow stains anywhere on my ship. Glen Kelley "KP" wrote in message oups.com... Hi All Like to install a relief tube system in my ASW-27 and looking for some ideas. Ken (KP) |
I did a similar system on my ASH26e. Be aware that tubular composite kite
spar material is available in many nesting diameters. So you don't have to use a brass or other metal outer tube. A larger composite tube is both lighter and will glass in better. The you can use a smaller kite spar tube for the stiff pee tube to extend out. If the larger tube is installed at an angle aft, then there's no need to cut the end of the extended tube at an angle to insure suction. If the larger tube ends at the seat pan, and in an area that's hard to see due to the seat cushion (like just aft of the stick), then you can install a guide "V" to make it easy to install the smaller extension tube in flight. I did this using a V made of stainless steel welding rod fixed to the seat pan with some UHMW polyethylene tape. If there's interest, I can post some pictures to the glider forum on this. bumper "Glen Kelley" wrote in message ... Hi, I have a system in my PIK-20 that works very well. I installed a brass tube that has the appropriate ID to slip over a carbon fiber aerrow shaft. I drilled a hole in the fuselage floor behind the stick and through the outside of the aircraft. I then epoxied the brass tube in the hole and cut to be flush on the bottom of the aircraft and the seat floor. One end of the arrow shaft is cut at a slant to create suction in the airstream. The other end of the arrow shaft is glued into a model airplane fuel bulb (looks like a turkey baster bulb, but has a much smaller opening at the bottom. You will have to size the arrow shaft so that you can insert into the brass tube with the canopy closed. In my ship, this results in an arrow shaft that is 20" long. The rear of the fuel bulb has a hole cut in it to provide a friction fit (seal) around your willie. When done, I flush it with a little water put a piece of paper towel in the opening, and stow the assembly. Oh, And I use a bit of mylar over the exit hole so that the hole is sealed unless the arrow shaft pushes the mylar out of the way. Works great - no muss, no fuss, no catheters and no yellow stains anywhere on my ship. Glen Kelley "KP" wrote in message oups.com... Hi All Like to install a relief tube system in my ASW-27 and looking for some ideas. Ken (KP) |
bumper wrote:
If there's interest, I can post some pictures to the glider forum on this. Please do. |
"Avron" wrote in message oups.com... bumper wrote: If there's interest, I can post some pictures to the glider forum on this. Please do. Okay, I posted some pics to the glider forum. Look in albums by "bumper" /relief system. Or try: http://www.gliderforum.com/photos/ph...sp?albumid=128 all the best, bumper |
The factory installs a pee tube by drilling a hole in the seat pan just
behind the stick. They route the tube to the right aft landing gear door. Find a 27 with the factory option installed and you'll see one system that works for sure. John Cochrane |
John,
Sorry to say the factory installation does not work for the following reasons: 1. The tube comes through the seat pan under the right thigh not in the center. This causes the tube to be crushed so that flow is restricted. 2. The tube running down the right side then into the gear well and onto the aft end of the right gear door has two uphill points ( or high points ). The Germans must have great nossel pressure. The corresponding low points leave liquid in the tube with air in between. The suction created by the tube at the gear door never removes all the fluid. This requires a pretty good liquid pressure to move the low point liquid and air out. This can cause a "blow off" of the condom and if one uses a funnel, it has to be held up close to the top of the pannel. Tom Idaho BB wrote: The factory installs a pee tube by drilling a hole in the seat pan just behind the stick. They route the tube to the right aft landing gear door. Find a 27 with the factory option installed and you'll see one system that works for sure. John Cochrane |
I had a 27 type system in my first glider and I agree it does not work well.
In my second glider I went straight down with a larger guide tube and a smaller one to slide in and out, which worked much better. In my third iteration, which happens to be an ASW24, I use the same approach but with improvements. First a guide tube, having an even bent starting flush at the seat pan and 90 deg. to the contour of the seat pan. The hole is at the 4 o'clock position at the stick opening of the seat pan. It clears the thigh even when the knees are tight together against the instrument column. The radius of the guide tube is such that the telescoping tube exist the bottom of the belly at about a 20-25 deg. angle. The inner tube (telescoping) continues to make a curve free of the guide tube and points almost back wards when the glider is not flying. When flying I am sure it will point back. The tube, in that position on the ground, is about 5" from belly skin. When retracted the belly is nice and flush. The system works well with a bulb type funnel and catheter. After a five day contest there will be some residue but no intrusion into the gear well. There is no streaking hence no fluid running along the skin. From the catheter I hook directly to the quick disconnect from there a short latex tube for max flex without kinking, and then onto the stiffer tube of about 10" It all can be retracted if desired. Regards Udo wrote in message ups.com... John, Sorry to say the factory installation does not work for the following reasons: 1. The tube comes through the seat pan under the right thigh not in the center. This causes the tube to be crushed so that flow is restricted. 2. The tube running down the right side then into the gear well and onto the aft end of the right gear door has two uphill points ( or high points ). The Germans must have great nossel pressure. The corresponding low points leave liquid in the tube with air in between. The suction created by the tube at the gear door never removes all the fluid. This requires a pretty good liquid pressure to move the low point liquid and air out. This can cause a "blow off" of the condom and if one uses a funnel, it has to be held up close to the top of the pannel. Tom Idaho BB wrote: The factory installs a pee tube by drilling a hole in the seat pan just behind the stick. They route the tube to the right aft landing gear door. Find a 27 with the factory option installed and you'll see one system that works for sure. John Cochrane |
My factory pee tube works great. You have to route it correctly under
the seat pan if you take the seat pan out for an annual. If you install a t that lets air into the system, you can blow out any remaining liquid. John Cochrane |
Similar Threads | ||||
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Air defense (naval and air force) | Mike | Military Aviation | 0 | September 18th 04 04:42 PM |
Naval air defense | Mike | Naval Aviation | 0 | September 18th 04 04:42 PM |
Air Force Helper 2000 | tomcat | Naval Aviation | 0 | June 9th 04 11:54 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
