fitting a cruise/climb switch on the stick
Old January 31st 18, 05:19 PM posted to rec.aviation.soaring
Default fitting a cruise/climb switch on the stick
With an LX 9000 and remote stick control I used a flap sensor as the primary input to change climb/ cruise but also found by chance a combination of settings on the 9000 that caused the taster switch on the stick to switch to climb vario in cruise flap. While in thermalling flap the taster had no effect. That was ideal as I could hold climb mode while nosing around for lift in medium speed in cruise flap.
I have sold the glider recently and can't recall the combination of settings but it should be easy to find by experimenting with the setting options for climb/ cruise switching and the settings for the taster switch
Cambridge 302 - switch from Netto in cruise to TE in climb? Bernie[_4_] Soaring 3 November 30th 14 08:27 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 15 December 21st 12 11:54 PM
adding speed/vario switch into ASW-19 control stick grip Kimmo Hytoenen Soaring 0 December 19th 12 01:28 PM
cruise vs. climb article location SAM AND LEIGH ZIMMERMAN Soaring 5 March 19th 07 04:15 PM
Flap handle activated Climb/Cruise switching Andy Smielkiewicz Soaring 5 March 14th 05 04:54 AM
