Urgh. Sorry to hear that. What happened? I have a Cardinal RG with a IO-360A1B6 with 1000 hours on it. On one short 30 min. flight to Cape May, NJ (WWD) I noticed a small amount of oil running down the nose gear door. I did a cursory look and found the oil level unchanged and saw nothing through the oil access door. I wiped it off. On the flight back all oil indicators were fine. When I landed the drip of oil was back. No big oil loss, but when you fly the same airplane you know what's suppose to be there and what's not. I called my mechanic and co-owner and explained the problem. At first the mechanic was not concerned. My partner flew a few days later on a short flight and when he landed the A&P came over to say hello. He then noticed the oil on the gear door. He grounded the plane and the next day called me to the airport. He showed me a pretty good leak coming through something called a "though-bolt" on the number two cylinder. A though-bolt is a long bolt that goes completely through the engine from one cylinder to the other and helps keep the case enlighten and tight. That wasn't the big problem though, he said I could fly with a minor leak at the through-bolt to TBO. Next he did a dye penetrate test and found a crack in the case in front of the number 4 jug at one of the studs for that cylinder. That did it. The engine had to come off, the case split and a new case was ordered. The story goes on though. As he was taking the engine off he found one other interesting item. One of the through-bolt nuts on the bottom of cylinder number 3 was sheared off completely flush the cylinder base. That's when the hair on the back of my neck stood up. I have to think that all this was related as the nut was still laying in the bottom of the engine. This was recent! Next I had a recollection of starting the engine before my flight to WWD and I remember that I heard a "snap!" just as the engine caught. It was loud enough to make me say, "...what the %$#@ was that?!" and just soft enough for me to dismiss it and ponder, "...did you really hear what you think you heard?" The rest is speculation, but maybe that was the nut snapping off and something bad happened in the engine causing the leak at the through bolt on number two cylinder. Maybe the engine was ready to self-destruct in the air on the next flight. Who knows? But I hope to learn more when the engine is broken down and inspected. I will keep you all posted if you are interested. Kobra |
Kevin Kubiak wrote:
What are they offering for trade-n for a 196? $450. |
Kobra wrote: Urgh. Sorry to hear that. What happened? Next I had a recollection of starting the engine before my flight to WWD and I remember that I heard a "snap!" just as the engine caught. It was loud enough to make me say, "...what the %$#@ was that?!" and just soft enough for me to dismiss it and ponder, "...did you really hear what you think you heard?" So true... Always the hard question is how do you distinguish between when the engine goes auto-rough every time you fly over water versus the truly exceptional snap. A year ago I turned the key in my Jeep, and it seemed to start pretty sluggishly, but started nonetheless. Engine ran brilliantly so I dismissed it. It wasn't cold or anything, I just chalked it up to gremlins. Five minutes later I double-parked to grab a coffee, came back out, turned the key, and -clunk-. That sluggish start was the starter's last gasp. Had I known I could have driven it to a mechanic and avoided the tow, but it was still under warranty so at least it only cost me time and not cash. -cwk. |
Similar Threads | ||||
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
For Sale Garmin GPSMAP 196 | Snead1 | Soaring | 0 | May 14th 04 03:10 AM |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Products | 10 | April 29th 04 06:57 AM |
Garmin GPSMAP 296 | Cockpit Colin | Piloting | 7 | March 23rd 04 01:15 PM |
