encoding altimeter pinout?
Old July 14th 04, 12:09 AM
Bill Chernoff
Default encoding altimeter pinout?
Hi Everyone,
I have an Aero Mechanism 8140B-20 Altimeter/Encoder. Does anyone happen to
have a pinout for this model? Or any ideas on where to find one? The google
search turned up an Aero Mechanism CNC, but they are not the right guys.
tia
Bill
Old July 15th 04, 05:16 AM
Icebound
"Bill Chernoff" wrote in message
news:vYZIc.9077$od7.923@pd7tw3no...
Hi Everyone,
to
google
tia
Bill
Did you find this list?
http://www.horizonaero.com/PDF%20Dow...Pubs-Index.pdf
The overhaul manual for that unit is in there. I don't know if that
necessarily means that they supply info from it...
Old July 15th 04, 02:32 PM
Pete
Try the rocky mountain encoder site....
http://www.rkymtn.com/einstall.pdf
Cheers,
Pete
Europa with both short and long wings
Hi Everyone,
to
google
tia
Bill
Old July 15th 04, 04:34 PM
Bill Hale
"Bill Chernoff" wrote in message news:vYZIc.9077$od7.923@pd7tw3no...
Hi Everyone,
tia
Bill
Reverse Engineering Aeromechanism 8040 type Bendix connections
A+ R
Gnd H
A1 L
A2 K
A4 A
B1 J
B2 B
B4 F
C1 C
C2 E
C4 D
Gnd P
Jumper M-N
These come from a harness diagram for a
14 v airplane that did once work.
It might be that there is a D output... for you high
flyers. There is one pin, G, unaccounted for on the list
above. I'm not sure all Aeromechanisms would have this.
I believe that one of the grounds is a ground for the LEDs
and one is for the output phototransistors.
I think the jumper from M-N adjusts the current for 14v.
I'd guess that you would leave it out for 28v. You could
measure between them and see if it was a few hundred ohms...
that would confirm the theory.
That's the best I can do. Bill Hale
Adjustment of Altimeter Ron Home Built 5 April 5th 04 03:12 AM
KR-21 marker beacon pinout? JFLEISC Home Built 0 March 17th 04 10:46 PM
SOLD Becker ATC-4401-175 and SigmaTek ARC EA-401A Servoed Encoding Alt Juan E Jimenez Home Built 0 August 11th 03 05:03 AM
FS: Becker ATC-4401-175 Transponder, EA-401A ARC Servoed Encoding Alt Juan E Jimenez Home Built 0 August 6th 03 04:21 AM
Recommendation for Radio, transponder and Altimeter Ron Natalie Home Built 0 July 8th 03 03:40 PM
